  4. Save a different version
4 Posts 2 Posters 1.2k Views 1 Watching
  • Ron Block
    Ron Block
    Ron Block
    Hi! I have a very detailed trip planned out and I would like to use most of the waypoints and notes already added but make subtle changes if I decide to change the route. Is there a way to copy the current version, then edit the copy under a new name? Thank you!
    • Ron Block Ron Block
      @Ron-Block
      In your library at the right side of the page.
      New users Corner
      Ron Block 1 Reply Last reply
      • TorqueRider TorqueRider
        @Ron-Block
        New users Corner
        Ron Block
        Ron Block
        Ron Block
        @Jack-van-Tilburg Thank you! The menu is different on mine. I had to click the 3 dots then go to the bottom and click more options to get to the copy option.
          @Ron-Block
          Which can. It depends on your screen resolution.
          But you found it.
          Ron Block
          Ron Block
            973
            779
          • prestaties en badges
            De Keyser
            De Keyser
          • Search help needed
            631
          • Any tip on "renumbering" many WP when adapting a file?
