More tilt on 3d mode
Hi I struggle to see the difference between 2d (top view) and 3d (tilted view). Can you make the tilt more obvious to show more of the route ahead just as it is in other navigation apps.
@JP-d In the settings you can adjust tilt and zoom from the default view.
@Dave-J-0 thanks for your reply. I have adjusted it to (- -) but would like to tilt even more.
Also I found you can't zoom in out in tilt mode it swaps to top view.
@JP-d I will have a look later. Not had problems before though.
@JP-d, Of you want more tilt, you need to + or ++, not - or --. You ar right about the zoom thing. I indeed see it going to birds-eye view. Never noticed that before. Auto-zoom works normally though.
@JP-d in my opinion, the zoom feature is an area in need of substantial improvement. For those that will say to adjust using +, ++, etc...yes, that works - it is the auto zoom for upcoming intersections, exits, etc - the amount of zoom the app does is so minimal, its barely noticeable. And it doesn't seem to work if the +, ++ has been used. Perhaps this is in thw works for future upgrades...or at least, I hope.
@GT-JWR, True. I think there are only 5 zoom steps available. If you have it on ++ you are already at the top zoomlevel, and autozoom will not do anything anymore. I have been asking around about this some time ago, but did not get confirmation. Maybe @Corjan-Meijerink can answer this one?
@Con-Hennekens the dynamic / automatic zoom will always continue to work.
The setting configures the range in which it can operate.Automatic zooming is only disabled in the top-down mode.
When using the zoom buttons on the map, you choose a fixed zoom level and the camera is set to the top-down mode.Some people like it like that, others don't
@Corjan-Meijerink, Oh, I see, so switching to top-down view when zooming is by design? I did not know. Thanks for clarification.
Was there a specific reason for this? A tap on the compass switches from 3D to top-down mode. Why not enable zoom in both modes?
