  4. Message to stop navigation
9 Posts 5 Posters 1.6k Views 3 Watching
  • Corrado Miniati 0 Offline
    Corrado Miniati 0
    Sometimes it happened to me that without activating the device, the wording "stop navigation - Confirm?" appears.
    Why does this happen?
    Thanks a lot
    • Corrado Miniati 0 Corrado Miniati 0
      Thanks a lot
      Rob Verhoeff Offline
      @Corrado-Miniati-0 How did you mount your phone? Is it possible that vibrations are causing something to be activated, making your phone think you've pressed a button?
      Corrado Miniati 0 1 Reply Last reply
        Corrado Miniati 0
        Hi Rob, thanks for the feedback.
        The tablet is mounted on a sturdy RAM arm, it works very well.
        This is the first time this has happened to me, I don't think it depends on the vibrations.
          RetiredWingMan Offline
          @Corrado-Miniati-0 I don't like the Ram mount because the arms tend to interfere with the side buttons, I've changed to the Quadlock with vibration dampner. It works much better and I can switch easily between portrait and landscape. As for your issue, it is likely that something has initiated closing the app.
            Corrado Miniati 0
            @Doug-Robinson
            Hi Douglas and thanks for feedback, I use an 8" tablet and can't use the quadlock mount.
            The tablet's RAM cradle does not hide any buttons and you can activate whatever you want.
            Something definitely started the browsing shutdown, I'd like to find out the cause.
            • Corjan Meijerink Online
              The only cause is you pressing stop navigation or the Android back button. Most likely the last happened due to vibrations / the mount 🙂
                Corrado Miniati 0
                Hi Corjan,
                I didn't touch any buttons because I was driving but the road was perfectly paved and there were no vibrations.
                It's the first time this has happened, on other roads with much more vibrations it had never happened, very strange....
                  Hi Corjan,
                  @Corrado-Miniati-0, Like with your flyer symbol going off screen, this could be due to a dirty screen. Clean it thoroughly. A defect hardware back key could indeed also be the problem.
                    Corrado Miniati 0
                    thanks a lot, i will try to clean it.
                    Corrado Miniati 0
                    Corrado Miniati 0
                      298
                    • Google maps and Streetview
                      Stevedo 6 0
                      Stevedo 6 0
                      825
                      siebo vd berg
                      siebo vd berg
                      543
                    • Transport modes?
                    • New Zealand Routes
