  4. Using Connector to export routes to Zumo XT but does not show in Trip Planner
32 Posts 7 Posters 17.2k Views 2 Watching
  • BD 1 BD 1
    @Hans-van-de-Ven-MRA-Master
    Gentlemen - appreciate the help. @ Hans - a good next step but I just hooked up my Navi VI with the same results: tried the connector to export a route and it does not appear in the 'splash' screen on start up nor is it found in the import directory/trip planner. As mentioned, I have performed a repair on MRA and tried 2 different browsers with the same results - Chrome and Edge as well as two different connector cables. Will be heading out for a 6 day trip shortly, so my responses will be delayed.
    I am grateful for the help and hopefully an easy fix is 'just around the next waypoint'
    Best,
    BD
    @BD-1
    Can you share the url of the route, make sure it is set public
    BD 1 2 Replies Last reply
    • Albert van den Elsen
      @BD-1
      I tried to reconstruct your issue.
      This is how it works for me.
      • connect your Garmin XT with the USB cable to your computer.
      • wait until your computer confirms the XT is connected.
      • open the desired route in MyRoute-app
      • start the export via the connector tool
      • choose your device. In my case Garmin (GPX 1.1)
      • push the export button
      • after a short while your get the message "route is exported"
      • unplug your XT
      • start your Xt again
      • directly the 'New routes found' splash screen appears ( push the YES button)
      • if not ! Try manualy to import the route by open the hamburger menu and push on 'import'. The Garmin now starts to search for imported routes.
      • now the imported route must be vissible
      • put a checkmark next to the route and push the 'import' button
        You get the splash screen 'Saving item to trip planner'
      • after the import, the trip planner opens and the route must be vissible
      This is how it works for me with the export tool but normaly I export routes with my iPhone in combination with MRA and Garmin Drive. This always works for me.
      I hope my approach is helpful to you.
      If not, please feel free to reply.
      iPhone 15,
      Garmin Zumo XT3
      Carpuride W702 Pro
      Sena 20S EVO headset
      Harley Davidson Road King M8
      BD 1 1 Reply Last reply
        @BD-1
        BD 1
        BD 1
        BD 1
        link text
        Thank you
          @BD-1
          • unplug your XT
          BD 1
          BD 1
          BD 1
          @Albert-van-den-Elsen
          Thank you Albert - exactly as do except I use gps 1.2. Of note, the export used to work perfectly but now it does not - no splash screen notification nor is it found when I use import in trip planndf
            @BD-1
            BD 1
            BD 1
            BD 1
            link text
            HABVEN aka MrMRA 2 Replies Last reply
            • BD 1 BD 1
              link text
              @BD-1
              Thanks I will have a look at it
              • BD 1 BD 1
                link text
                @BD-1
                The route is added to my Zumo without any problems. After disconnecting the Zumo, I am asked whether I want to import the new route. Then I get the message that the route cannot be calculated because the maps are not present in my device
                Make sure that you place the route points correctly on the route line. Zoom in maximum.
                  @BD-1
                  BD 1
                  BD 1
                  BD 1
                  Thank you Hans; I have been diligent on placing the shaping points correctly on the routes as well as putting the via points close to the desired location per your tutorial
                  Since you were able to successfully import the routes, I wonder if there is some windows glitch that snuck in on the last update? This is a new issue for me as the route import previously would work fine.
                  The work around currently is to save the route as gpx1.2 and copy it to the gpx folder on my SD card and then import into trip planner. Just a few more steps and I have full functionality for traveling.
                  I appreciate your quick responses and suggestions
                  V/R
                  BD
                  • BD 1 BD 1
                    V/R
                    BD
                    @BD-1
                    The problem probably lies with a Windows update or a Garmin update (I've had that before).
                    Save it as... and then copy it to the GPX folder or with the MyRoute app (App) and the Garmin Drive App you can also get the routes on your XT. Open the route on the App and choose to download, then choose export (Apple) or export (Android) and choose the Garmin Dive App.
                    If you are going to install the Garmin Drive app, skip the Explorer step.
                      @BD-1
                      BD 1
                      BD 1
                      BD 1
                      @Hans-van-de-Ven-MRA-Master 10-4; thank you Hans
                      paul69 1 Reply Last reply
                      • BD 1 BD 1
                        @BD-1
                        just a quick thought, I am not going to write many lines of text unless you require more explanation.
                        do you have explore activated on your XT. I had a similar problem, the problem was not resolved until I removed/de-activated explore.
                        K1600 GTL
                        iPhone 13 Pro, carpuride 702b
                        • paul69 paul69
                          @BD-1
                          @paul-69
                          Or create the collection in Explore and make it visible in the XR and Explore
                          paul69 BD 1 2 Replies Last reply
                            @paul-69
                            I had all sorts of problems with routes/tracks etc not loading onto the XT. when connected it would show a pop up window
                            "would you like to import route track etc" I would click yes, but it would not show up in the trip planner.
                            I spent quite some time trying to sort this out, various forums, the only thing that worked in the end was to deactivate explore, all my problems went away.
                            I think the explore app is a bit of a donkey, but I am sure there will be people that have success with it, although I certainly did not.
                            K1600 GTL
                              @paul-69
                              BD 1
                              BD 1
                              BD 1
                              I have found that without the Zumo XT hooked up, when I use the connector to export, it says "Completed" The route is exported to your device. Enjoy!
                              Prior to this challenge, if the Zumo was not fully 'synched' to the computer, I would get an error message indicating the device could not be found.
                              Did install the latest windows update - which had no effect on the problem
                              2023-09 Cumulative Update Preview for Windows 11 Version 22H2 for x64-based Systems (KB5030310)
                              Thoughts?
                              • BD 1 BD 1
                                Thoughts?
                                #23
                                @BD-1
                                You have to wait until you see the xt on your PC before you use the connector
                                I mostly use my windows 10 desktop, I will check this on my windows 11 laptop.
                                  @BD-1
                                  BD 1
                                  BD 1
                                  BD 1
                                  Good morning - please try to use the connector w/o a device hooked up and see if you get an error message indicating there is no device.
                                  Without any device hooked up, the connector indicates the file transferred.
                                  I can see and use the Zumo from Windows (11) Explorer and I can download and copy the files to my SD card - just can't transfer via connector.
                                  I have done a repair to myroute app w/o change. Tried both Chrome and Edge with the same results.
                                  • BD 1 BD 1
                                    @BD-1
                                    Just transferred a route to the XT using the Windows 11 laptop.
                                    No problems encountered, the route is neatly placed on the device in the GPX folder, after which I can import the route.
                                    If no device is connected to the laptop, I get the message that the device cannot be found.
                                    So on this side everything works as it should.
                                      @BD-1
                                      BD 1
                                      BD 1
                                      BD 1
                                      Can we switch sides? 🙂
                                      • BD 1 BD 1
                                        BD 1
                                        BD 1
                                        BD 1
                                        @BD-1
                                        Morning Hans - issues is resolved!
                                        I had a SanDisk Ultra USB plugged in at the same time my Zumo XT was plugged in. Removing the SanDisk allowed the connector app to seek out the Zumo as intended. Removing both the USB and Zumo and using the connector app gave me the error message there is no device.
                                        When the USB and Zumo are connected to the PC, the connector app is sending the file to the Garmin folder on the USB only.
                                        Appreciate your kind assistance in trying to solve my problem - appears to have been 'self inflicted' !
                                        BD
                                        • BD 1 BD 1
                                          link text
                                          Thank you
                                          @BD-1
                                          Always place the points on the route line, zoom in as much as possible.
                                          Guzzist 1 Reply Last reply
                                          BD 1
                                          BD 1
                                          Carlos Garcia
                                          Carlos Garcia
                                          • Online map settings
                                            MartinW
                                            MartinW
                                          • Real-time traffic
                                            Òscar
                                            Òscar
                                            Andy Nicholson
                                            Andy Nicholson
                                          • HERE map not calibrated
                                            MartinW
                                            MartinW
                                          • Myrouteappstay
                                            Bé Jeuring
                                            Bé Jeuring
                                          • Navigatie met DMD tablet
                                          • Show on the maps's button
