  4. Follow up about my first test of the new version (4.2.0)
21 Posts 9 Posters 4.5k Views 3 Watching
  • Michael Doherty 0undefined Offline
    Michael Doherty 0
    I uninstalled, re-started my Android phone, then re-installed. After downloading all necessary maps and re-configuring the app nothing changed 😞 The function i used most with the previous version still does not work. For me, NOT using the navigation was the best way to do motorcycle rides. But now with the new version, after opening the ride, i no longer can touch the compass button to zoom in to a 3D view and follow the line. It will not track on the map. Using the Navigate feature, it get random "do you want to continue" messages while riding, causing the app to crash. The app seems unstable. I and NOT a computer/phone engineer. i AM an expert motorcycle racer/rider with 55 years in the saddle. My initial impression is that MRA has become to complicated and has to many features that motorcyclists don't need. Simplicity is a motorcyclists friend. But that is just my opinion. I will continue to experiment with it going forward, but will use my second phone and another app as back up for the rest of the riding season. Thank you for the suggestions in my previous post. - MikeD
    Ton Verkleijundefined 1 Reply Last reply
    • Bouke Entundefined Offline
      what i understand is that you use a track and want to follow that without any instructions. maybe option is to select bicycle profile.
      Michael Doherty 0undefined 1 Reply Last reply
        Michael Doherty 0
        @Peter-Schiefer while riding along, it randomly stops navigating and askes me if i want to continue. It also crashes often.
        • Bouke Entundefined Bouke Ent
          Michael Doherty 0
          @Bouke-Ent i will continue to experiment but no longer can use it as my primary navigation app. For me this "upgrade" was poorly timed during the middle of my riding season. I have to go with what i know is working for now.
            The upgrade really was a new (and separate) functionality: the in-app routeplanner.
            I am curious what exactly has changed for you.
            A change has been made regarding “follow the line” but I cannot imagine you prefer that over active route navigation 😉
            As responded in the other thread, I now believe you never started the navigation. The continue prompt only shows when you aren’t navigating.
            So maybe, you just need to start the active navigation 🙂
            versluisundefined Michael Doherty 0undefined 3 Replies Last reply
              versluisundefined Offline
              versluis
              I just got back from the Eifel in Germany but with the new update no problem at all via CarPlay either
              • versluisundefined versluis
                @versluis nice! 🙂
                  Michael Doherty 0
                  wrote on last edited by Michael Doherty 0
                  @Corjan-Meijerink when i start navigation, that is when it randomly pops up the message asking "Do you want to continue" Having this message pop up while riding is not only annoying but dangerous. When i press "continue" the app locks up. This is WHILE riding along.
                    Michael Doherty 0
                    @Corjan-Meijerink I used to be able to Open the route, press the compass button twice to have a 3D view and then follow the line. Simple, easy. Now pressing the compass button twice just shows a DOT. When i try following the DOT the map wont track and the DOT goes off the edge of the map.
                    Corjan Meijerinkundefined Con Hennekensundefined 2 Replies Last reply
                    • paul69undefined Offline
                      hi,
                      new version update
                      i have just returned from an 8 day trip around the highlands of Scotland.
                      All my maps and routes were dowloaded prior to leaving.
                      all navigation was done offline. MRA did not let me down at all, except on one of the trips,
                      for some reason it tried to get me to do a u-turn for two waypoints that i know i passed on my route. eventually it automatically skipped both of them. I checked the route and the waypoints were placed exactly in the middle of the road and there were no diversions. unsure why this happened.
                      one of my routes had to be changed due to a road closure, fortunately i found this out the night before so managed to amend the route, and i used the MRA routplanner, in the next app, i could use this as i am a beta tester, this was very easy to use and worked perfectly the next day when I drove the route.
                      i can only speak from experience but MRA worked very well this time, i have now definitely stopped using all other navigation devices for planning and touring,
                      thanks @Corjan-Meijerink and the team,
                      i know this will not be much help to @Michael-Doherty-0 but you should try to stick with it as this app really works well. there will be reason you had issues, and once you get to the bottom of these i believe you will be a happy teddy.
                      K1600 GTL
                      Oukitel RT3
                      iPhone 13 Pro, carpuride 702b
                      Corjan Meijerinkundefined Michael Doherty 0undefined 2 Replies Last reply
                      • Michael Doherty 0undefined Michael Doherty 0
                        @Michael-Doherty-0 why not just start the active navigation? 😉
                        • paul69undefined paul69
                          hi,
                          new version update
                          @paul69 that is absolutely amazing to hear! 🙂
                          Thanks for the positive feedback. Waypoints might very incidentally not be marked as visited when in really poor reception / just by chance. Great the app solved it by itself! 😃
                          Happy that the in-app planner did its work too! 🎉
                            Michael Doherty 0
                            @Corjan-Meijerink I DO USE THE NAVIGATION. while NAVIGATING...it randomly STOPS....asks me " DO YOU WANT TO CONTINUE"... I click "CONTINUE" this wen the app crashes. I have to close the app, restart it. and get back to my route. Im sorry if i seem frustrated. But having people tell me it works fine for them , does not fix the issues i an having.
                              hi,
                              new version update
                              Michael Doherty 0
                              @paul69 I have years of experience with MRA.. I started back in the Trye To Travel Days
                                @Michael-Doherty-0 said in Follow up about my first test of the new version (4.2.0):
                                and that is what i wrote, once you find out why the issues occur, it will be good, it wasn't to rub your face in it, i was merely writing some feedback.
                                K1600 GTL
                                Oukitel RT3
                                  Ton Verkleijundefined Offline
                                  Ton Verkleij
                                  @Michael-Doherty-0 It looks like them navigation app was designed and runs fine on apple car play and then converted to android auto, with all kinds of problems following.
                                  It's just a small company with a few developers so progress is slow.
                                  -4
                                  • Ton Verkleijundefined Ton Verkleij
                                    @Ton-Verkleij outright not true.
                                    Wouldn’t call progress slow to be fair. For a small team an amazing amount of work is being done.
                                    Micheal Jenningsundefined Michael Doherty 0undefined 2 Replies Last reply
                                      Micheal Jenningsundefined Offline
                                      Micheal Jennings
                                      The App crashes for me each time I open music app Spotify, go back to route-app and its blank.
                                      I now have to invest in other software for my 10 day ride next month, looks like I will have to invest in Calimoto to ensure I get there and back.
                                      This is the only long ride this year so hopefully they can get some of these bigger bugs squashed by then.
                                        @Michael-Doherty-0, The dot follows you, not the other way around 😉 You should not press the compass twice, but only once, for the arrow to become full black instead of outlined.
                                        @Corjan-Meijerink, can it be that the 3D view in "follow the line" mode has been deprecated? I think Michael has a point here. I don't get the 3D view either, but to be honest I can't remember if it was there before... 😉
                                          This is a nice Freudian slip 😉
                                          Bouke Entundefined
                                          paul69undefined
                                          Michael Doherty 0
                                          versluisundefined
                                          versluis
                                          Ton Verkleij
                                          Micheal Jennings
                                          • Problems with DIY POI Files
                                            261
                                          • Start route bij dichtstbijzijnde routepunt werkt niet
                                            Nick Carthewundefined
                                          • Route analysis in WEB planner...
                                            Corrado Miniati 0undefined
                                            Corrado Miniati 0
                                          • Long Term Test in Patagonia - BMW R1250GS
                                            Nick Dawsonundefined
                                            Nick Dawson
                                          • MRA V5.0.3 (449) iOS Gebührenpflichtige Straßen Autobahn ??
                                            Axel Härtlundefined
                                            Axel Härtl
                                          • Gpx naar mra-route gaat fout
                                            Adriaan Vonkundefined
                                            Adriaan Vonk
                                          • Different paths between TT and Here algorithms
                                            RainerTundefined
                                            RainerT
                                            212
