Zoom on the menu
Is it possible to implement zoom on the menu to enlarge the writing?
When traveling there are not always favorable conditions for being able to read the small print. -
When traveling there are not always favorable conditions for being able to read the small print.@Corrado-Miniati-0 iOS has a feature to magnify your screen, tucked away in the settings. The text in the app is not scalable. I have no idea which platform you're using, but I guess that Android also has something similar. In iOS, you need to tap your screen with three fingers (if you have it set up that way), and then you can zoom in on text, images, etc.
@Rob-Verhoeff
Thanks Rob, I found a system for Android to zoom in with a triple tap on the screen.
