  4. No Navigation to Destination if route was left
10 Posts 4 Posters 1.8k Views 2 Watching
  • Kudee Offline
    Kudee Offline
    Kudee
    wrote on last edited by Kudee
    Up to now I have only ever driven with planned routes, which works very well.
    Today I used the magnifying glass to find a destination. Selected direct or curvy for selection, decided in favour of curvy.
    On the way I then shortened the route and drove directly towards my destination. What is happening now is very special: MRA is constantly trying to get me back on the original and calculated route! Even 50 metres from the destination, MRA wants to return to the route!
    This is not what I expect from a sat nav. Can anyone reproduce this? Operating error?
    4.1.3-312,
    • Jörgen Offline
      Jörgen Offline
      Which version are you using?
      Kudee 1 Reply Last reply
      • Jörgen Jörgen
        Kudee Offline
        Kudee Offline
        Kudee
        @Jörgen 4.1.3-312
        Jörgen 1 Reply Last reply
        • Kudee Kudee
          @Jörgen 4.1.3-312
          Jörgen Offline
          Jörgen Offline
          @Kudee
          Ok, sounds good, there was a former version with a similar problem. If you left the track, you wouldn’t be guided back.
          By the way, if you use A to B navigation you get a Route, if you use any curvy option you get a Track.
          Anyway I will try to reproduce your problem.
          • Jörgen Jörgen
            @Kudee
            Kudee Offline
            Kudee Offline
            Kudee
            @Jörgen Thank you Jörgen! But you agree with me that this is the simplest thing that any Medion Aldi 79.-Euro sat nav should be able to do 🙂
            • Kudee Kudee
              4.1.3-312,
              @Kudee said in No Navigation to Destination if route was left:
              Sounds perfectly normal. You plan a route, if you deviate you are directed back to the route (which actually is a track, since you uses curvy options). It used to be a lot of people's frustration that, when navigating a track, the system heads to the destination directly when you deviate. Seems to be solved now 🤣
              ehm, no! Not for a track. 😉 If you use a direct route, it perfectly does as you propose.
              Kudee 2 Replies Last reply
                Kudee Offline
                Kudee Offline
                Kudee
                This post is deleted!
                  Kudee Offline
                  Kudee Offline
                  Kudee
                  @Con-Hennekens Sorry again. It doesn't really work that way. If I deviate from the route, MRA wants to return to the calculated route a few times, 4 times? This is extremely annoying, especially in a city. Google Maps does this much better and recalculates every time I leave the route. Can I get MRA to do this?
                  • M. Schrijver Offline
                    A simple A tot B route is something else compared to pre-planned route
                    MRA is specialized in Pre-Planned. Google Maps is specialized in A to B routes
                    As far is i know. MRA does not stop when reach your destination. You must stop navigating manually.
                    • Kudee Kudee
                      @Kudee, Yes, the MRA app also immediately recalculates once you deviate from it. Similar to Google Maps.
                      • if you use a direct route (that also means NO curvy options!) it will calculate the quickest routes to the finish, just like Google Maps.
                      • if you are navigating a track (that includes a A2B route using curvy options) it will redirect you to the track in a logical manner. But not everyone's logic is the same 😉
                      • if you are navigating a route with waypoints, it will use an algorithm to decide to which next waypoint you will be redirected. This happens at the third recalculation. It is assumed that when you meticulously plan a route, you will want to ride as much as possible of it. Therefore you are not immediately redirected to the next waypoint indeed, but only after the second recalculation. It then goes to the closest waypoint ahead in the route. That CAN still be the same waypoint, but can also be one of the next waypoints (with a maximum of 10). Iirc after 5 recalculations it will not try to reach the same waypoint anymore, but usually it will have skipped it by that time anyway.
                      For situations in which you want to skip waypoints quicker, there is a convenient button on the screen. Personally I think this is way better than needing to revert to previously unintended auto skipped waypoints, because there is no convenient way to do that without stopping.
                      Kudee
                      Kudee
                        272
                        siebo vd berg
                        siebo vd berg
                        517
                      • Transport modes?
                      • Google maps and Streetview
                        777
                      • New Zealand Routes
                      • MRA 5.2.2 (489) Avoidances are not taken into account///Vermeidungen werden nicht berücksichtigt
