  4. Map display car play
18 Posts 7 Posters 228 Views 1 Watching
  • Uwe Müller
    Uwe Müller
    Uwe Müller
    I think that the contrast of Car Play could be improved.
    Greetings Uwe
    • Uwe Müller Uwe Müller
      Greetings Uwe
      @Uwe-Müller feel free to share a screenshot / elaborate a bit 🙂
        Greetings Uwe
        @Uwe-Müller, Isn't it so that you change contrast and brichtness at your carplay unit?
        • Jörgen
          Adjusting contrast and brightness in CarPlay makes the screen even worse and thus does not help.
          The display quality for CarPlay is much worse than for smartphones (OLED).
          The used color and brightness difference between street and landscape is too small. The dark gray is too little different from the light gray or blue.
          So some other colors could help.
          • Jörgen Jörgen
            @Jörgen said in Map display car play:
            The cause of this isn't CarPlay, but the screen in your car. Most manufacturers don't put nice high resolution displays in their cars.
            Uwe Müller 1 Reply Last reply
              Uwe Müller
              Uwe Müller
              Uwe Müller
              @Herko-ter-Horst A Zenec Naviciever is installed in one of my vehicles. The quality of the screen is good. Nevertheless, the contrasts could be better
              Uwe Müller Herko ter Horst 2 Replies Last reply
                Uwe Müller
                Uwe Müller
                Uwe Müller
                Unfortunately at the moment MRA crashes immediately so I can't take a screenshot.
                As soon as the app opens and I try to enter a destination, it crashes.
                  @Uwe-Müller Does the unit itself have any options to adjust contrast?
                    Uwe Müller
                    Uwe Müller
                    Uwe Müller
                    @Herko-ter-Horst YES
                      @Uwe-Müller Maybe adjusting that will help? I do agree that the app in general has a very muted colour scheme, which contributes to things on screen mushing together on low-res, low contrast displays.
                        @Uwe-Müller said in Map display car play:
                        You are not using the correct app, try using the beta MRA Navigation app that works from within the MRA Mobile app.
                          Uwe Müller
                          Uwe Müller
                          Uwe Müller
                          @Nick-Carthew i don‘t find a beta in the store
                            @Uwe-Müller see this sign up form: https://forum.myrouteapp.com/topic/2806/sign-up-for-the-beta and other instructions listed here: https://forum.myrouteapp.com/category/19/beta-mra-navigation-next
                            You need to fill in some stuff and then you get access to the Beta 🙂
                            Uwe Müller 2 Replies Last reply
                              Uwe Müller
                              Uwe Müller
                              Uwe Müller
                              @Corjan-Meijerink Thank you. I thought I had halutinations 😂
                                Uwe Müller
                                Uwe Müller
                                Uwe Müller
                                Sorry, now I got a confirmation for the beta test, but unfortunately I still don't know where to find the download.
                                Unfortunately I am a dau
                                  @Uwe-Müller you’ll get an invitation later. I need to process all registrations manually. I usually do this on Wednesday / Thursday. When I’ve done so, you will receive an email from us with further instructions 🙂
                                    Uwe Müller
                                    Uwe Müller
                                    Uwe Müller
                                    @Corjan-Meijerink Now I have received the invitation, but no mail from Testflight. Has it disappeared, or is it normal that it arrives so much later?
                                    Spam folder is empty
                                    • Walter Coady
                                      Walter Coady
                                      Walter Coady
                                      My unit will not display, basically white screen. The fix is to unplug, turn on my MyRoute-app on phone and reconnect.
                                      Uwe Müller
                                      Uwe Müller
                                      Walter Coady
                                      Walter Coady
                                      • 'Geen adres bekend'
                                        PA. Vis 0
                                        PA. Vis 0
                                        Ruud Bijkerk
                                        Ruud Bijkerk
                                      • Route exporteren uit beta
                                        Johan 5q
                                        Johan 5q
                                        127
                                        158
                                      • iPad - zooming out
                                        Big Al 1
                                        Big Al 1
