  4. Karte nicht sichtbar
29 Posts 11 Posters 412 Views 5 Watching
    Update for Android is available! This solves the issue that older versions were not loading maps 🙂
    Christian S. Reinhard Punz Bouke Ent Ronni 4 Replies Last reply
      Christian S.
      Christian S.
      Christian S.
      you are the best! works again on my both devices with Android 9.
      Thank you so much for quickly fixing the problem.👍
        @Christian-Schrenk we are working on some improvements regarding backwards compatibility. Expecting a beta version this week!
        Ronni
        Ronni
        Ronni
        @Corjan-Meijerink YES YES YES My old Samsung S8 with Android 9 and One UI Version 1.0 is running Again.
        Thanks a lot, Corjan.
        Greetings
        Ronni
        Samsung Galaxy A56 5G
        Android 16
        One UI Vers. 8.0
        Carpuride W712D
        Silverfox BT Cntroller H1+
          @Christian-Schrenk @Ronni thanks for the update! 🙂
            @Corjan-Meijerink, no, thank YOU for the update... 🤣
              @Con-Hennekens hahahah, thanks 😉
                Reinhard Punz
                Reinhard Punz
                Reinhard Punz
                @Corjan-Meijerink Vielen Dank, auch mein BV9100 zeigt die Karten nun wieder an! 👍
                  @Corjan-Meijerink said in Karte nicht sichtbar:
                  what is now minimum android version ? i am using samsung active 2 and get feeling support will end soon.
                    Ronni
                    Ronni
                    Ronni
                    Yeah, Yeah, Yeah,
                    Hey Superman, I've to inform you, that you have managed to bring my 7 year old Samsung bone
                    Galaxy A 320
                    on Android 8
                    with Samsung Exp. Version 9.0
                    and a "Sicherheits/security" Patch dated 01.11.2020
                    back to life.
                    He shows me the cards and navigates the routes, it takes a while, as if he can't believe what he's doing, but he does. Brilliant.
                    You saved him from the trash can and he can now let the wind blow around his nose for a little while on the handlebars.
                    Again again again (No, not Quo)
                    Thanks for your outstanding job.
                    Greetings
                    Ronni
                    Android 16
                    One UI Vers. 8.0
                    Carpuride W712D
                    Reinhard Punz
                    Reinhard Punz
                    Axel Marschel
                    Axel Marschel
                    Christian S.
                    Christian S.
                    Ronni
                    Ronni
                    Eric Minschart
                    Eric Minschart
                    • Online map settings
                      723
                      Axel Lange
                      Axel Lange
                    • In het kort......
                    • Route probleem
                    • Icons in the app differ from those in the planner
