  3. [Beta] Announcements
  4. Updated beta v4.1.2 (305)
35 Posts 16 Posters 589 Views 5 Watching
  • Michel van Hagen MRA-Founder
    Administrator
    Ik rij nu in de Harz met app versie 4.1.3 - 306 (alpha test versie), geen crashes, app hervat de route goed, tussenstop toevoegen ging goed, audio goed, navigeren goed, Apple CarPlay geen klap verkeerd gegeven, dat geeft geen garantie dat het bij iedereen goed gaat en ik heb niet alles getest, maar het lijkt een bijzonder stabiele versie te zijn!
    I am now driving in the Harz with app version 4.1.3 - 306 (alpha test version), no crashes, app resumes the route well, adding a stopover went well, audio good, navigating well, Apple CarPlay did not give a wrong blow, that doesn't matter. guarantee that everyone will be fine and I have not tested everything, but it seems to be a very stable version!
      Today i did a tour again. Waypoint Messages set to all.
      Today it went pretty good. There were some small things but a lot better than yesterday.
      This shows a problem also. Still a lack of stability. Some days goes well and other days are problematic. This should be more or less the same every day. The software must be reliable, predictable.
        @Tom-Johann thanks! How did your drive between those waypoints? When not deviating it should start skipping 🙂
        Tom Johann
        Tom Johann
        Tom Johann
        @Corjan-Meijerink said in Updated beta v4.1.2 (305):
        exactly. I did not deviate from the route but in some cases it autoskipped anyway..
        • Arno 0
          Arno 0
          Arno 0
          I’m using this latest version now in camper mode during my vacation in France on an old Samsung A6 tablet. The navigation itself is no problem but during my rides, the bleu line that shows the way to drive is constantly changing. Sometimes it’s gone for a few seconds, then it’s a bold line, a thin line or you see three lines next in parallel. Very strange and frustrating especially when you need to check which way to take and it’s not shown. Is there a solution?
            What i think what happens.
            When driving you have a certain speed. But the accuracy of the GPS varies. Therefore every navigation tries to predict what are going to do. You see this behaviour when entering and exit long tunnels.
            I think the disapperance of the blue line is also a part of this prediction (sort of).
              @M-Schrijver correct 🙂
              Arno 0 1 Reply Last reply
                Arno 0
                Arno 0
                Arno 0
                @Corjan-Meijerink Is there something that I can do to prevent this or is it due to the GPS of my tablet or the way MRA works? The constant changes are not very pleasant because it every time asks your attention even if you're not really looking at the screen.
                • Arno 0 Arno 0
                  @Arno-0 said in Updated beta v4.1.2 (305):
                  Could this be caused because your tablet in the camper van is not getting a clear view of the sky?
                    That is a possibility.
                    • Arno 0
                      Arno 0
                      Arno 0
                      I don’t think this is the problem because the tablet is mounted directly behind the windscreen. I can check tomorrow if there is any difference when using my smartphone on CarPlay. Then I will use both in parallel because I do not trust the stability of CarPlay yet and don’t like problems during riding.
                      • arcangelenruta
                        arcangelenruta
                        arcangelenruta
                        Using the new beta on my motorcycle with CarPlay, I have observed that there is a difference from the previous one related to the audio of the navigation instructions. Before, I used the navigation channel for the instructions.
                        Since the last beta for the same instructions, use the channel identified as "Vol. Audio."
                        This causes problems since the radio is cut when it gives an instruction and you have to reactivate it, or it is mixed with the audio of the music causing cuts in the instructions.
                        Is it possible to return to the previous operation, and use the navigation channel for the instructions?
                        Thanks!!!
                        Rafael Rodriguez
                        Honda GL1800BD Goldwing
                        Edwin_M
                        Edwin_M
                        Stanisław
                        Stanisław
                        arcangelenruta
                        arcangelenruta
                        Arno 0
                        Arno 0
                        Lynchy67
                        Lynchy67
                        Tom Johann
                        Tom Johann
                        Walter Coady
                        Walter Coady
                        • Animation
                          23
                        • Route line transparency
                        • Issues about using planner in tablet
