  4. No text whilst using the Animate function
7 Posts 5 Posters 2.0k Views 2 Watching
  • Skellum
    Skellum
    Skellum
    Whilst using the Animation function on some Scottish routes I am planning I have noticed that although Waypoint photo's are shown, it no longer shows the Text Box?
    I have used this function before so I know how it works but obviously not functioning correctly at the moment.
    Tony
    HABVEN aka MrMRA Rob Verhoeff 2 Replies Last reply
    • Skellum Skellum
      Tony
      @Skellum
      It works well with the routes in the library, first the text then the photo.
      Do you mean when you use the animation function when planning your route?
      Skellum 1 Reply Last reply
      • Skellum Skellum
        Tony
        @Skellum I've never seen that work! Only the photos will pop-up. No speech and no text will show.
        šŸ’» Routelab on MacBook Air & iMac (Golden Gate & Ventura)
          @Skellum
          Skellum
          Skellum
          Skellum
          @Hans-van-de-Ven-MRA-Master Yes, while planning our trips I always like to look at the route animation showing waypoint text and photo's, however I have noticed the text box no longer works and all you see now is the waypoint photographs.
          I have double checked that the animation menu was set correctly but still no text box?
            Skellum
            Skellum
            Skellum
            @Rob-Verhoeff Yes that is what I am finding now - we used to also get the waypoint text in a box - as per the animation menu.
            • Nick Carthew
              Problem reported to the development team.
                The issue should be solved! šŸ™‚
                Skellum
                Skellum
                  Erdna
                  Erdna
                • Minimap
                  LE DIZES Freddy
                  LE DIZES Freddy
                • Bollard trouble
                • Map movement
