  4. MRA connector won't see my pc-connected BMW Navigator (tomtom version, 2024 yr)
10 Posts 4 Posters 2.9k Views 2 Watching
  • Rob Bousieundefined Offline
    Rob Bousie
    Every export option the MRA Connector (windows) offers, won't do it. The picture shows the options, but when you have Gold license (like I have now) there are even more options, but still none of them work.
    The two TomTom export options mention that the device needs to approve the import, but nothing shows on the BMW Navigator.
    All other export options just mention that the Navigator is not connected. However, when browsing through en explorer windows, I can also browse the local storage on the Navigator.
    I reported it to MyRoute but they wont follow-up, and exit the conversation by noting that i can manually export the routes and manually import them on my device.
    Anybody else more luck?
    King 06undefined Nick Carthewundefined 2 Replies Last reply
    • Rob Bousieundefined Rob Bousie
      King 06undefined Offline
      King 06
      @Rob-Bousie
      You call your BMW Navigator a "tomtom version, 2024 yr". But that is a wrong assumption. The BMW Navigator is a device developed by BMW with TomTom techniques. It is not a TomTom and therefore the current MRA connector does not work with your device.
      There are several other ways to export your route to the BMW Navigator. They are also described here on the forum.
      Rob Bousieundefined 1 Reply Last reply
        Nick Carthewundefined Online
        @Rob-Bousie The fact that your navigation device uses the TomTom map and algorithms, I would advise you to change your planning map from HERE to TomTom.
        • King 06undefined King 06
          @Rob-Bousie
          Rob Bousie
          @King-06 Thank you for replying. I know how to do it manually, but I would really like to use the Export function directly into my Navigator. But you mention there are several ways, so I am gonna dig in the forum some more. Again, thank you.
          Rob
          ps. I did change the Routes from HERE to TomTom, still no luck. Export problem stays unchanged.
            Rob Bousie
            @Nick-Carthew hi Nick, I encountered the issue before I was a Lifetime member. But now I am, and after changing the map from HERE to TomTom, like you mentioned, the issue stayed unchanged. I really just would like to benefit from the Connectors functionality. Thank you for replying. Cheers,
            Rob
            King 06undefined 1 Reply Last reply
              Rob
              King 06
              @Rob-Bousie
              Changing from Here to TomTom map is not meant to enable export. The BMW ConnectedRideNaviagoter uses TomTom maps and then it is better to plan with the same map.
              You can easily export your created and saved routes to the Connected Ride App if you use the MRA App on your smartphone. After that your route will sync with the Nav.
                @Rob-Bousie
                Rob Bousie
                @King-06 tesrting that, will be my first task for tomorrow 😊
                  King 06
                  @Rob-Bousie
                  MRA and the BMW Connected App
                  The menus have changed in appearance recently, but their essence will certainly still be recognizable.
                    @Rob-Bousie
                    Rob Bousie
                    @King-06 menus changed indeed, but still very workable. Great topic find, this worked for me. 👏 👍
                    • Stephan Dornbergundefined Offline
                      Stephan Dornberg
                      Has this issue been addressed ? I am unable to make use of the MRA Connector functionality on my PC. Ive tried different computers, different cables, nothing work although the Zumo shows up as being connected both in File Explorer as well as Basecamp. I know how to transfer files manually or through Drive, but if the functionality exists, it should work. and it doesnt.
                      Stephan Dornberg
                      King 06undefined
                      King 06
                      Rob Bousieundefined
                      Rob Bousie
                        Simon James Hancockundefined
                        Simon James Hancock
                        2.9k
                      • What is this? (Basic account)
                      • Move blocks of routepoints
                      • What is this red line
                      • Updated beta! 5.2.1 (486)
                        447
                      • Roundabout Symbol and Exit Number
                        b0hd1undefined
