  4. Unable to Expand route
17 Posts 7 Posters 3.1k Views 4 Watching
  • Don Staufferundefined Offline
    Don Stauffer
    This route in particular:
    https://www.myrouteapp.com/route/open/10120597
    The first time I tried, I did have the route locked. After unlocking, I can add and remove waypoints, but the Expand feature does not add waypoints.
    I have three other routes that expand as they should. They were all derived from a larger route using segments.
    Thanks in advance for any suggestions or explanations.
    -dhs
    ErikMatthezingundefined Marinus van Deudekomundefined King 06undefined Brian McGundefined 4 Replies Last reply
    • Reinhard-32undefined Offline
      @Don-Stauffer Your observation is correct when I use your route. I have no clue why this is happend.
      BTW. Check the position of your waypoints. Some on them a poor posioned. Point 14 for example.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      • Don Staufferundefined Don Stauffer
        -dhs
        ErikMatthezingundefined Offline
        ErikMatthezing
        @Don-Stauffer
        If I put the route points neatly on the road and then reverse the route, then I can expand the route points. Then I reversed the route again.
        Strange is that if you put the route back in the original position I could not expand again, only if I reverse the route. Maybe a bug somewhere?
        Peter Bijnsdorpundefined 1 Reply Last reply
        • ErikMatthezingundefined ErikMatthezing
          @Don-Stauffer
          Peter Bijnsdorpundefined Offline
          Peter Bijnsdorp
          @ErikMatthezing Ik heb de mogelijkheid om de route te gebruiken daarna kun je de route gewoon bewerken.
          ErikMatthezingundefined 1 Reply Last reply
          • Peter Bijnsdorpundefined Peter Bijnsdorp
            ErikMatthezing
            @Peter-Bijnsdorp Dat klopt, maar dat was niet de vraag van @Don-Stauffer volgens mij. Hij wilde de route uitbreiden met meer waypoints, wat niet goed ging. Toen ik de route heb geopend en bewerkt had ik dus hetzelfde probleem als Don.
            Daarna heb ik mij handelingen zoals in mijn vorige bericht gedaan en toen kon ik wel routepunten uitbreiden. Maar als de route in weer in de origenele staat gezet wordt kan ik ook (weer) niet uitbreiden.
            That’s right, but I don’t think that’s the question of Don-Stauffer. He wanted to expand the route with more waypoints, which did not go well. When I opened and edited the route I had the same problem as Don.
            After that I did my actions as in my previous post and then I could expand waypoints. But if the route is put back in the original state, I can not (again) expand.
              Peter Bijnsdorp
              @ErikMatthezing Gewoon de route geopend, dan gekozen voor gebruik route daarna bewerkt met uitbreiding van meer punten en nu gedeeld.
              https://www.myrouteapp.com/nl/social/route/10126991?mode=share
                -dhs
                @Don-Stauffer hi Don
                I tried expanding the route the way your route was. Nothing happened. Then I looked at your waypoints. Most of them were off route and a couple of them way off route.
                Of you tried expanding such a route MRA is not capable to do that simply because the route is not accurate enough. So try putting all the waypoints ON the route and try again
                Good luck
                  -dhs
                  King 06undefined Offline
                  King 06
                  wrote on last edited by King 06
                  @Don-Stauffer
                  This is not the answer that solves the problem.
                  But for what purpose do you want to expand the waypoints?
                  (expanding works if you "temporarily" convert the used map to TomTom)
                  @Marinus-van-Deudekom said in Unable to Expand route:
                  I did that but it doesn't matter.
                  Don Staufferundefined 1 Reply Last reply
                  • Peter Bijnsdorpundefined Offline
                    Peter Bijnsdorp
                    https://www.myrouteapp.com/nl/social/route/10127239?mode=share
                    hier dus de route opnieuw gedeeld, ik had hem bij mij weggehaald vandaar dat het niet meer te openen was.
                    Als in mijn vorige post opnieuw geopend, dan klikken op gebruik route daarna uitgebreid met diverse punten erop en weer gedeeld. na opnieuw openen zie je gewoon de uitbreiding terug.
                    • King 06undefined King 06
                      @Don-Stauffer
                      Don Stauffer
                      @King-06 The route as posted does not match the route when I open it directly. All points are properly located, including 12 and 14 which are clearly off route on the posted route. I am using the Here map as needed for my Garmin.
                      I believe 40, 41 and 42 were points I added as a test, hence out of sequence. A side question, sometimes I am able to add points between existing waypoints and have them numerically inserted, sometimes I can't get that to happen. I usually click on the previous waypoint, then insert a new waypoint, but sometimes it gets added to the end of the route and I end up dragging it up the waypoint list.
                      By way of explanation, I generally expand a route as a last step before exporting to my Zumo, as an attempt to keep the GPS from altering my route.
                      I'll be taking off later today on our chilly fall color tour around the state of Michigan.
                        @Don-Stauffer Hi Don
                        The route posted had only 27 points. The only point that was ON the route is 24. The rest is off route or even way off route.
                        There are hence no waypoints with a number above 27.
                        If toy want to add a waypoint between 2 existing waypoints click and hold dowd on the route.
                        If you expand your rout as you explained just to keep your XT on track the conclusion mest be there were not enough waypoints to begin with. There are several videos on how the build a route properly maybe that could be a tip for you.
                        The route as you posted is in the beginning of this topic can't be expanded because it lacks enough good waypoints ON the route. Thus MRA can't help your there. Fixe the waypoints first and then build your route.
                        good luck
                          good luck
                          @Marinus-van-Deudekom I've just fixed the waypoints on the route but still it would not expand.
                          Next I reversed the route and expanded it to 60 waypoints. No problem. Reversed it again and the original route contains now 60 waypoints. Beats me Maybe @Corjan-Meijerink can explain it.
                          For your convenience I'll paste the url for the 60 point route.
                          Next I expanded it to 70 points, again no problem
                          Have fun
                          https://www.myrouteapp.com/route/open/10127010
                            -dhs
                            Brian McGundefined Online
                            Hi @Don-Stauffer a couple of suggestions for you
                            I tried changing the routing from Here to TomTom & OpenStreetMap & the original posted route expanded ok. So you could give that a go then return it to the Here routing
                            Secondly I found that point 11 seems to be the issue with the original route expansion, some corruption of location, by just shifting point 11 a bit I was able to expand the origianl route
                            Normaly navigate Routes in Offline mode with Offline Maps
                              Have fun
                              Don Stauffer
                              @Marinus-van-Deudekom Waypoints were properly located on the Here map that I use. As I mentioned, the appearance changed when I made the route public and opened it from the forum. This is not a critical issue, I thought perhaps trying to expand the route when it was locked could have caused an issue. Getting on the motorcycle in a minute to ride this Day 2 route. Unfortunately temps are about 35F this morning, so we'll be using the heated gear. Thanks to all for testing and commenting.
                                @Don-Stauffer the locking of the route could make a difference however when I tried it it wasn’t locked. As been said in this topic the problem around point 11 is. It seemed that the route was cut in 2 overthere. Reversing the route must have solved that problem.
                                Making the route public does noting with the waypoints. When checking the waypoints zoom in max to place the points ON the route. Havé fun today
                                  Don Stauffer
                                  It was a beautiful fall day in Michigan, sunny and brilliant fall color. Turns out 1 routing point was slightly off, #14. The rest of the route executed properly on my Garmin Zumo. No issues around point 11. We'll be back on the road tomorrow, including a couple of my favourite roads from trips past. Thanks to all at My Route for building and maintaining such a great app! It really has made touring easier and more enjoyable.
                                    @Don-Stauffer the problem ponted about point 11 had nothing to do with driving the actual route,
                                    it was to do with why the route would not the expand i.e. your original question 👋
                                    ErikMatthezing
                                    Don Stauffer
                                    Peter Bijnsdorp
                                    King 06undefined
                                    King 06
                                    • App behaviour when in offline mode at a construction site
                                      Peter Zehentreiterundefined
                                    • Nav versus Gold subscription
                                      AWDC LAOundefined
                                      316
                                    • MRA: The Hassle-Free App
                                      AWDC LAOundefined
                                    • Geen kaart
                                      342
                                    • Ervaring met Garmin streetcross op MT-07
                                      AWDC LAOundefined
                                    • Hoeveel apparaten op 1 account ?
                                      AWDC LAOundefined
                                      301
                                    • Verwijderen van routes in eigen bibliotheek
                                      AWDC LAOundefined
