  4. Android Auto - power consumption - hot phone
18 Posts 8 Posters 7.0k Views 3 Watching
    @Rob-Smith Thanks! Totally understand 🙂
    Andrew
    Andrew
    Andrew
    I have been running my phone on dark screen mode and after an 8 hr ride using Myroute app it is still showing 95% + charge
    • Andrew Andrew
      @Andrew That is definitely while charging and very likely too.
      If the phone itself doesn't have much overhead load and the charger is decent, this is what we expect 🙂
      Andrew 1 Reply Last reply
        Andrew
        Andrew
        Andrew
        @Corjan-Meijerink Yes while charging I have had it in the past when the phone would only last for about 3 hrs while charging think dark mode helps a lot, still having problem with android auto showing roundabouts as left or right turns but phone shows roundabout correctly, very pleased with the way the app is progressing and seems to be improving for me with no drop outs on the last few rides. Keep up the good work.
        • richtea999
          @Andrew said in Android Auto - power consumption - hot phone:
          [I] think dark mode helps a lot
          Spot on. See here:
          "The Purdue study found that switching from light mode to dark mode at 100% brightness [i.e. full sunlight] saves an average of 39%-47% battery power."
          Rob Smith 1 Reply Last reply
          • richtea999 richtea999
            Spot on. See here:
            Rob Smith
            Rob Smith
            Rob Smith
            @richtea999 @Andrew Just to confirm dark mode on the phone won't make any difference at all to consumption while using Android Auto? I believe the screen on the phone is normally Off when using Android Auto
            • Tony 13
              Tony 13
              Tony 13
              Android auto in a Ford using their SYNC3, leaves the phone screen on, you have to turn it off manually.
              And does then make a difference
              • richtea999
                That sounds about right.
                There is, of course, some processing power needed for the phone to interact with the Android Auto device, but that power consumption is typically much less than lighting up the screen.
                  The power consumption depends heavily on the mapdetails.
                  In a urban area the power consumption will be higher compared to the low detail in backroad area's
                  Many direction changes causes also a higher consumption because more rendering is necessary
                  The difference in power consumption with screen on or off is little compared to the consumption when rendering
                  richtea999 1 Reply Last reply
                    @M-Schrijver Quite true - my mistake.
                    The phone still needs to do the route calculations, not the Android Auto unit, and that takes reasonable processing power (too much in HERE libraries' case).
                    • Rob Smith Rob Smith
                      Andrew
                      Andrew
                      Andrew
                      @Rob-Smith My phone screen is on maps as well as TFT screen
                      • Andrew Andrew
                        Andrew
                        Andrew
                        Andrew
                        @Andrew As I have already stated my phone finishes 250 ml route with a full charge, however lsst night I went into phone settings and found a tab for fast charging ticked this went out today and phone went down to 49% very quickly turned of fast charge and it soon went back up to 100% even using Spotify while using MRA.
                        • Andrew Andrew
                          Rob Smith
                          Rob Smith
                          Rob Smith
                          Just an observation - most people when talking about power consumption seem to be basically saying - make sure your phone is plugged into a reasonably meaty charger - that way all is well.
                          However - something like google maps navigating for you uses significantly less power than MRA. I am hoping that this extra power burn in MRA is due to the MRA dual map render(?) of the Here maps and I have read this is being worked on to reduce this.
                          To me - running an app that consumes more power than other nav apps (and as such creates device heat from processing and heat from charging) a phone (on power or off power) is not ideal, as having a phone that gets physically hot while navigating is not going to be ideal for the device. Hopefully this will fall as updates come through. Keep up the great work.
                          p.s. I am talking from my experience while using the MRA navigation via Android Auto.
                          GT JWR Con Hennekens 2 Replies Last reply
                            @Rob-Smith 👊 , 100%...well said.
                              @Rob-Smith said in Android Auto - power consumption - hot phone:
                              No, it is certainly not ideal!
                              But keep in mind by far not all phones suffer from that problem.
                              That is not how I intended any of the many comments I made 😉
                              But truth is that many people use far from ideal charging equipment, but do not realize that. I think at least a significant part of the users that see their phone's charge not keeping up with the battery use can be helped by better charger and better cable, that sustain the charging capabilities of modern phones.
                              That is however by no means an excuse for the high power consumption of the app (or better said: the HERE rendering engine).
                              Tony 13
                              Tony 13
                              Rob Smith
                              Rob Smith
                              Andrew
                              Andrew
                                2.7k
                                2.8k
                              • Altitude numbers size
                                Ed Lauwerens 0
                                Ed Lauwerens 0
                              • Seizoensafsluitingen
                              • Elektrisch voertuig
                                Arno van Lochem - Senior RX
                                846
                              • Eerste keer MRA met Android auto, een wat mindere ervaring
                              • 5 dagen Harz.. 2 problemen met AA
                                2.4k
