  4. Crazy routes when using Here maps because of disconnections in roads
10 Posts 5 Posters 1.8k Views 2 Watching
  • Ramon Cutanda Lopez Offline
    Ramon Cutanda Lopez
    wrote on last edited by Ramon Cutanda Lopez
    Hello,
    I have just purchased a new motorbike and I am preparing some winding routes for the running-in. To my surprise, I am finding a lot of "disconnections" in roads which forces the Here navigation engine to design INSANE deviations. I had experienced this problem in the past, but this time I am completely shocked to find that:
    a) I am experiencing such disconnection in 3 out 3 of the routes I have planned.
    b) In the most extreme example, there is a detour of almost 100 km.
    The problem is exclusive of Here maps, as the routes are planned as expected with the TomTom engine.
    Here you have the links to the routes shown in the screenshots below:
    https://www.myrouteapp.com/en/social/route/9603492?mode=share
    https://www.myrouteapp.com/en/social/route/9603898?mode=share
    https://www.myrouteapp.com/en/social/route/9604085?mode=share
    alt text
    alt text
    alt text
    alt text
    alt text
    alt text
    I personally use two strategies when I find this problem:
    a) Mark the point where the disconnection begins as a mandatory stop, so that I know that I need to stop navigating because "something is going on". I then ignore the navigation directions along the faulty connection, which usually means just some metres, and then go on as planned.
    b) Create separate routes for each of the sections where disconnection begins and ends.
    I find both strategies quite annoying; but better that than riding dozens of extra miles.
    I am aware that this is not a MRA problem, but Here's. However, because MRA chose Here as the navigation engine and maps I feel that some kind of tool needs to be developed within MRA to address this kind of problem, as I consider it is a serious one.
    Regards,
    Marinus van Deudekom Gerard Wullink MTC-Zeilberg 4 Replies Last reply
    • Ramon Cutanda Lopez Ramon Cutanda Lopez
      Hello,
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      Regards,
      Marinus van Deudekom Offline
      @Ramon-Cutanda-Lopez are You using any restrictions while planning. Do you have trafic information on. Things like that can cause your problem. Since you made the routes with TomTom card did you compare the route in the toolkit with the Here card.
        Hello,
        alt text
        alt text
        alt text
        alt text
        alt text
        alt text
        Regards,
        Gerard Wullink Offline
        Gerard Wullink
        @Ramon-Cutanda-Lopez Could it be you have 'saesonal closings' active on the toolkit? If you plan routes over mountains in early spring, they could well be closed due to snow.
          Ramon Cutanda Lopez
          Thank you for your interest, Marinus and Gerard:
          1. No restrictions whatsoever.
          2. No traffic enabled.
          alt text
          alt text
          1. I created the routes using Here maps. However, I switched to TomTom just to take the screenshots so that you could compare the crazy route planned by Here vs the "logical" route that I expected and that TomTom indicates correctly.
          Thank you once again.
            Hello,
            alt text
            alt text
            alt text
            alt text
            alt text
            alt text
            Regards,
            @Ramon-Cutanda-Lopez in ruta 2 there’s a road closed Between 14 and 17
            If You activate the trafic layer it’s quite clear
            Ramon Cutanda Lopez 1 Reply Last reply
              Hello,
              alt text
              alt text
              alt text
              alt text
              alt text
              alt text
              Regards,
              MTC-Zeilberg Offline
              MTC-Zeilberg
              Take a look at youte routepoints, place them ON the here routeline
                Ramon Cutanda Lopez
                @Marinus-van-Deudekom, bingo!
                I had problems with two of the routes because the road is officially closed:
                https://infocar.dgt.es/etraffic/
                https://www.google.com/maps/d/u/1/viewer?mid=1YnK1nWlT0fxWYoDF8GpF6lHi3CvpYg8&ll=38.19435257766315%2C-2.253235930796811&z=13
                alt text
                alt text
                That explains why the route breaks after point 14:
                alt text
                And also why I cannot connect waypoints 12 and 13 in my other route:
                alt text
                I still have no explanation, however, to this extrange turn here:
                alt text
                I make the left turn at waypoint 2 once or twice a week. There is absolutely no problem whatsoever there.
                I had never used the traffic layer before, as I plan my routes days —sometimes weeks— ahead of my trips, so I thought that info would not be useful. I now know it is! Thank you for your tip, Marinus.
                • MTC-Zeilberg MTC-Zeilberg
                  Ramon Cutanda Lopez
                  @MTC-Zeilberg Thank you for the tip. However, even if I place the waypoint as precisely as possible, Here still plans a wrong turn.
                  alt text
                  Regards,
                    Ramon Cutanda Lopez
                    After checking the official detour, it turns out that one section of the road marked as blocked by Here is ACTUALLY NOT BLOCKED and I need to use it to access one of the officials detours. Is there any way to force the planner to ignore blocked sections?
                    alt text
                    alt text
                    • M. Schrijver Offline
                      Welcome to the stange world of navigation.
                      What can i tell you to help you?
                      Here and TomTom are two different producers of maps. Both are making good maps but they are not exactly equal.
                      When ypou encounter difference in making routes between the two maps and you cannot solved these difference by placing some extra routepoints. Search for the location where the diffuculties are. When you found it. Try to avoid this location on both maps.
                      My experience in real-life. If something like this happens the situation on the road is mostly also (a bit) odd.
                      When planning with TomTom map. The traffic info of TomTom is not used. Basicly you can easily make a route over a stretch of road which is closed.
                      But in Here it is a different. Even when traffic info is not shown. The Here map uses the traffic when making a route. This can confuse people.
                      This can result in your question
                      MTC-Zeilberg
                      MTC-Zeilberg
                      Gerard Wullink
                      Gerard Wullink
                      Ramon Cutanda Lopez
                      Ramon Cutanda Lopez
                      • opslaan naar plantomtom
                        chris 18
                        chris 18
                      • Elektrisch voertuig
                        jan rodeyns
                        jan rodeyns
                      • Waypoint list for a long route ( ~50 t0 100 routing points) will not be show on the Android auto ridernav screen
                        Stevedo 6 0
                        Stevedo 6 0
                      • Update 5.2.2 - Quick fix
                        1.2k
                        Ioan Dragulescu
                        Ioan Dragulescu
                        10.3k
                      • Carpuride W702 icm Carplay
                        17.5k
                        299
                      • scherm bevrirzing
