  4. no internet but.....
13 Posts 4 Posters 3.4k Views 2 Watching
  • Fred Gilbert Fred Gilbert
    Lets say you are faced with a major road closure. You are in the middle of nowhere without internet. You have the offline maps for the region you are in. It Should be possible to start a new route and save it to the phone and use offline maps. I had just enough intermittent internet to open the app but still couldn't make the route.
    @Fred-Gilbert, If you want to enter a destination without an internet connection, you need to put your app in Offline mode first.
    Fred Gilbert 1 Reply Last reply
      Fred Gilbert
      Fred Gilbert
      Fred Gilbert
      yes, of course.
      Now if I could just prevent the app from turning "offline" off when I'm not looking!
        yes, of course.
        Fred Gilbert
        Fred Gilbert
        Fred Gilbert
        @Fred-Gilbert
        Now I remember, the problem was that I could not create a new route from route lab while (no internet) offline. I was thinking if I could start a blank route & save it to the phone I should be able with "offline maps" to finish making the route.
          @Fred-Gilbert
          Fred Gilbert
          Fred Gilbert
          Fred Gilbert
          This post is deleted!
            Fred Gilbert
            Fred Gilbert
            Fred Gilbert
              Fred Gilbert
              Fred Gilbert
              Fred Gilbert
              @Fred-Gilbert The way I see it, you have to think like a developer to use this app effectively. I was having a problem zooming in to a map while offline. I went to "map folder" and discovered that none of the maps I had previously downloaded were present.
              Con Hennekens 2 Replies Last reply
                @Fred-Gilbert, You can not use route lab without internet connection. It is a WEB planner 😉 The button in the app opens an embedded browser view to the website. Im am not a developer, and I think most customers are not 😉
                You can however set a destination by address, company name or favorite using the looking glass, also in offline mode.
                  @Fred-Gilbert said in no internet but.....:
                  Where did you find this "map folder"? Has it at all something to do with the MRA app? I have been looking for the mapdata myself some time ago, and could not find it quickly enough.
                    Fred Gilbert
                    Fred Gilbert
                    Fred Gilbert
                    I was referring to the settings section listing available offline maps.
                    I had a number off maps that had disappeared. I assumed that if there was no "X" next to them, it meant there was nothing there.
                    Con Hennekens RetiredWingMan 2 Replies Last reply
                      @Fred-Gilbert, ah, that explains. Do you have your maps written to an SD card by any chance?
                        @Fred-Gilbert there was a Here update a month or so ago that required an update and all previous downloads were removed.
                        Fred Gilbert
                        Fred Gilbert
                          396
                        • test Myroute APP
                          1.7k
                          LE DIZES Freddy
                          LE DIZES Freddy
                          7.5k
                          576
                        • How to plan correctly
                          Erdna
                          Erdna
                          442
                          Hubert Thori
                          Hubert Thori
                        • Tour results and a question
