  4. Duplicate Route inside editor
6 Posts 4 Posters 1.5k Views 1 Watching
  • Lluis Arasanz Offline
    Hi all,
    I apologize If commented before.
    Route editor ALWAYS save modified waypoints when exiting editor. This is good.
    But sometimes I need to change working route to have 2 similar versions for modified routing, This is done by:
    • Exit route planner
    • Locate route
    • Duplicate and rename
    • Enter again in route planer to modify.
    Perhaps, is possible to put "duplicate" or a "save route as" button near "rename" button on route planner?
    to something similar to:
    This can be used also to have a backup before make changes.
    Best Regards
    • BMW F750GS
    • Lluis Arasanz Lluis Arasanz
      Hi all,
      • Locate route
      Best Regards
      Jack van Tilburg Offline
      Jack van Tilburg
      @Lluis-Arasanz
      To be honest, I find the existing copy function of the personal route library sufficiently functional. When editing routes, I almost always make a working copy in advance and see no added value in your proposal.
      Thomas s Con Hennekens 2 Replies Last reply
        @Lluis-Arasanz
        Thomas s Offline
        Thomas s Offline
        Thomas s
        @Jack-van-Tilburg Hi Jack, your approach working with MyRouteApp is different from Luis'. And I do agree to Luis request.
          @Lluis-Arasanz
          @Jack-van-Tilburg, "sufficiently functional" it is, but that does not equal "not subject to improvement" 😉 I think it is a good idea. Do you copy and rename your Word (or whatever) documents before opening them, or do you open a document and then "save as" with a different name?
            Jack van Tilburg
            (back when I was still working 🙂 )When I was still writing documents, 'life' incrementals were made.
            Now when I create a document (or whatever) I start with a right mouse click -> duplicate and work with the copy.
              @Jack-van-Tilburg, I guess your IT service was very happy to increase storage space every now and then 😉 Nowadays we have versioning built in to filesystems. But anyhow: I think adding a small symbol to "save as" can make some people happy and it does not intervene with your methods.
              Jack van Tilburg
              Jack van Tilburg
              Thomas s
              Thomas s
                459
              • POI naming/text display
              • Stemgeluid sterker bij afspelen muziek
              • MRA groups
                Steve Standing
                Steve Standing
              • Onbegrijpelijke afslagen
              • GPX1.2 & Garmin Tread
                MTC-Zeilberg
                MTC-Zeilberg
              • Folders that can store tracks and waypoints
                martin-phogel.de
                martin-phogel.de
