  3. [App-Beta] Announcements
  4. New Beta! (v4.0.4)
New Beta! (v4.0.4)
49 Posts 22 Posters 453 Views 7 Watching
    Just in time for the weekend! 🎉
    The previous Beta had some awesome new features and we try to continue on the same pace. The update might not contain the biggest changes but nonetheless enough good stuff to start releasing it to the public 😉
    Detailed lane assistance
    Where applicable (mostly highways), you can now enable the app to show a detailed image of the lanes you should use.
    This information is only available on the primary roads. Within the screen layout settings, you can configure the lane instruction to be off / simple / detailed. The simple setting represents the lane instructions as you are used too 😉
    Spoken waypoint information
    In the previous update, we changed the layout of presenting waypoint information.
    In the the audio settings of the app, you can choose between waypoint notifications off / via / all.
    • Off: never spoken
    • Via: only viapoints are mentioned
    • All: both via- and shapingpoints are mentioned
    In the previous app version, this would just be a generic notification about approaching a waypoint. In the update, a feature unique for MRA is added. The title and possible description of the waypoint are actually read to you! 😏
    Note: if the title of a waypoint is merely an address and no description is present, we do not read it to you. If you truly want a waypoint to be read to you; either ensure no numbers are present in the name or add a description.
    Improved warnings for motorhomes
    To ensure y'all do not crash your motorhomes into tunnels, we enhanced the warnings specifically for your vehicle dimensions.
    If you exceed (or are very close to) the dimensions of the upcoming road, you receive an audio / visual warning. We also added the applicable restrictions as icons to the map.
    Note: these are only displayed when driving a motorhome route. Ensure you set your vehicle dimensions correctly
    Voice prompt configuration
    Quite some people were annoyed with the amount of voice prompts you would get for each instruction. You can now select an amount between 1 and 4 voice prompts per instruction.
    The lower the number, the less instructions you receive.
    Note: 0 is not available because if you do not want any voice prompts, just turn it off 😉
    Automatically start tracking
    Do you often forget starting a tracklog? Simply turn on this setting! 🎉 When driving a (scenic) route, the tracklog will automatically start.
    Note: AB routes won't be recorded automatically
    Updated settings
    More settings as described above are available. These are the updated settings.
    Automatic resuming and recenter camera
    Ever had a brake and forgot to resume your tracklog?
    Did you had a drop of rain messing with your screen?
    Issues of the past! When we detect you are moving, a paused tracklog will automatically resume and the camera will refocus on your position after 5 seconds of continuous movement.
    Note: only works while navigating and cannot be turned off
    Fixed issues
    • Grey screen (mostly Android) when resuming navigation
    • Audio channel configuration iOS - this should solve the volume issues / radio interrupt you were experiencing
    • Some Android Auto stability improvements
    Minor changes
    • Account screen can be used when not logged in - allowing users to change settings or view their downloads even when not logged in.
    • After editing a route and going back to the app, the app refreshes the information about that route
    • Improved adding favorites - you can now immediately edit a saved favorite
    That's it 💪
    So what is coming up?
    • Still investigating and working on a solution for battery usage with HERE
    • Android Auto & CarPlay stability
    • Android Auto & CarPlay features
    • Next update will contain nearby fuel stops! 🎉
    Have an awesome weekend. Looking forward to the feeback.
    Cheers,
    Corjan
    @Corjan-Meijerink Great work again mate. 👏
      Android is available to download.
      iOS still in review 😉
      Dave J 0 1 Reply Last reply
        @Corjan-Meijerink just downloaded the Android version. Great job and just in time for a big ride in a couple of days. 😀
        iPhone 18 Pro
          @Stanisław yeah, AB routes are routes that are generated by app using the fastest option.
          Example: search for an address (keep it to fastest) and go - that's AB.
          Lynchy67
          Lynchy67
          Lynchy67
          Android is available now.
            • Off: never spoken
            Updated settings
            Fixed issues
            Minor changes
            That's it 💪
            Cheers,
            Corjan
            @Corjan-Meijerink said in New Beta! (v4.0.4):
            Does this apply to files in the 'Downloads' file?
            iPhone 18 Pro
            Nick Carthew Corjan Meijerink 2 Replies Last reply
            • Dave J 0 Dave J 0
              @Dave-J-0 said in New Beta! (v4.0.4):
              Great question.
              If you edit a previously download route, does the link in the downloads folder change to the edited version?
              • Dave J 0 Dave J 0
                @Dave-J-0 @Nick-Carthew No 🙂
                Only the behavior that when you opened a route, click the pencil icon (edit), change stuff and close the browser: you will see the route refreshing.
                  @Corjan-Meijerink Understood. So delete previous downloaded version and re-download the edited version for use off-line. 👍
                    @Lynchy67, may I ask for the reason for double accounts?
                    Lynchy67
                    Lynchy67
                    Lynchy67
                    #19
                    Of course you can ask!
                    For a long time I had iPhones and only a single iOS MRA Account.
                    Then I simply got fed up and bored with iOS and decided to try an android phone.
                    First i bought a second hand S10 5G and more recently upgraded to a second hand Samsung S21+
                    I will never buy a brand new phone again!
                    Yes I have paid twice for the full MRA Navigation experience.
                    For me its a navigation device first and secondly a phone that I rarely use to make calls.
                    Also I have an 9" iPad and a 12" iPad Pro so in theory I can test iOS as well.
                    Maybe one day iOS will wooh me back into their fold!
                      @Nick-Carthew no need to delete, new download will replace the old one 😉
                        • Off: never spoken
                        Updated settings
                        Fixed issues
                        Minor changes
                        That's it 💪
                        Cheers,
                        Corjan
                        How is the spacing of the voice prompts determined if you select a lower number? I have chosen '2' but I seem to be only receiving one very late announcement. Screenshot_20230831-162944.png
                        At motorway speeds, this announcement is also very late. Furthermore with the times I do receive the first announcement of the 2, this tends to be just, "continue on the route.......". I had thought that I may get an initial 0.5mile out warning and then one before I need to turn. Grateful if you could clarify how the variable announcements are determined with distance and moreover, speed.
                        I will do some more testing with a more complicated route and not just an A to B. Good work.
                        iPhone 18 Pro
                        • Dave J 0 Dave J 0
                          #22
                          @Dave-J-0 thanks! Ofcourse I can elaborate 🙂
                          1: The actual action (eg. Turn left now)
                          2: Furthest possible notification (eg. Turn left in 5km)
                          3: Distance reminder (eg. Turn left in 500m)
                          4: General reminder (eg. Turn left in 2km)
                          Each number includes the preceding numbers so to say 😉
                          The first is the only one guaranteed to exist.
                          Dave J 0 Drabslab 2 Replies Last reply
                            @Corjan-Meijerink ok. That makes sense. For me, I would prefer if the number 2 was number 4 and then 3 and 4 became 2 and 3 repaectively. Useful to know what others think and will go with the flow. 😀. Btw, the grey screen problem on resume does seem to be cured despite my best efforts to break it. 😂 Great job.
                            iPhone 18 Pro
                            Lynchy67 1 Reply Last reply
                              #24
                              Wow, this is difficult to decide on when starting to think about it.
                              I would probably want to turn it around:
                              1: The actual action (eg. Turn left now), I always want to hear
                              3: Distance reminder (eg. Turn left in 500m), I always want to hear as it is useful at any speed and any road
                              4: General reminder (eg. Turn left in 2km) i want to hear sometimes depending whether I go fast or not
                              2: Furthest possible notification (eg. Turn left in 5km) I maybe don't need as I am never racing and will already have forgotten the instruction by the time I get to the turning point. 🙂
                              Corjan Meijerink Stefan Hummelink 2 Replies Last reply
                                @Corjan-Meijerink yes. This works a treat. Brilliant.
                                iPhone 18 Pro
                                  • Off: never spoken
                                  Updated settings
                                  Fixed issues
                                  Minor changes
                                  That's it 💪
                                  Cheers,
                                  Corjan
                                  @Corjan-Meijerink thnkx 4 a great job done
                                  May the testing begin👍😁
                                  • Drabslab Drabslab
                                    @Drabslab @Dave-J-0 Thanks for the feedback! This is exactly what the Beta is for. More than happy to change it if that’s preferred 🙂
                                    • Drabslab Drabslab
                                      @Drabslab said in New Beta! (v4.0.4):
                                      +1 !
                                      Skellum 1 Reply Last reply
                                        +1 !
                                        Skellum
                                        Skellum
                                        Skellum
                                        @StefanHummelink said in New Beta! (v4.0.4):
                                        +1 !
                                        and me! and well done again Corjan 👍
                                        • Dave J 0 Dave J 0
                                          Lynchy67
                                          Lynchy67
                                          Lynchy67
                                          @Dave-J-0
                                          Same here, I spent 30 minutes on a bus loading routes with not a single grey screen in sight.
                                          @Corjan-Meijerink 👍
                                          Òscar
                                          Òscar
                                          Stanisław
                                          Stanisław
                                          Ruud Schouten
                                          Ruud Schouten
                                          Dikke Wim
                                          Dikke Wim
                                          Skellum
                                          Skellum
                                          Inge Bakermans
                                          Inge Bakermans
                                          cvlmtg
                                          cvlmtg
                                          Lynchy67
                                          Lynchy67
                                          Steve Lynch
                                          Steve Lynch
                                          Ian foster 0
                                          Ian foster 0
                                          Koen VH
                                          Koen VH
                                            Rene van Maanen
                                            Rene van Maanen
                                          • _Tracklogs folder nearly empty?
                                          • One crash today
                                          • Tracklogs access at friends and clubs
                                          • 6.0 UI in landscape needs pollishing
                                            Mosimann
                                            Mosimann
                                          • Download club route folders
                                            136
