  4. Avoid Dual Carriageways
9 Posts 5 Posters 2.9k Views 1 Watching
  • Ian Montana
    Ian Montana
    Ian Montana
    Hi - I'm plotting our Euro Tour for this year and I wondered if there was an easy way in MRA to avoid dual carriageways and motorways. I've been using shaping points but there must be an easier way ?
    Thanks
    Erdna 1 Reply Last reply
    • Ian Montana Ian Montana
      Thanks
      Erdna
      Erdna
      Erdna
      @Ian-Montana Cheers,
      did you try these options?
      2024-06-06 18_15_11-2 Porto Tolle - Mulazzo – MyRoute-app Web – Mozilla Firefox.jpg
      Ian Montana 1 Reply Last reply
      • Erdna Erdna
        Ian Montana
        Ian Montana
        Ian Montana
        @Erdna Hi - yes I did but the routing always chooses dual carriageways as the fastest route
        Thanks for replying
          Thanks for replying
          @Ian-Montana, then set the route optimization to shortest (car mode only I believe). Still no guarantee, but it will not be chosen for being the quickest way. You will need to add more waypoints on none dual carriageway roads to prevent them.
            Ian Montana
            Ian Montana
            Ian Montana
            @Con-Hennekens I found a solution - change the map to open street map then choose avoid highways and it works - then go back to goolge maps and all good 🙂
            Thanks for all the comments
            Con Hennekens paul69 2 Replies Last reply
              @Ian-Montana, You need to consider that Google Maps is just a map overlay, it is not a map that routing is based on. Besides, not all dual carriage roads are highways. Especially if you are navigating with the MRA app you will be better off using the HERE map (in the top menu, not the layer tile). Shaping points ARE the answer... 😉
                @Ian-Montana
                hi @Ian-Montana
                just a point to note, if disabling dual carriageways was an option, in some regard this may cause problems.
                A dual carriageway can sometimes be only 100m long, i.e. to make a junction safer better traffic movement etc.
                so on a lovely windy road you are tootling along and then all of a sudden you must drive down narrow country lanes full of mud and cow sh*t just to avoid a small section of that particular road.
                just a thought.
                K1600 GTL
                Oukitel RT3
                iPhone 13 Pro, carpuride 702b
                Lynchy67 1 Reply Last reply
                • paul69 paul69
                  @Ian-Montana
                  hi @Ian-Montana
                  just a thought.
                  Lynchy67
                  Lynchy67
                  Lynchy67
                  @paul69 said in Avoid Dual Carriageways:
                  Personally, I love those types of country lanes. 👍
                  • Lynchy67 Lynchy67
                    @Lynchy67, yes me too, except for the mud and cow sh*t 🤣
                    Erdna
                    Erdna
                    Lynchy67
                    Lynchy67
                    Ian Montana
                    Ian Montana
                    • Custom POI color and icons
                    • File en omrijden
                    • A11 Making the Algorithm More Visible – Overview and Planner File
                    • File / Creation date
                      Robineke
                      Robineke
                      310
                    • F003 POI Folder & group missing in the app
                    • F005 Menu covered
                      13.6k
