  4. Map downloads to Android
3 Posts 2 Posters 552 Views 1 Watching
  • Tony 13undefined Offline
    Tony 13
    Just trying to set up the app for navigation and use with Andoid Auto. But Screenshot_20240320_112545_One UI Home.jpg struggling a bit. First question is getting UK maps downloaded.
    I am now seeing the attached notification. This suggests that something has downloaded and something is downloading. Clicking the down arrows does not give me any information.
    I can't see anything in "downloads"?
    how do I know what i am downloading - I may have pressed several buttons because nothing seemed to be happening 😊 ?
    how can i restart downloads?
    Thanks
    Tony
    • Tony 13undefined Tony 13
      Thanks
      Tony
      @Tony-13, It's not that difficult, although I am unsure how you managed to get 2 download processes simultaneously.
      If you think Germany instead of UK you will see this if you go backj into the menu - offline maps:
      If the checkmark on the left is visible, all is okay. If not, you can klik the > to enter the UK regions. There will be a down-arrow on the right. With that you restart the download. It will take some time to index the parts you already received, but after that it will continue your download where it left off.
      In the end you will see something like this:
      Checkmarks for all regions, and only a X on the right. Don't press it, it will delete your download 😉
      Sometime a download gets stuck. In that case a force-close and restart of the download as described above will get you going again. Try to leave the phone untouched until the download is ready, and seek a spot with good wifi reception. Yes, all in all it is a bit finicky indeed...
        Tony 13
        did a force stop of the app. This time when I started the map download I got the usual style circle progress indicator 🙂 and download of Wales completed in about a minute. Thanks
        Tony 13undefined
        Tony 13
        • Updated beta! 5.2.1 (486)
          Nick Carthewundefined
        • Veekeersinfo en omleiden
          310
        • wrong routing
          ErikMatthezingundefined
          ErikMatthezing
        • Request login credentials
          Yannick_van_Vugtundefined
          Yannick_van_Vugt
