  4. BMW connected navigator does not work with MRA GPX files,
23 Posts 9 Posters 12.9k Views 1 Watching
    @Håkan-Ohlström
    Just updated the BMW ConnectedRide Navigator. Create a route in the MRA planner, use the TomTom map, make sure the route points are on the road. Save the route as gpx 1.1 on your PC. Then copy and paste the gpx file of your route into the "Routes" folder on the BMW ConnectedRide Navigator.
    Then go to Navigation, then start, then click on the 3 dots in the top right corner and click on import, the route you just placed in the "Routes folder" will be imported into the BMW ConnectedRide Navigator.
    Now first drive a route to see how the ConnectedRide Navigator behaves with regard to the route points.
    To be continued...
    @Hans-van-de-Ven-MRA-Master
    I understood that the BMW Motorrad Connected app on the smartphone automatically synchronizes with the ConnectedRide Navigator if you use a BMW ID.
    Have you tried that yet?
    I use the MRA App to export routes directly in the BMW Motorrad Connected app.
    So no hassle with cables and copy and paste.
    • TorqueRider TorqueRider
      @Jack-van-Tilburg
      Tried it, but no result
      Raymond Bayol TorqueRider 2 Replies Last reply
        @Jack-van-Tilburg
        Raymond Bayol
        Raymond Bayol
        Raymond Bayol
        @Hans-van-de-Ven-MRA-Master Hello, i have find the solution.
        At first make your way on your computer and when y've finished, close it (don't export, just close).
        On your cellphone, open MyRoute and go to "itineraire", find the way and select "export", choose .gpx 1.0, download and after choose export, choose Connected BMW and in connected, you have 2 choices, you must choose the track with the more points and after select import.
        You find your way in track importation.
        HABVEN aka MrMRA Simon Gentilli 2 Replies Last reply
          @Jack-van-Tilburg
          That's sad. Synchronization is one of the features that BMW promotes.
          HABVEN aka MrMRA 2 Replies Last reply
          • Raymond Bayol Raymond Bayol
            @Raymond-Bayol
            I did all that, the gpx file is added in the connected app, but not in the connectedRide Navigator.
            The connected ride navigator can handle routes with routepoints, so I don’t use the track
              @Jack-van-Tilburg
              Still testing….
                @Jack-van-Tilburg
                Still testing….
                Did a test drive today, 30KM, 14 training points and 3 via points in the route. Route saved as a gpx 1.1 file and placed from the downloads folder on my PC in the routes folder on the Navigator. You can then import these routes via the Navigation menu. A route and track file is imported. Started the route and drove the route without deviations.
                2nd picture the planned route, first picture the recorded track placed over the route.
                Now I just have to figure out whether the route can also be displayed in the navigator via the connected app and how I get the via points on the screen, perhaps save them as POI..
                  @Jack-van-Tilburg
                  Logged in again to the Connected app, so that it was linked again and voila, the routes can be downloaded to the navigator via the app.
                  So, if you use MyRoute-app, then: Plan a route in MRA, via the MRA app, export the route to the connected app.
                    @Jack-van-Tilburg
                    I have an RT and therefore use the TFT for navigation.
                    The export function from MRA to BMW Connected is absolutely fantastic and easy to use (experience since '21)
                    • Mark Jaffe
                      Mark Jaffe
                      Mark Jaffe
                      I am not having an issue importing GPX files to the Connected ride navigator but i cant seem to get it to see the way points in the gpx file. they import as supported points and therefore you cant skip them as they are not way points. any ideas
                      • TorqueRider
                        @Mark-Jaffe
                        Maybe you get more information about this when you reed this topic
                        MRA and the BMW Connected App
                        • Tony Baker
                          Tony Baker
                          Tony Baker
                          I have had no issue exporting routes to the BMW Navigator app. However, it is totally useless if you venture off road as the BMW app does nor recognise tracks and will start recalculating. I am just using the MRA app now on carplay with my phone mounted where my NAV 6 used to be. I am going to try the chigee CarPlay screen but it is only 5", if only they made a 7 or 8" version.
                          • Håkan Ohlström Håkan Ohlström
                            Unable to export MRA gpx files to connected ride navigator, what to do?
                            Best regards
                            Håkan Ohlström
                            Terry Weller
                            Terry Weller
                            Terry Weller
                            @Håkan-Ohlström
                            I find that if I export my route to OneDrive I can then import it into BMW Connect app and it will work.
                            • Terry Weller Terry Weller
                              @Håkan-Ohlström
                              @Terry-Weller
                              You can export the route directly to the connected app via the app
                                Simon Gentilli
                                Simon Gentilli
                                Simon Gentilli
                                @Raymond-Bayol that works for me too. I have used a dedicated phone for the bike, a Pixel 5, which seems to work better than my regular iPhone, it also fits in the cubbyhole on my 1250rt more easily
                                • HABVEN aka MrMRA HABVEN aka MrMRA locked this topic on
                                MTC-Zeilberg
                                MTC-Zeilberg
                                Simon Gentilli
                                Simon Gentilli
                                Terry Weller
                                Terry Weller
                                Tony Baker
                                Tony Baker
                                Mark Jaffe
                                Mark Jaffe
                                Raymond Bayol
                                Raymond Bayol
                                Håkan Ohlström
                                Håkan Ohlström
                                • Navigating on NEX
                                  Òscar
                                  Òscar
                                • Spoken notes are truncated
                                  3.2k
                                • Place Street View on the waypoint's position
                                • knop "Segment aanpassen" werkt niet
                                • Map behouden bij wisselen tussen Routes en Tracklogs
                                  Ed van Klink
                                  Ed van Klink
                                • Move pop up
