  3. [App] Announcements
  4. New update! (4.0.4)
New update! (4.0.4)
12 Posts 8 Posters 4.3k Views
    Hi everyone! ๐Ÿ‘‹
    We've got quite a nice update for you this week! ๐Ÿ™‚
    It will probably be downloadable between this evening and Wednesday.
    Detailed lane assistance
    Where applicable (mostly highways), you can now enable the app to show a detailed image of the lanes you should use.
    This information is only available on the primary roads. Within the screen layout settings, you can configure the lane instruction to be off / simple / detailed. The simple setting represents the lane instructions as you are used too ๐Ÿ˜‰
    Spoken waypoint information
    In the previous update, we changed the layout of presenting waypoint information.
    In the the audio settings of the app, you can choose between waypoint notifications off / via / all.
    • Off: never spoken
    • Via: only viapoints are mentioned
    • All: both via- and shapingpoints are mentioned
    In the previous app version, this would just be a generic notification about approaching a waypoint. In the update, a feature unique for MRA is added. The title and possible description of the waypoint are actually read to you! ๐Ÿ˜ We are sure you will enjoy the MyRoute-app text-to-speech service ๐Ÿ˜ƒ
    If you want to repeat the audible description of the waypoint, simply press the displayed information on your screen.
    Note: if the title of a waypoint is merely an address and no description is present, we do not read it to you. If you truly want a waypoint to be read to you; either ensure no numbers are present in the name or add a description.
    Improved warnings for motorhomes
    To ensure you do not crash your motorhomes into tunnels, we enhanced the warnings specifically for your vehicle dimensions.
    If you exceed (or are very close to) the dimensions of the upcoming road, you receive an audio / visual warning. We also added the applicable restrictions as icons to the map.
    Note: these are only displayed when driving a motorhome route. Ensure you set your vehicle dimensions correctly
    Voice prompt configuration
    Quite some people were annoyed with the amount of voice prompts you would get for each instruction. You can now select an amount between 1 and 4 voice prompts per instruction.
    The lower the number, the less instructions you receive.
    1 = action only, 2 = 1 + distance reminder, 3 = 2 + general reminder, 4 = 3 + furthest possible announcement.
    Note: 0 is not available because if you do not want any voice prompts, just turn it off ๐Ÿ˜‰
    Note: apart from the action instruction, the others are not guaranteed to exist
    Automatically start tracking
    Do you often forget starting a tracklog? Simply turn on this setting! ๐ŸŽ‰ When driving a (scenic) route, the tracklog will automatically start.
    Note: AB routes won't be recorded automatically
    Updated settings
    More settings as described above are available. These are the updated settings.
    Automatic resuming and recenter camera
    Ever had a brake and forgot to resume your tracklog?
    Did you had a drop of rain messing with your screen?
    Issues of the past! When we detect you are moving, a paused tracklog will automatically resume and the camera will refocus on your position after 5 seconds of continuous movement.
    Note: only works while navigating and cannot be turned off
    Fixed issues
    • Grey screen (mostly Android) when resuming navigation
    • Audio channel configuration iOS - this should solve the volume issues / radio interrupt you were experiencing
    • Some Android Auto stability improvements
    Minor changes
    • Account screen can be used when not logged in - allowing users to change settings or view their downloads even when not logged in.
    • After editing a route and going back to the app, the app refreshes the information about that route
    • Improved adding favorites - you can now immediately edit a saved favorite
    • If audible warnings are enabled, a notification will be played when a waypoint is skipped
    • CarPlay / Android Auto: fixed issue where map was zoomed in too much after reopening the app.
    That's it ๐Ÿ’ช
    So what is coming up?
    • Still investigating and working on a solution for battery usage with HERE
    • Android Auto & CarPlay stability
    • Android Auto & CarPlay features
    • Next update will contain nearby fuel stops! ๐ŸŽ‰
    Enjoy this update! ๐Ÿ™‚
    Cheers,
    Corjan
    Marinus van Deudekom Bart De Medts Renรฉ en Charissa Bol 4 Replies Last reply
      Hi everyone! ๐Ÿ‘‹
      • Off: never spoken
      Updated settings
      Fixed issues
      Minor changes
      That's it ๐Ÿ’ช
      Cheers,
      Corjan
      @Corjan-Meijerink do you know when it will be available in Google Store
        @Marinus-van-Deudekom This public release will probably be available before Wednesday. Sometimes Google / Apple complete their reviews within a day, mostly within 2 and sometimes in more ๐Ÿ˜‰
          Hi everyone! ๐Ÿ‘‹
          • Off: never spoken
          Updated settings
          Fixed issues
          Minor changes
          That's it ๐Ÿ’ช
          Cheers,
          Corjan
          @Corjan-Meijerink Nice job MRA team!
          ๐Ÿ๏ธ Tiger: DMD Nor7e + SilverFox controller
          ๐Ÿ๏ธ Bobber: iPhone 15 Pro + Quad Lock mount
          ๐Ÿš— Car: iPhone 15 Pro with wireless Apple CarPlay
          • Cleo
            I don't know if i ask an new function or i didn't look very wel but in the field Time and Duration at the bottem you see only the the extra travel time if plan a route, lets say from a to b and there is a congestion, but if you start to navigate you don't see the extra delay any more. Is this an option or a bug?
            • Cleo Cleo
              @Cleo that's correct. The exact amount of delay isn't displayed anymore when you started navigating ๐Ÿ™‚
              • Cleo
                That's a pitty or bugger. I always like to see the delay if it's to long a take a break, only when a travel long distances.
                  @Corjan-Meijerink iOS is available waiting for Android
                  • Neil Bartlett
                    Neil Bartlett
                    Neil Bartlett
                    Thanks team, its nice to see the updates rolling through regularly.
                    R1200RS, Nav VI, Zumo XT2, iPhone. โ€” Plot the Track, Go the Distance
                      Hi everyone! ๐Ÿ‘‹
                      • Off: never spoken
                      Updated settings
                      Fixed issues
                      Minor changes
                      That's it ๐Ÿ’ช
                      Cheers,
                      Corjan
                      @Corjan-Meijerink De update werkt geweldig. Is zeer duidelijk bij de aanduiding voor de afslagen. Is weer echt top werk!
                      DerRoteBlitz 1 Reply Last reply
                      • Renรฉ en Charissa Bol Renรฉ en Charissa Bol
                        DerRoteBlitz
                        DerRoteBlitz
                        DerRoteBlitz
                        @Renรฉ-en-Charissa-Bol Hi, Android is available
                        • richtea999 richtea999 referenced this topic on
                          Hi everyone! ๐Ÿ‘‹
                          • Off: never spoken
                          Updated settings
                          Fixed issues
                          Minor changes
                          That's it ๐Ÿ’ช
                          Cheers,
                          Corjan
                          @Corjan-Meijerink en de Android update is ook beschikbaar
                          1 minuut voor mijn trip van 125 km nog snel geรฏnstalleerd.
                          Met Android auto gereden.
                          Gesproken aanwijzingen waren nu hard genoeg.
                          Geen uitval op app crash gehad.
                          Lane assist was bijna perfect, althans op de telefoon want op het scherm van de radio was Lane assist helaas nog niet zichtbaar.
                          Van de week op de motor de volgende test doen
                          Good job team
                          DerRoteBlitz
                          DerRoteBlitz
                          Neil Bartlett
                          Neil Bartlett
                            Thomas Neumeyer
                            Thomas Neumeyer
                            3.7k
                            Robineke
                            Robineke
                            226
                          • How to plan correctly
                          • Offline Mode function
                          • Brittany routes
                            Tony 13
                            Tony 13
