  3. Re ordering routes in my folder, is there a way?
9 Posts 5 Posters 1.8k Views 1 Watching
  • Lee Hardwick Offline
    Lee Hardwick
    Hi Folks,
    Is there a way to re order routes in my folder. I seem to have them randomly scattered in there even after putting them there in the order I want. I`ve numbered them but would like them in order.
    Thanks!
    Lee
    Herko ter Horst Hans van de Ven MR.MRA 2 Replies Last reply
    • Lee Hardwick Lee Hardwick
      Hi Folks,
      Thanks!
      Lee
      Herko ter Horst Offline
      @Lee-Hardwick You can not manually order them. You can sort the routes by any of the columns in the list, by clicking on the column header.
      Lee Hardwick 1 Reply Last reply
        Lee Hardwick
        @Herko-ter-Horst Thanks for the reply, a bit disappointing that they can`t be moved in the order I want them such as Day1, Day2 etc
        Tim  Thompson Nick Carthew Herko ter Horst 3 Replies Last reply
          Tim  Thompson Offline
          Tim Thompson
          @Lee-Hardwick said in Re ordering routes in my folder, is there a way?:
          Seems to me that you do a have a fair amount of control in their order by the naming convention you use and sorting on the names column. Plus... There are folders.
            Nick Carthew Offline
            As @Tim-Thompson has already said, considered naming of routes and the use of folders is the way to organise your routes.
            I would also drop the word Day and number sequential routes as 01, 02, 03 etc.
              Hi Folks,
              Thanks!
              Lee
              @Lee-Hardwick
              I use always MMDD Route Name (0326 Start season 2023)
                You can just prepend Day1, Day2, etc. to the name of your route and sort by name. Or use any of the date-based naming conventions suggested above.
                I personally use a folder per year. Inside are folders for each of my trips, for which the name starts with "MMDD" for month and date. Inside each trip folder are routes for which the name starts with "MMDD (dow)", occasionally with a sequence number added if I use multiple routes per day, so "MMDD-1 (dow)" and "MMDD-2 (dow)". I just keep the lists/tables in MRA sorted by name.
                  Lee Hardwick
                  Thanks for the ideas folks, I`ve had a play and numbered them day1,day 2 etc at the start of the description and its worked to get them in order with the name.
                  • Tim  Thompson Tim Thompson
                    Lee Hardwick
                    @Tim-Thompson I`ve used folders to group a multi day tour in
                    Lee Hardwick
                    Lee Hardwick
                    Tim  Thompson
                    Tim Thompson
                      377
                      Kobutex Motorreizen
                      Kobutex Motorreizen
                    • App loopt vast
                      Marcel Schreurs
                      Marcel Schreurs
                    • Seizoen sluitingen wegen
                    • I can't see Road Closures
                      KeesV
                      KeesV
                    • Absurd travel time calculation
