  3. Ferry Problem
Ferry Problem
9 Posts 4 Posters 3.2k Views 1 Watching
  • Gil Yoder
    Gil Yoder
    Gil Yoder
    I have noticed a problem when a route includes a ferry using HERE routing. For example, look at the following test route:
    https://www.myrouteapp.com/route/open/3550405
    With a waypoint on either side of the ferry, HERE creates a route that bypasses the ferry in favor of a much longer circuitous route. A workaround is to select Toolkit/Avoid/Highways, but that is not a good solution if you don't want to avoid highways.
    The problem does not occur with either Tomtom or OpenStreetMap routing.
    I haven't checked to see if this occurs within the navigation app.
    If this is a problem with HERE routing, it probably exists within the navigation app.
    How can this be elevated for Garmin to check?
    Gil
    "Be patient and understanding. Life is too short to be vengeful or malicious."
    – Phillips Brooks
    Nick Carthew 2 Replies Last reply
    • Gil Yoder Gil Yoder
      Gil
      @Gil-Yoder Place a route point on either side of the crossing and then use ‘skip’ on the route point on the far side of the crossing. This draws a straight line and effectively turns navigation off to stop re-routing.
      Gil Yoder De Vree 0 2 Replies Last reply
        Gil
          Gil Yoder
          Gil Yoder
          Gil Yoder
          @Nick-Carthew Skip works fine in the web app, but it doesn't help in the Navigation app. When the route is loaded in the Navigation app, the route is recalculated without the skip.
          And the Nav app behaves the same as the web app. The ferry is avoided unless "Avoid highways" is enabled.
          Working this out in my head, I guess the thing to do is to use skip to include the ferry when "Avoid highways" is disabled, complete your route with expanded waypoints to force routing on highways, and then enabled "Avoid highways" in the nav app to include the ferry.
          That's kind of convoluted, but I think it would work.
          – Phillips Brooks
            @Gil-Yoder I haven’t tested the Nav app for this, but I’ll set up a test route and report back with my findings.
              @Gil-Yoder The Nav app should take you to the ferry, ignore it if it tries to re-route you. It should then re-calculate when you arrive on the other side.
              Gil Yoder 1 Reply Last reply
                Gil Yoder
                Gil Yoder
                Gil Yoder
                wrote on last edited by Gil Yoder
                @Nick-Carthew
                @Nick-Carthew said in Ferry Problem:
                This makes sense, Nick. Thank you for your help.
                – Phillips Brooks
                  De Vree 0
                  De Vree 0
                  De Vree 0
                  @Nick-Carthew Top !
                  • Leike Lodiers
                    set the transport mode from motor to car this sometimes help to.
                    De Vree 0
                    De Vree 0
                    Gil Yoder
                    Gil Yoder
                      135
                    • Beta abonnement
                      BMW1300GSA
                      BMW1300GSA
                    • SilverFox Controller C2
                      Hans Lamers
                      Hans Lamers
                    • Add PDF printing
                    • "Please verify your email" display
                    • Layers menu: option to permanently display Favorite labels
