  3. [App] Announcements
  4. New update! (4.0.8)
New update! (4.0.8)
57 Posts 16 Posters 41.2k Views 7 Watching
    @Hans-Lamers misleading. As far as the phone is concerned, the output of the charger/adaptor is 5V at a max of 3 amps = 15 w. I hope my recently purchased Quadlock wireless charger does better than yours. I purchased the 15w version that needs to be direct wired to a 12v source rather than plugging into a USB port. I have also found that the quality of the USB cable can seriously affect charging rates. Keep cables as short as possible.
    Dikke Wim
    Dikke Wim
    Dikke Wim
    #26
    @Doug-Robinson
    My Quadlock wireless charger also cannot keep up with the drainage of battery while using MRA. I'm using an iPhone 13 Pro Max.
    Thanks for the tip to look into the charging cable!
    • Dikke Wim Dikke Wim
      @Doug-Robinson
      @Dikke-Wim :
      I use an iPhone Xr in the BMW cradle, which fits well. I haven't had any battery problems so far and everything was great for the whole day, even on a longer tour.
      There were several apps open...
      Ich nutze ein iPhone Xr im BMW Cradel, das passt gut. Ich hatte bis jetzt keine Akku Probleme und auch bei einer längeren Toure für den ganzen Tag alles Top.
      Es waren mehre Apps geöffnet, …
        @Dikke-Wim :
        @Hubert-Thoring
        I think the BMW cradle supplies more power than the Quadlock or SP connect.
        Edwin_M 1 Reply Last reply
          @Hubert-Thoring
          Edwin_M
          Edwin_M
          Edwin_M
          #29
          I did some additional testing and I must say that I am dissapointed in the performance of the Quadlock Wireless Charger (with USB connection). It is a very expensive accessory and it is advertised to reach up to 10W with Galaxy devices. (using a good power supply ofcourse).
          And yes the power drain of the MRA next app is still on the high side.
          In short , the wireless charger does not exceed 6W of power supply in my tests.
          Phone is an S24+ .
          Case is a Quadlock Mag Case
          I have the USB connection version of the Wireless charging head. combined with the Motorcycle - Waterproof 12V To USB Smart Adaptor - Quad Lock® Europe - Official Store (quadlockcase.eu)
          I did some testing:
          1. Checked on phone: Turned of battery protection and checked all battery fast charging options are on. Used an additional quality USB-A to USB-C cable to test (otherwise I'll need to get a lot of covers of of my motorcycle) all fast charge options are enabled
          2. Without Quadlock: tested directly on the a charger : outcomes: On an USB-A output max 2,4A => 7 W charging second USB-A output with a QC3.0 => 12,5 W.
            3, Quadlock hardware test: used the same cable wired directly on the 12V Quadlock convertor => 12 W
          3. Quadlock hardware test: used the same cable from the 12V quadlock convertor to the wireless head = 6W
          4. Quadlock wireless charging head connected to wall charger (as in bullet 2): 1. on QC3.0 port => 6W max via charging head second on normal port max 2,4A resulting in 3,4W max via charging head
          response of Quadlock on results:
          *Our wireless charging head has advertising on our product page to charge at a maximum of 10W, as yours is charging at 5W it still sitting with the expected performance.
          Just to note that you will always have a faster charging speed using a cable as this is not surprising because we can't expect the wireless charge to perform the same.*
          The latter is obvious. But losing 6W over the wireless charging head is dissapointing to say the least.
          (i found that , with a 100 km roundtour, first edit in Routeplanner online) using it as a route from that to navigate with and using Dark mode, the phone was able to charge. In light mode , the drain is too big at the moment.
          Also must state that I am always using Flitsmeister AND youtube music in background as well;
          • Flat Twin Therapy
            Flat Twin Therapy
            Flat Twin Therapy
            While it might be true or not that Quadlock does not charge as advertised, it still does charge my phone when navigating using another app like Waze and Google Maps, and MRA is draining the battery.
            Also, the charger in my car (USB outlet in dashboard / not quadlock) does charge the battery when navigating with other apps, while the battery drains when using MRA.
            (Android)
            Since January 2024 I started recording some of my rides commuting and touring the R1200RT in The Netherlands:
            https://youtube.com/@FlatTwinTherapy
            Edwin_M Dikke Wim 2 Replies Last reply
            • Flat Twin Therapy Flat Twin Therapy
              (Android)
              Edwin_M
              Edwin_M
              Edwin_M
              @Flat-Twin-Therapy agree
              • richtea999
                #32
                @Edwin_M said in New update! (4.0.8):
                ...I found that ... using it as a route from that to navigate with and using Dark mode, the phone was able to charge. In light mode , the drain is too big at the moment.
                Not to allow HERE off the hook, but Dark mode is a good work-around until they pull their finger out and fix the problem for MRA.
                It works for me, and will decrease battery usage on any phone with an OLED / AMOLED display, because they require power to light each pixel (rather than having a screen-wide backlight).
                • Edwin_M Edwin_M
                  Phone is an S24+ .
                  I did some testing:
                  @Edwin_M what app are you using to measure/monitor the charging power?
                    Edwin_M
                    Edwin_M
                    Edwin_M
                    @Doug-Robinson accubattery
                      (Android)
                      Dikke Wim
                      Dikke Wim
                      Dikke Wim
                      #35
                      @Flat-Twin-Therapy
                      Besides the fact that the Quadlock wireless charges is not "strong" enough, some smartphones may stop charging because of a tempertaure that becomes too high as a result of all the calculations MyRoute has to do. See below:
                      • Jörgen
                        #36
                        Just for information, with my Oukitel outdoor tablet I noticed that changing the USB charging cable it fixed the battery loading problem. The first cable did not supply enough power. First, I thought the 12/5V converter was the issue, but it was the cable.
                        Anyway, has someone tried to see if Here's own navigation app has the same issue with power consumption?
                        • Jörgen Jörgen
                          Edwin_M
                          Edwin_M
                          Edwin_M
                          @Jörgen https://forum.myrouteapp.com/post/33259
                            @Flat-Twin-Therapy no offence taken!
                            It bothers me probably the most as not only user but also as person responsible for the technical stability / usability of the app.
                            I have a meeting with HERE development next week in which they will update me on their progress 🙂
                            Edwin_M
                            Edwin_M
                            Edwin_M
                            @Corjan-Meijerink any Update/progress from the meeting with HERE?
                            • Ton Verkleij
                              Ton Verkleij
                              Ton Verkleij
                              Hello,
                              I would like to see the operation of the app completely independant from the smartphone, making it a real standalone app on Android whereas using it on Android auto I do not have to use smartphone at all.
                              richtea999 1 Reply Last reply
                              • Ton Verkleij Ton Verkleij
                                Hello,
                                #40
                                @Ton-Verkleij said in New update! (4.0.8):
                                Hello,
                                I'm pretty sure Android Auto needs a smartphone to work. How were you hoping to install the app? (unless your vehicle's head unit is really a smartphone/tablet in disguise)
                                Ton Verkleij 1 Reply Last reply
                                • richtea999 richtea999
                                  Hello,
                                  Ton Verkleij
                                  Ton Verkleij
                                  Ton Verkleij
                                  @richtea999 I will be using the app via Android Auto on the Chigee IO5-lite device.
                                  https://www.chigee.com/collections/aio-5-lite/products/aio5-lite
                                  MotoCon richtea999 2 Replies Last reply
                                    @Ton-Verkleij, how is using the app via Android Auto ever going to be smartphone independant...?
                                    Dae 0 1 Reply Last reply
                                      @Ton-Verkleij The Chigee looks good, Ton, but only for certain predefined features. It does have a GPS module, so in theory it might be possible for MRA to supply Chigee with a build that runs standalone, but to be honest, it's a market of 1 versus 20k different models of Android devices.
                                      You're asking for the Chigee to be become a satnav as well as everything else, but all the satnav downsides would come with that, i.e.:
                                      • infrequent updates to functionality, if any
                                      • you're tied in to Chigee's satnav design - no swapping devices
                                      • when it busts you have to buy another one, which will include paying for the new satnav 'module' again.
                                        Dae 0
                                        Dae 0
                                        Dae 0
                                        @Con-Hennekens said in New update! (4.0.8):
                                        Maybe Ton is confusing Android Auto with Android Automotive.
                                        My car, a Polestar, runs Android Automotive and doesn’t offer Android Auto. You install the apps on the car, not your phone. Since the car doesn’t so Android Auto, you can’t use MRA unless you’re an iPhone user (the car does support CarPlay).
                                        MotoCon Corjan Meijerink 2 Replies Last reply
                                        • Dae 0 Dae 0
                                          @Dae-0, A dedicated Android native head-end for motorbikes would be really great. But if the AIO can install apps, they do a really great job hiding that info on their website ;-). Integration with dashcams is great though!
                                          Edwin_M
                                          Edwin_M
                                          Hans Lamers
                                          Hans Lamers
                                          Dikke Wim
                                          Dikke Wim
                                          Dae 0
                                          Dae 0
                                          Lynchy67
                                          Lynchy67
                                          Ton Verkleij
                                          Ton Verkleij
                                          Flat Twin Therapy
                                          Flat Twin Therapy
                                          • Kaart niet zichtbaar
                                            222
                                          • Route omzetten naar een track
                                            Jeroen ekkel c
                                            Jeroen ekkel c
                                          • Xpert overlay not clear
                                            Corrado Miniati 0
                                            Corrado Miniati 0
                                          • Trains like Ferries?
                                            Corrado Miniati 0
                                            Corrado Miniati 0
                                          • Current city/village name instead of the street name
                                            Hanza 0
                                            Hanza 0
                                          • Vermijdingsopties is wat verwarrend
                                            Eric Bovelander
                                            Eric Bovelander
                                          • Ansicht im Querformat
