  4. Offline gpx file storage folder
19 Posts 5 Posters 5.5k Views 1 Watching
    @Corrado-Miniati-0 said in Offline gpx file storage folder:
    but my "Download" folder does not contain the MRA gpx files.
    Did you choose a GPX version from the download menu, or did you keep the default "Make available for offline use" option? The latter does not export a GPX file.
    @Nomko-Nomden said in Offline gpx file storage folder:
    Did Android showed you where the file is going to be downloaded?
    My Android also does not show where you want the file to be downloaded. It immediately goes to the systems download folder.
    Corrado Miniati 0
    Corrado Miniati 0
    Corrado Miniati 0
    I performed these operations in sequence:
    but in the system folder "Download" I can't find the gpx files.
    Con Hennekens 2 Replies Last reply
    • richtea999
      Agreed with Con - they are saved in the Internal Storage -> Download directory (on a Samsung, at least).
      The app doesn't give an option of another place to store them - it's using the default given by the operating system.
      If it's still a problem, you could try Download (successfully but you don't know where) -> Export - > Share (Apri Itinerario) -> email yourself, and then you'll have the GPX as an email attachment, and that may give you better options to save it on your phone.
      • Corrado Miniati 0 Corrado Miniati 0
        @Corrado-Miniati-0, That is strange, because for me that works as it should. However, that is not the way the get a GPX file. You should use one of these options:
        And then open the FILES app on your android phone, and go to the download folder from there (instead of the download folder within the MRA app).
        • richtea999
          Ah - Con is right again! You have to select a format.
          If you select the top one (which is just an instruction) nothing gets saved, even though the Downloads section in the app says it has downloaded.
          I'd call that a bug.
          Select GPX 1.1 or similar and I think it will work OK for you.
            @Corrado-Miniati-0, I have to correct myself...
            I now see that the downloaded GPX files are shown in the MRA app's own download folder as well:
            Did you realize that list is scrollable? you will need to scroll down, because it is sorted alphabetically.
            Pressing a GPX file gives you this:
            Pressing Open let's you choose the app in which you want to open the GPX:
            • richtea999 richtea999
              @richtea999 said in Offline gpx file storage folder:
              I don't think that's a bug 😉
              That option probably leads to an entry in an internal database instead of a file download. Just like on the webplanner.
              Corrado Miniati 0 1 Reply Last reply
                Corrado Miniati 0
                Corrado Miniati 0
                Corrado Miniati 0
                wrote on last edited by Corrado Miniati 0
                By downloading the itinerary in gpx 1.1 format it is saved both in the MRA and Android download folders and can now also be used to navigate it with other apps.
                But then what is the "make available offline" function for?
                Wouldn't it be more useful to put the download in gpx 1.1 format as the first item in the list since it is the most used one?
                In MRA can I change the file download folder and for example download to a folder named "GPX" created by me?
                Thanks a lot for the support
                richtea999 Con Hennekens 2 Replies Last reply
                  Make available offline for the app to use in offline mode (i.e. not for the user to play around with!).
                  @Con-Hennekens said in Offline gpx file storage folder:
                  Damn - he's right again. 👍
                    I don't think it is the most used one 😉
                    That option is default, because it makes the route navigationable offline with the MRA app itself. It contains more information than a GPX. Think POI notes, color and descriptions of the waypoints, navigational settings which were chosen in the planner, things like that. It is a proprietary format.
                      Haha, not always though, I had to correct myself above too 😉
                      And besides, you are often right too, and with a lot more in depth knowledge too 👍
                      • Con Hennekens
                        I think this thread should be moved to the self help forum?
                          Corrado Miniati 0
                          Corrado Miniati 0
                          Corrado Miniati 0
                          #17
                          I understand, so before a trip it is best to perform a double task to have the possibility of using other navigation apps if MRA does not work:
                          1- in MRA download the routes using the "make available offline" function because it contains more information
                          2- in MRA download the routes using the "gpx 1.1" function to find it in the Android "Download" folder and be able to use them with other apps
                          It's correct?
                          Is it possible to perform a multiple download by selecting all routes?
                          Con Hennekens Herko ter Horst 2 Replies Last reply
                            It's correct?
                            @Corrado-Miniati-0, Yes, if you want to able to use GPX for another app, it is indeed necessary to download it beforehand, but that seems quite logical, isn't it?
                            In the MRA App settings, under functional, there is an option to make routes automatically available for offline use once you start them. With that option all routes you start form the routes menu, become available for offline use immediately. My habit is that I always check routes in the app itself before leaving. Then you don't need to think about downloading them, they just appear in the downloads folder (of the MRA app).
                            Not at the moment. Instead of that it would likely be possible to program an export routine so that one can export a GPX file offline from the downloads folder. That would make it possible to make that export only on a "need to have" basis, even when you are offline. But to be honest, I don't think that this suggestion would get any priority. I guess the app at the moment is pretty "feature freezed", to be able to move development attention to the webplanner in due time.
                              It's correct?
                              Not in the app, but this functionality is available in the planner. You can select multiple routes and download them in a zip-file.
                              Corrado Miniati 0
                              Corrado Miniati 0
                                Glenn.B
                                Glenn.B
                                3.7k
                                Robineke
                                Robineke
                                225
                              • Overlay Routes like the App does and waypoints without routes
                                Rob Kelley
                                Rob Kelley
                              • How to plan correctly
                              • Brittany routes
                                Tony 13
                                Tony 13
                              • Slow Favorites
