  4. Buggs
Buggs
tug man
2 Posts 2 Posters 693 Views 1 Watching
  • a.w.seaman
    a.w.seaman
    a.w.seaman
    1. While replanning a route I rode in 2013,
      This was originally done in theTyre program that is no longer available.
      While routing up the coast line from Split in Croatia using multiple way points. Your system also showed a second motorway option. This was just one of several instances where this occurred in this region. Why is this happening.
    2. You also have a similar problem with the train under the channel. In that it wants to take you via the ferry to Calais and then back again via train to the parking area at Folkstone.
      Again why is this happening.
    • a.w.seaman a.w.seaman
      @a-w-seaman Sharing your routes in this forum is the best way to get a detailed answer. Make sure the privacy of your routes are set to public before sharing.
      By the way, I’m pretty sure that these aren’t bugs.
      a.w.seaman
      a.w.seaman
      • Route Opacity Viewing Existing Routes in Library
      • Move a GPS point on the map
      • Guida Libera
      • Route leads straight to endpoint
        Rolf Engelsman
        Rolf Engelsman
      • Elevation profile: cursor that follows the route on the map
        79
      • MyRouteApp on the Tracer 9 GT+ Display. Works! :)
        DRD
        DRD
