  4. Voice prompts are wrong at roundabouts
7 Posts 4 Posters 959 Views 2 Watching
  • Ben Raineundefined Offline
    Ben Raine
    On a ride today the voice prompts at EVERY roundabout told me “At the roundabout take the first exit” despite the map clearly showing that I should take the 2nd, 3rd or any other exit.
    The route was planned in MRA and I wasn’t off route at all. My friend also was experiencing the same problem n the same route.
    Anyone else have this issue?
    BMW R1200RS, Garmin XT but it winds me up so now using MRA Navigation more on IPhone 14 Pro Max
    • Ben Raineundefined Ben Raine
      Rob Verhoeffundefined Offline
      @Ben-Raine this is a known issue due to a bug at the map supplier Here. Should be a bug fix on their side soon. In the mean time, select drive mode car instead of motorcycle.
      BMW K1600GT-P (2013) | Nolan N100-5 with Sena 30K
      iOS on iPhone 13 & 16 (mounted on Quadlock or AliExpress extention on BMW-cradle)
      Apple CarPlay in VW T-Roc
      Michael Kruseundefined Ben Raineundefined 2 Replies Last reply
        Michael Kruseundefined Offline
        Michael Kruse
        Ja das habe ich auf meiner Vatertagstour auch festgestellt.
        Außerdem funktioniert bei mir der Blitzerwarner nicht obwohl aktiviert.
        Habe die Gold - Version und MRA Navigation Next.
        Woran kann es liegen das der Blitzerwarner nicht funktioniert. ???
          Ben Raine
          @Rob-Verhoeff thanks for clarifying, more annoying than anything but hopefully the fix will be out soon
          • Michael Kruseundefined Michael Kruse
            @Michael-Kruse said in Voice prompts are wrong at roundabouts:
            Das is nicht gestattet in Deutschland, oder?
            Michael Kruseundefined 1 Reply Last reply
              Michael Kruse
              OK. also im Ausland , wenn erlaubt geht Sie , aber in Deutschland nicht
              Ist von My Route App so eingestellt???
                @Michael-Kruse, This is most likely no MRA setting, but due to the absence of speedcamera information in Germany, since that is not allowed 😉
                Michael Kruse
                Ben Raineundefined
                Ben Raine
                • New beta! 5.1 (457)
                  arcangelenrutaundefined
                  arcangelenruta
                  13
                  43
                  277
                • V5.1.0 - 458 Same Point in Route Cycles to First Instance if Later Point Selected - CarPlay
                  Dave J 0undefined
                • Joining a planned route from a differant position.
                  supergundefined
                • Snelste route vergelijken met de kortste route.
                  M. Schrijverundefined
                • Use GPX Format 1.1 for export
                • Clearing existing text in dialogue when editiing
                • Random routes.
                  MattN_73undefined
                  MattN_73
