  4. Ben niet blij met de nieuwe HERE kaart!
30 Posts 10 Posters 13.4k Views 4 Watching
  • Mopetenpit Mopetenpit
    @Con-Hennekens said in Ben niet blij met de nieuwe HERE kaart!:
    Move your WP's to the corresponding black dots. If you do that, your WP is correct ON the HERE map. No matter the layer you use.
    Yes, I am familiar with this procedure and I do it the same way. My actual question is: Which X-Y coordinates are in the GPX files? The coordinates for the blue route points or those for the small black ones on the route? Can you answer that?
    @Mopetenpit I don't think the black dots are actually anything "real", I think that's just a display artefact of two semi-transparent line-segments overlapping slightly.
    A GPX file can contain both a route (basically a list of waypoints) and a track (lots of "points" based on a calculated or recorded route).
    The waypoints (blue) you place on the map will be in the GPX as part of the route. If you use a GPX-format that also contains a track, it will contain coordinates of many "points", enough to exactly represent the black line that's been calculated (in this case using HERE).
    So in a sense, both the blue points and the "black points" will be in the GPX. If your navigation device/app uses the route, it will use the blue waypoints to calculate a route on the device, which may differ from the line you see in the planner (and the black points/lines do not matter). If your device/app uses the track, it will just use that (and the blue waypoints don't matter).
    • CD130
      Zo te zien loopt de nieuwe HERE layout ook niet overeen met de daadwerkelijke route gemaakt in HERE… Dat is toch wel een beetje vreemd…
      Hier een voorbeeld
      Herko ter Horst Dwars 2 Replies Last reply
      • CD130 CD130
        Hier een voorbeeld
        @CD130 Heel vreemd inderdaad. Aantal situaties bij mij in de buurt geprobeerd en daar loopt de route gewoon netjes over de kaart.
        Jouw stukje route loopt op geen enkele kaartlaag correct (met HERE als onderlaag), dus wat daar aan de hand is...
          @Mopetenpit, That is an intriguing question... 😉
          I am quite confident that the stored coordinate is the one that represents the WP and not the black dot. That is easily argumented, because the WP comes back at the same place when exporting and re-importing a GPX file. The black dot is a calculated coordinate that fixes the WP coordinate to a routable road.
          However: because I hate to talk bullshit I actually exported a GPX file to check if not also the black dot coordinate is present in the file.
          Each WP seems to be represented by a single coordinate in the route data of the GPX file, but I had some trouble recognizing it. It seems the coordinate in the file has a lot more digits than the ones shown in the WP info in the planner 😉 (red oval)
          If you look at the Track information in the same file you can see that the first coordinate (green circle) is not equal (besides that LATitude and LONgitude have been flipped? Why...). This is quite logical, since the breadcrum over the routeline is represented, and not the waypoints. I think for at least the first and the last WP of a route the track-coordinate will be exactly the black dot. How the breadcrums in between these point are calculated, I have no idea. But for the start en endpoint I checked them in Google maps and they seem to correspond. Just flip LAT and LON, else you will and up somewhere off the coast of Somalia... 🤣
            @Con-Hennekens Lat and Lon aren't actually flipped, just the order in which they happen to be present in the file differs from the routepoint to the trackpoint. For both, lat is still 51.x, while lon is 5.x, so no we're not in Somalia.
            And like I said, I don't think there's a black dot at all, just the overlap of two semi-transparent lines. There's no "black dot" at the start of the line.
              @Herko-ter-Horst said in Ben niet blij met de nieuwe HERE kaart!:
              Ik verdenk hem ervan dat hij toch stiekem buiten de gebaande paden heeft gereden 😉
              Mopetenpit 1 Reply Last reply
                Mopetenpit
                Mopetenpit
                Mopetenpit
                @Con-Hennekens @Herko-ter-Horst @Rob-Verhoeff @CD130
                Thank you for the detailed answer to my question! 👍
                  Yes of course, the position is flipped. But if you copy the coordinate and paste it in GMaps, remove the non-numbers, of course that will lead to flipped coordinates. But I meant nothing else than that their positions in the file where flipped of course (would be something if it wasn't 😉 )
                  You are quite right, but there where line segments overlap we see a.... 😉 They still represent the coordinate of a waypoint that is transposed to the actual road.
                    @Dwars Dan kan je jezelf nog steeds trakteren op een andere kaart. Selecteer simpel een andere overlay (Michelin, OSM of TomTom) en je kan helemaal los met alle kleurtjes. De hoofdkaart voor de route berekening is dan nog steeds Here (TT of OSM). En aan de wandelpaden of onverharde wegen heb je toch al niets in de Here-kaart omdat de meeste simpelweg ontbreken en de navigatie over dat soort wegverharding niet wordt ondersteund.
                    Christian Zondag
                    Christian Zondag
                    Christian Zondag
                    @Rob-Verhoeff ik denk dat Dwars bedoeld in de Navigation omgeving.
                    zou mooi zijn als we zouden kunnen rijden op de OSM kaart maar dat gaat niet voor zover ik weet.
                    Dwars 1 Reply Last reply
                    • Christian Zondag Christian Zondag
                      Dwars
                      Dwars
                      Dwars
                      @Christian-Zondag
                      Nee Rob, je hebt het mis!
                      Dwars bedoelt de gewone routekaart van HERE die eerst hartstikke duidelijk was maar waarvan nu alle wegen groot of klein dezelfde kleur hebben.
                      En ik weet dat je daar dan een andere kaart over kunt leggen of wat ik hier boven ook al gelezen heb dat ik dan de waypoints op de zwarte puntjes moet zetten.
                      Het gaat om de topografische kaart en niet de Navigation kaart.
                      • Dwars Dwars
                        @Christian-Zondag
                        #19
                        @Dwars said in Ben niet blij met de nieuwe HERE kaart!:
                        Dwars bedoelt... etc.
                        Je bedoelt denk ik @Christian-Zondag 😉
                        • CD130 CD130
                          Hier een voorbeeld
                          Dwars
                          Dwars
                          Dwars
                          @CD130 Bij mij hetzelfde!
                          Helmut Müller 1 Reply Last reply
                          • CD130 CD130 referenced this topic on
                          • Dwars Dwars
                            Helmut Müller
                            Helmut Müller
                            Helmut Müller
                            @Dwars
                            Hallo,
                            ich finde das neue Karten Farbbild bei HERE leider auch "mißlungen".
                            Ich plane meine Routen alle am PC mit MRA und das
                            alte Kartendesign war von der farblichen Darstellung hierfür
                            perfekt.
                            Die unterschiedlichen Straßen waren super zu erkennen und auch farblich unterschiedlich.
                            Jetzt sind alle Straßen grau und unterscheiden sich nur in der
                            Breite. Dazu sind sie noch auf dem blassen Untergrund
                            schwer zu erkennen.
                            Es wäre eine gute Sache, wenn zu den vorhandenen Karten auch noch das "alte" Here Kartendesign zur Verfügung steht.
                            Hinzu kommt ja auch noch , das auf meinem Navi auch das
                            alte Kartendesign angezeigt wird.
                            Ich glaube auch nicht, das bei meinem Garmin Navi beim nächsten
                            Update euer neues Kartenlayout erscheint.
                            Also wird es die alte HERE Karte weiter geben, eben nur nicht
                            bei MRA.
                            In der APP ist es ja auch möglich, die Karte HERE "Gold" zu
                            wählen.
                            Die alte HERE Karte wird also nicht vom Markt verschwinden.
                            Was wäre das für ein Chaos, wenn Papier Karten ein solches Kartenbild bekämen.
                            Wer soll da noch den richtigen Weg finden.
                            Leider verliert MRA durch die Umstellung an viel Interesse und
                            Attraktivität für die Anwender.
                            Ich glaube, die Entwickler haben noch nie selbst eine Touren-
                            planung gemacht.
                            Auch wenn das alte HERE nicht weiter gepflegt würde, könnte man es doch als Karte erhalten.
                            MotoCon Rob Verhoeff Dwars 3 Replies Last reply
                            • Helmut Müller Helmut Müller
                              @Dwars
                              Hallo,
                              perfekt.
                              schwer zu erkennen.
                              bei MRA.
                              wählen.
                              planung gemacht.
                              @Helmut-Müller said in Ben niet blij met de nieuwe HERE kaart!:
                              planung gemacht.
                              And now seriously: There is a difference between the HERE maps from HERE and the HERE maps from Garmin. Garmin adds their own details on a seperate (probably self-hosted) platform. MRA makes use of the fixed HERE platform. I agree with you that the new map-style lacks detail (to be honest, I thought likewise about the old style HERE map). Luckily we have maplayers for this. And hopefully HERE will turn on their design decisions. I don't think it is much in MRAs hands.
                                @Dwars
                                Hallo,
                                perfekt.
                                schwer zu erkennen.
                                bei MRA.
                                wählen.
                                planung gemacht.
                                planung gemacht.
                                Are you serious? 🤣
                                  planung gemacht.
                                  Are you serious? 🤣
                                  Helmut Müller
                                  Helmut Müller
                                  Helmut Müller
                                  @Rob-Verhoeff
                                  und wie !
                                  Es geht nicht um die Planung von A nach B.
                                  Es geht um die sehr detailierte Planung von Touren anhand
                                  der Karte. Dabei muß ich erkennen können, ob es ein Weg oder eine Straße ist.Und sie muß auch als solches zu erkennen sein.
                                  Vergleiche doch nur mal die Michelin Karte mit der Here.
                                  Da bedarf es dann schon keiner weiteren Erklärung
                                  VG
                                  Rob Verhoeff MotoCon Helmut Müller 3 Replies Last reply
                                    @Rob-Verhoeff
                                    und wie !
                                    VG
                                    @Helmut-Müller Let me put it delicately... the lead developer may not be that old, but he knows a whole lot about planning routes!
                                      @Dwars
                                      Hallo,
                                      perfekt.
                                      schwer zu erkennen.
                                      bei MRA.
                                      wählen.
                                      planung gemacht.
                                      Dwars
                                      Dwars
                                      Dwars
                                      @Helmut-Müller 👍 👍 👍 👍
                                        @Rob-Verhoeff
                                        und wie !
                                        VG
                                        Apparently it does need some extra explanation:
                                        You can activate the Michelin map-overlay on top of the HERE map.
                                        That is an very welcome feature, programmed by the developer, who very well knows what it takes to plan routes...
                                        Drabslab 1 Reply Last reply
                                          All very true, but it does not change that HERE (on which MRA is totally dependent) seems not to be an entirely satisfactory product.
                                          Just look how many negative posts there are about Here, not to mention the battery drain issue
                                          Mopetenpit
                                          Mopetenpit
                                          Christian Zondag
                                          Christian Zondag
                                          Helmut Müller
                                          Helmut Müller
                                          Dwars
                                          Dwars
                                            153
                                            Ruud Bijkerk
                                            Ruud Bijkerk
                                          • Route exporteren uit beta
                                            Johan 5q
                                            Johan 5q
                                            126
                                          • iPad - zooming out
                                            Big Al 1
                                            Big Al 1
                                          • Website update - Trip book PDF, route lock for collaborators, a close button in the planner and more
                                          • Startpunt wijzigen
