  3. [App] Announcements
  4. New update! (4.2.0) In-app MRA Routeplanner
45 Posts 19 Posters 31.5k Views 8 Watching
  • Cookie On Tour
    Cookie On Tour
    Cookie On Tour
    Thank you, can't wait to try it out!
    Joerg
    (Cookie-On-Tour.de)
    • Ruurt Visser Ruurt Visser
      Waar kan ik instellen dat dit 'gewoon' in het Nederlands te lezen is zodat ik er ook wat van snap?
      @Ruurt-Visser said in New update! (4.2.0) In-app MRA Routeplanner:
      Probeer eens de tool van deepl.com:
      Vertalingen van en naar alle talen die maar wil (nou ja, veel in elk geval).
        @Ruurt-Visser forum aankondigingen doe ik altijd in het Engels. De mailing over deze update en de bijbehorende info pagina’s zijn ook Nederlands 🙂
        Ruurt Visser 1 Reply Last reply
        • Stuart Greer Stuart Greer
          @Corjan-Meijerink i like the new capabilty. as an XT user, when modifying or creating a route offline is there a way to export a gpx file.
          @Stuart-Greer not yet! That is only possible when accessing it online as the file is created by our website rather than by the app itself.
          Stuart Greer 1 Reply Last reply
            Stuart Greer
            Stuart Greer
            Stuart Greer
            @Corjan-Meijerink thats good news Corjan, great work on the route planner.
              Ruurt Visser
              Ruurt Visser
              Ruurt Visser
              @Corjan-Meijerink Dank je wel. Ik ga beter kijken.
              • Cookie On Tour
                Cookie On Tour
                Cookie On Tour
                I love the new options and I can't wait to see a true sync coming, so no manual downloads are needed.
                QQ: Has the app received any other fixes to bugs or enhancements regarding sound for example? Is there a full release note somewhere?
                Joerg
                (Cookie-On-Tour.de)
                • Cookie On Tour Cookie On Tour
                  @Cookie-On-Tour, These ARE the release notes 😉
                  Cookie On Tour 1 Reply Last reply
                    Cookie On Tour
                    Cookie On Tour
                    Cookie On Tour
                    @Con-Hennekens said in New update! (4.2.0) In-app MRA Routeplanner:
                    LOL okay, so no improvements or fixes to the sound issues....
                    Joerg
                    (Cookie-On-Tour.de)
                      @Cookie-On-Tour correct 😉
                        Good morning MyRoute-app users!
                        We are proud to announce the upcoming release of the in-app MRA Routeplanner 🎉
                        After elaborate testing by the Alpha and Beta testers, we are confident that this will be an epic release 💥 With pride we present the in-app MRA Routeplanner to you!
                        With this routeplanner you can edit your high quality MRA routes with an interface it deserves.
                        • Edit any existing route! 💪
                        • Create a new route from scratch
                        • Change routes from others
                        • All this can even be done offline! 🎉
                        The Routeplanner offers many features to help you in building lovely routes.
                        Quickly keep adding waypoints to your route to shape the route to your preference.
                        • Yellow button starts the adding process and keep tapping it to continuously add waypoints
                        • Click add to add a new waypoint and stop adding more
                        • Cancel, dismiss what you are doing
                        If you make a mistake, no problem! Simply use the undo / redo buttons like you are used to in the website 😉
                        Do you want to add information to waypoints? Ofcourse you can do so! 🎉
                        Change the colour, type, note, title, pause duration or even the icon of the waypoint! 😮
                        Do you want to add a waypoint somewhere along the route? Obviously that's possible too!
                        • Tap somewhere along the line to add a waypoint there in order of the route
                        • Long press and drag a line to immediately move the marker you are adding in that leg
                        Do you need to move a waypoint precisely? Simply use the advanced move interface to place the waypoint exactly where you want. Long pressing and dragging the waypoint works too but that is less precise 🙂
                        Then we also allow you to change any of the other settings.
                        • Edit the name / description of the route.
                        • Alter the privacy / travel mode
                        • Avoid specific type of roads
                        • View all the waypoints
                        Talking about waypoints! Did you know you can drag the waypoints shown in the list to reorder them? 😏 When you've opened a waypoint you can also swipe left / right to jump to the previous / next waypoint 😮
                        That's it really!
                        So in short:
                        • Create new routes from scratch
                        • Edit any route
                        • Access to our unique MRA Routeplanner features in-app
                        • Modify waypoints
                        • Change route information / details / options
                        Feel free to discover all other features yourself 😉
                        Isn't this an amazing update??? We have put a lot of focus in the visual appearance and user experience of this planner so we hope you are satisfied.
                        In the upcoming update we will rework your route library to enable easy syncing of all your routes. Meaning that offline created routes will be synced to the website when online again, you can automatically sync routes / your entire library between website and app! 🎉 But that's for later 😉
                        If you got any feedback, feel free to share it on this forum 🙂
                        Best,
                        Corjan
                        Team MRA ❤
                        marc van der heijden
                        @Corjan-Meijerink ik had anders meteen problemen, app liep vast nadat ik wilde proberen ( weet niet of het überhaupt kan ) route overslaan functie, app crashte en kon helemaal opnieuw beginnen want zelfs de route werd niet opgeslagen zoals dat normaliter wel het geval was
                        Marinus van Deudekom Corjan Meijerink MotoCon 3 Replies Last reply
                        • paul69
                          hi @Corjan-Meijerink
                          i managed to use the in-app routeplanner while touring recently due to a road closure, i had to re-plan the next day's ride and i must report that it worked extremely well, and it was very easy to use, excellent bit of work MRA gang
                          K1600 GTL
                          iPhone 13 Pro, carpuride 702b
                            @marc-van-der-heijden jammer dat de app vastliep. Je moet bij de in app planner de route wel opslaan anders dan in de web versie. Die stap heb je niet kunnen doen dus ook niks opgeslagen.
                              @marc-van-der-heijden dat kan ook gewoon gebeuren hoor 😉 Gaat vaker goed dan fout en foutjes zijn op te lossen. Heb je bij je andere bericht al gevraagd of het te reproduceren is.
                              • paul69 paul69
                                @paul69 awesome! 🙂
                                  @marc-van-der-heijden said in New update! (4.2.0) In-app MRA Routeplanner:
                                  Gebeurde dat direct na de app update? Ik heb wel vaker gemerkt dat direct na een update niet alles vlekkeloos werkt. In mijn beleving komt dat door het updaten van een draaiende app. Ik maak er een goede gewoonte van om na een update de app een keer geforceerd te sluiten (niet wegswipen, maar force-close vanuit de Android settings - apps). Een reboot zou natuurlijk hetzelfde resultaat hebben.
                                  marc van der heijden 1 Reply Last reply
                                  • Richard 18
                                    Richard 18
                                    Richard 18
                                    Great work.
                                    Thank you for all the effort put in.
                                    Richard
                                    • Marius Gross
                                      Marius Gross
                                      Marius Gross
                                      Hallo, ich finde die offline Planung als gelungen und hilft mir sehr bei doch noch einigen Standorten mit schlechtem oder keinem Internet. Einen grossen Haken hat es aber für mich immer noch.
                                      Ich plane die langen Strecken lieber auf einem Tablet als auf dem Smartphone. Wenn ich nun auf dem Tablet im Offline Modus plane und danach die Route speichere, wird diese bei den Downloads nur auf dem Tablet gespeichert. Ich habe bisher keine Möglichkeit gefunden, diese Route auf dem Smartphone für die Navigation zu speichern oder sogar als Export auf das Garmin Zümo XT2 (via Tread App) zu bringen.
                                      Habe ich etwas übersehen?
                                      Corjan Meijerink Dirk Kevin K. 2 Replies Last reply
                                      • Marius Gross Marius Gross
                                        @Marius-Gross no that’s correct!
                                        We need to implement that and will be added in the next update 🙂
                                        For now a workaround is to modify the route from the downloads folder when you got internet and then you will be able to save it online too!
                                          vanuit Android ken ik het, in de iPhone is het volgens mij gewoon app sluiten, ik sluit sowieso vaak apps
                                          JP d
                                          JP d
                                          Tom Grzelinski
                                          Tom Grzelinski
                                          BMcG
                                          BMcG
                                          Stuart Greer
                                          Stuart Greer
                                          Cookie On Tour
                                          Cookie On Tour
                                          Ruurt Visser
                                          Ruurt Visser
                                          Richard 18
                                          Richard 18
                                          Marius Gross
                                          Marius Gross
                                          Paulusma
                                          Paulusma
                                          versluis
                                          versluis
                                          Dirk Kevin K.
                                          Dirk Kevin K.
                                          Benny Van de Velde
                                          Benny Van de Velde
                                          • 'Geen adres bekend'
                                            PA. Vis 0
                                            PA. Vis 0
                                            Ruud Bijkerk
                                            Ruud Bijkerk
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                            127
                                            158
                                          • iPad - zooming out
                                            Big Al 1
                                            Big Al 1
