  4. Multiple waypoints deleted instead of just 1
8 Posts 5 Posters 1.7k Views 1 Watching
  • Trevor fundefined Offline
    Trevor f
    When deleting 1 waypoint in a route in the App (on my Samsung S22) always 2 waypoints are deleted not 1.
    On the MRA Web, only 1 waypoint is deleted on the same route.
    Anyone else have the same issue on the MRA app? And a solution! Or is it a bug in the app?
    Rob Verhoeffundefined Stuart Greerundefined 2 Replies Last reply
    • Trevor fundefined Trevor f
      Rob Verhoeffundefined Online
      @Trevor-f I can't reproduce this on iOS.
        Stuart Greerundefined Offline
        Stuart Greer
        @Trevor-f yes this also happens on my S22 +. I get around it by clicking on the waypoint and pressing the delete button in the dialogue box.
        Trevor fundefined 1 Reply Last reply
          Happend on my S20 only from the app, Web page works fine.
          • Stuart Greerundefined Stuart Greer
            Trevor f
            @Stuart-Greer thanks Stuart, so it's not just me! Seems like a software bug that needs a patch by MRA Co
              @Trevor-f, no it is not just you. I don't make it a habit to edit routes in the app, but tried it for this case, and this is what happens:
              https://photos.app.goo.gl/ENDovUbWsLEe4eog8
              Deleting through a tap on a waypoint and choosing the litter bin works okay.
                @Con-Hennekens Does this also happen if you remove a waypoint through the map itself? Or only through the waypoint menu?
                  @Rob-Verhoeff said in Multiple waypoints deleted instead of just 1:
                  @Con-Hennekens said in Multiple waypoints deleted instead of just 1:
                  Stuart Greer
                  Trevor fundefined
                  Trevor f
                    Mzokkundefined
                    166
                  • wrong routing
                    John S Parryundefined
                  • Updated beta! 5.2.1 (486)
                    Nick Carthewundefined
                  • Veekeersinfo en omleiden
                    Herman Veldhuizenundefined
                    329
                  • Request login credentials
                  • Move blocks of routepoints
                    Yannick_van_Vugtundefined
                    Yannick_van_Vugt
