  4. Offline Setup
Offline Setup
19 Posts 5 Posters 4.1k Views 3 Watching
    @Nigel-Ralphson, can you visualize that? Screenshots or screen recording? I have no idea what you are looking at. If you have waypoints in your route, I don't really see how Navigation would not use them...
    Nigel Ralphson
    Nigel Ralphson
    Nigel Ralphson
    @Con-Hennekens Screenshot_20240528_132344.jpg Screenshot_20240528_132329.jpg Screenshot_20240528_132404.jpg
      Nigel Ralphson
      Nigel Ralphson
      Nigel Ralphson
      @Con-Hennekens Hi Con, please see pics. As you can see...if I click navigate and track it follows the route I've created. If I click route it comes up with a completely random route!
        No it does not. The route is only extended. From point 1 to point 3 the route is identical.
        The extra route to point 1 is from your current postion. You can disable it.
        A bit below the yellow "Start" button is an option. "Start from current location" Disable this and look at the result
        Nigel Ralphson 1 Reply Last reply
          Nigel Ralphson
          Nigel Ralphson
          Nigel Ralphson
          @M-Schrijver Ah I didnt see that as it disappears very quickly. However, as you can see below with a different example the routes arent the sameScreenshot_20240528_134455.jpg Screenshot_20240528_134407.jpg Screenshot_20240528_134427.jpg
          MotoCon M. Schrijver 2 Replies Last reply
          • Nigel Ralphson Nigel Ralphson
            Hi, I know this topic has been covered but I cant find anything which solves my issue.
            I have downloaded the relevant country and the route I have created. I have also gone into "Functional" and switched "Offline navigation" on.
            However, when I then select the route and press navigate it says " no internet connection - go offline". I click that and it says "offline navigation enabled - no route could be calculated using your offline map. To try again, we need to turn off the offline navigation" and gives me the option to go online.
            Hence, I am confused!!
            Where am I going wrong?
            Re: Offline
            @Nigel-Ralphson
            Download the route for off-line use. Then goto downloads and start the route by clicking on the file wich is the route you want to drive
              @Nigel-Ralphson, The last 3 pictures you posted:
              Picture 1 is a route overview like you planned it in the planner
              Picture 2 is the same route, but calculated for navigating with the HERE map AT THIS TIME (considering trafic information). This can be slightly different.
              Picture 3 is a tracklog you recorded, which does not necessarily follow the route you planned.
              I really see nothing out of the ordinary (or I completely miss your point 😉 )
              Nigel Ralphson 2 Replies Last reply
                @Nigel-Ralphson
                Two things to try and see some results.
                Disable traffic-aware routing. When disabeling. The route in MRA Routeplanner and MRA Next could be the same.
                Place more points between point 3 and 4. This way you force MRA Next more to follow the same route.
                  @Nigel-Ralphson
                  Nigel Ralphson
                  Nigel Ralphson
                  Nigel Ralphson
                  @Hans-van-de-Ven-MR-MRA thanks but done that
                    Nigel Ralphson
                    Nigel Ralphson
                    Nigel Ralphson
                    @Con-Hennekens I havent done the route yet! On a test if I follow the track it follows my planned route but if i follow the route it deviates,
                      @Nigel-Ralphson
                      Nigel Ralphson
                      Nigel Ralphson
                      Nigel Ralphson
                      @M-Schrijver thanks I'll give it a go
                        Nigel Ralphson
                        Nigel Ralphson
                        Nigel Ralphson
                        @Con-Hennekens Hi Con, I ran a route yesterday that I'd designed. My friend ran it in route mode and I ran it in track. The routes were completely different. The route mode just looked for the fastest point between waypoints whilst the track mode followed my prescribed route. 🤷‍♂️
                          #19
                          @Nigel-Ralphson, If you plan your route on the HERE map, differences while navigating can virtually only happen due to traffic. So if you did not encounter any traffic problems, it is a sign that you probably did not plan it on the HERE map, and that you have set way too less waypoints. You may share that route with us, so we can have a look. Without that, I don't see how we can be of further assistance.
                          Nigel Ralphson
                          Nigel Ralphson
                            guenniguenzelsen
                            guenniguenzelsen
                            Emanuele 5
                            Emanuele 5
                          • Club routes public/private
                          • Bollard trouble
