  4. Karte nicht sichtbar
29 Posts 11 Posters 412 Views 5 Watching
    @Marschel Android 9 is not supported anymore since 2 years ago. Can I ask what phone you are using?
    @Corjan-Meijerink this subject has come up before without a resolution as far as I have seen. Is there an official statement somewhere that shows what is or is not supported?
    • Axel Marschel
      Axel Marschel
      Axel Marschel
      Hello Corjan,
      I now tested the app again on another cell phone with Android 12 and the maps were visible and everything worked.
      But why is Android version 6 or higher specified as the required operating system for this app in the Google Play Store and not a higher version?
        @RetiredWingMan as indicated by the App / Play store. If you cannot download the app, your phone is not supported.
        However, besides the specific Android version or minimum requirements there are some other demands such as graphic rendering engines (for the map). Sometimes our dependencies are updated and things break for very old devices 🙂
        @Marschel that is why the Play store indicates it can be downloaded but after downloading, a specific component shows issues. Another phone with Android 6 might work just fine.
        However, we know the issue is not strictly related to (old) Android versions. I am therefore researching the issue and hope to come up with a solution.
        Reinhard Punz 1 Reply Last reply
        • Axel Marschel
          Axel Marschel
          Axel Marschel
          Hello Corjan,
          Thanks for your quick answers.
          Then I'm probably very lucky to have an old cell phone that no longer works with the Android version.😢
          Ok, then after 7 years it's probably time for a new cell phone.😀
          • Axel Marschel Axel Marschel
            Hello Corjan,
            @Marschel After 7 years, I'd consider the phone to have served you well! 🙂
            All jokes aside, I am still researching the issue to see if we can fix the issue. It seems to have a higher chance of occurring on older devices but is not strictly limited to them 😞
              @Corjan-Meijerink thank you for looking into the issue. I use my old S7 Android 8 phone as a backup to my S20 Android 13. Cheers!
              • Axel Marschel
                Axel Marschel
                Axel Marschel
                Hello Corjan
                Now I have a new cell phone, again a Motorola, the g84 5G model with Android 13.
                The cards are now visible again😎
                Now the maps are visible again and I was able to test the navigation for the first time.
                In short, I'm thrilled and will continue testing.
                  Reinhard Punz
                  Reinhard Punz
                  Reinhard Punz
                  @Corjan-Meijerink ja, das wäre schön. Mein Blackview BV9100 ist jetzt leider auch betroffen. Vor dem 15. März 2024 hat alles normal funktioniert. Jetzt das Phänomen mit den nicht sichtbaren Karte. Android 9. Ich hoffe auf eine Lösung und, dass ich mir deshalb kein neues Handy kaufen muss.
                  Christian S. 1 Reply Last reply
                  • Reinhard Punz Reinhard Punz
                    Christian S.
                    Christian S.
                    Christian S.
                    Hallo,
                    bei mir das gleiche bei beiden Telefonen die ich rein als Navi nutze, beide Android 9.
                    Schöne Überraschung zu Saisonbeginn.
                    Kann das gefixt werden oder sind wir wirklich gezwungen, nun neue Telefone zu kaufen?
                    • Christian S. Christian S.
                      Hallo,
                      @Christian-Schrenk we are working on some improvements regarding backwards compatibility. Expecting a beta version this week!
                      Christian S. Reinhard Punz Eric Minschart RetiredWingMan Ronni 5 Replies Last reply
                        Christian S.
                        Christian S.
                        Christian S.
                        Hello Corjan,
                        thanks for the info. If there is a solution please let me know.
                          Reinhard Punz
                          Reinhard Punz
                          Reinhard Punz
                          @Corjan-Meijerink Ich habe das Update auf meinem BV9100 installiert - leider ohne Erfolg. Auch Deinstallation und neu installieren hat nicht geholfen. Cache löschen ebenfalls nicht.
                            Eric Minschart
                            Eric Minschart
                            Eric Minschart
                            Same problem here. Galaxy active tab 2, Android 9. Fully equipped on my bike with Brodit holder, Carpe Iter controller. Completely useless at the moment. Hope there wil come a solution soon. Is there a possibility to install an older version?
                            Br, Eric
                              @Corjan-Meijerink my Samsung S7 Android 8 does not show the maps.
                                Update for Android is available! This solves the issue that older versions were not loading maps 🙂
                                Christian S. Reinhard Punz Bouke Ent Ronni 4 Replies Last reply
                                  Christian S.
                                  Christian S.
                                  Christian S.
                                  you are the best! works again on my both devices with Android 9.
                                  Thank you so much for quickly fixing the problem.👍
                                    Ronni
                                    Ronni
                                    Ronni
                                    @Corjan-Meijerink YES YES YES My old Samsung S8 with Android 9 and One UI Version 1.0 is running Again.
                                    Thanks a lot, Corjan.
                                    Greetings
                                    Ronni
                                    Samsung Galaxy A56 5G
                                    Android 16
                                    One UI Vers. 8.0
                                    Carpuride W712D
                                    Silverfox BT Cntroller H1+
                                      @Christian-Schrenk @Ronni thanks for the update! 🙂
                                        @Corjan-Meijerink, no, thank YOU for the update... 🤣
                                          @Con-Hennekens hahahah, thanks 😉
                                          Reinhard Punz
                                          Reinhard Punz
                                          Axel Marschel
                                          Axel Marschel
                                          Christian S.
                                          Christian S.
                                          Ronni
                                          Ronni
                                          Eric Minschart
                                          Eric Minschart
                                          • Online map settings
                                            720
                                            Axel Lange
                                            Axel Lange
                                          • In het kort......
                                          • Route probleem
                                          • personal heat map discrepancy/ editing
