  4. Compare function in toolkit - odd results
6 Posts 4 Posters 950 Views 3 Watching
  • David Butteryundefined Offline
    David Buttery
    wrote on last edited by David Buttery
    I plan in HERE, and was using the toolkit function to compare with TomTom (first time i have done this). Initially it found a couple of differences, which I eliminated with additional shaping points. However one instance left a "limb" hanging in the red TomTom overlay that didn't make any sense. Tried to capture a screenshot of it - attached. Any ideas ? .Screenshot 2024-05-27 at 16.31.12.png
    Nick Carthewundefined Rob Verhoeffundefined 2 Replies Last reply
    • David Butteryundefined David Buttery
      Nick Carthewundefined Offline
      @David-Buttery It’s not easy to offer an explanation or solution from just a screenshot. Sharing the route would be more useful.
      David Butteryundefined 1 Reply Last reply
        Rob Verhoeffundefined Offline
        @David-Buttery It seems to me as a map error in the TomTom map. I can easily drive that same section of road from point 45 to 48 on the Here or OSM map. Streetview also does not provide any other insights that would suggest you need to choose a different direction.
          In TomTom Mydrive the same result appear. But....
          If you turn the direction of the route around. Everything is well.
          I could be an error on the TomTom map. But it could also be the situation has been changed over there. Streetview is not updated that often.
          Coming from point 46, you are only allowed to turn left.
          Because wherever i put point 47. The route does always goes left and then turns around and from there it goes to point 47
            David Buttery
            @Nick-Carthew route is public - here's link: https://www.myrouteapp.com/en/social/route/9210776?mode=share
              @David-Buttery Thank you for sharing your route. When I use the plan.tomtom route planner I also see the same issue, so obviously an error in the TomTom map.
              I have reported the error to TomTom, you can do the same here: https://www.tomtom.com/mapshare/tools/new/mapshare/#loc=53.96705,-2.44067,19.5
              David Buttery
              • Next+ 1st impressions
                610
              • Problems with DIY POI Files
              • Carpuride zwart scherm
                CD130undefined
              • Tracking rijden
                De Ploey Georgesundefined
                De Ploey Georges
              • positie indicator meerdere keren ver van de route
                844
              • geen afstand in overzicht
              • overzetten van my route op tomtom
              • Hello, i want to make a trip to the Dolomieten (cortina )from Halle 1500(Belgium) in about 3 days. came somebody tell me a nice route or what i must avoid?Thanks
