  4. Battery drain when navigating
57 Posts 22 Posters 1.0k Views 8 Watching
  • Flat Twin Therapyundefined Offline
    Flat Twin Therapy
    wrote on last edited by Flat Twin Therapy
    Yesterday I wanted to use MRA Next Beta for navigating and tracking a tour. Phone was 92% when I left home. Wirelessly charging using the QuadLock charger, which I always use on the bike. It allways charges during the ride, so never drains.
    After 30m I noticed my phone only had 52% left... Rebooted the phone and resumed the tracklog (I love this feature <3). But rebooting didn't help. MRA kept draining the battery. At 45% I stopped navigating with MRA Next, downloaded the .gpx and used a differerent app to navigate.. however I did use MRA Next for track recording... That worked... Battery started to charge again...
    Anybody having the same issue?!
    Google Pixel 6 Pro, Android 13, QuadLock wireless charging on R1200GS.
    Since January 2024 I started recording some of my rides commuting and touring the R1200RT in The Netherlands:
    https://youtube.com/@FlatTwinTherapy
    Rob Verhoeffundefined Corjan Meijerinkundefined 2 Replies Last reply
    • Flat Twin Therapyundefined Flat Twin Therapy
      Rob Verhoeffundefined Offline
      @Rolf-Aalders Did you use the latest build 3.2.8-151? In that version some issues regarding battery drainage should be resolved!
      Flat Twin Therapyundefined 1 Reply Last reply
        @Rolf-Aalders Happy you love the tracklog recovery feature! 🙂
        Please indeed confirm the app version you are using, we will investigate the issue!
          Flat Twin Therapy
          @Rob-Verhoeff Thanks Rob, good to hear it is being worked on.
          No I'm not using 3.2.8-151.
          In the app version number states 3.2.8-150
          How do I update? In the play store no update is available
          Had to go somewhere tonight by car. Phone in a wired charger and normally indeed positive charging. Now, track recording and navigation: 2 crashes and negative charge. When I stopped navigating and kept recording track, positive charging, so issue is reproducable.
          I do know you mentioned latest version might fix battery usage, but still wanted to inform that navigating seems to cause it, not the track recording.
            @Rolf-Aalders 3.2.8 is the latest! Android and iOS have a slightly different build number (150 vs 151).
            Reading these messages it indeed has more to do with the navigation rather than the background tracking. We’ll investigate!
              Flat Twin Therapy
              @Corjan-Meijerink thanks!
              Let me know if you need more info! Happy to help!
              • Mopetenpitundefined Offline
                Mopetenpit
                My contribution to the topic "battery charging". I drove a short distance today with the bike and Navigation Next. At the start I had a battery charge of 73%, at the finish was 64%. The route is 3.4 km long and of course only takes a few minutes. Equipment: iPhone 13 pro, iOS version 16.3.
                Ad Koppenolundefined 1 Reply Last reply
                • Arno 0undefined Offline
                  Arno 0
                  Also tested battery drain this morning on my OnePlus 6T with Android 11 and MRA Next 3.2.8-150 installed. A half hour 25 km tour (no tracking) dropped the battery level with 9% without charging.
                    @Mopetenpit @Arno-0 Now that’s a significant different between you two. I would like to say that the Android experience is more or less reasonable battery consumption. The iOS usage is however more than you would expect.
                    • Jure Sirena 0undefined Offline
                      Jure Sirena 0
                      Its exactly what I experienced. Large baterry draining despite phone on charger (you have my report)
                        Jure Sirena 0
                        I plan today to do 150km, I will reset all the counters and start with 100% battery and on charger. Will post results
                        • Rob Verhoeffundefined Offline
                          Today no navigation, but onbly tracking a route by bycicle. Let the screenshots speak for itself.
                          Started tracking at 96% battery capacity. Distance 15km; time 40minutes.
                          Halfway, 1% background activity
                          After 30km's end of tracking. 90 minutes pause in between two trackings and only 3% use of background activity.
                          Batterycondition is 100%.
                          Looks good so far. Resumé: tracked with the app for 90 minutes and stood on standby for 90 minutes.
                          iPhone 13
                          iOS 16.3.1
                          App-buid: 3.2.8 - 151
                            iPhone 13
                            iOS 16.3.1
                            @Rob-Verhoeff That's very decent! Thanks for sharing the information 🙂
                            • Willy DEOMundefined Offline
                              Willy DEOM
                              Première sortie à moto avec la version beta :
                              Samsung Galaxy S21 FE 5G - Android 13 Batterie 4.500 mAh
                              Version beta 3.2.8 - 150
                              1° sans alimentation du smartphone
                              Démarrage à 10h à 100% avec uniquement un itinéraire + suivi + Bluetooth écouteurs : Batterie vide (0%) à 12h !!!
                              2° Essai avec alimentation :
                              Démarrage à 14h30, batterie à 58% avec uniquement itinéraire + bluetooth écouteurs : Batterie à 44% à 15h30
                              Effectivement, la batterie se vide à une vitesse VV' alors qu'en utilisation normale, la batterie tient plus de 2 jours.
                              Je suis certain de ne pas tenir toute une journée malgré l'alimentation 12V.
                              C'est un réel problème que je n'avais pas avec la version MRA Navigation.
                              Bon travail et bonne continuation, on compte sur vous
                              • Willy DEOMundefined Willy DEOM
                                @Willy-DEOM Thanks for sharing the feedback and further information. We will continue investigating the issue.
                                  Dave J 0undefined Offline
                                  @Corjan-Meijerink Just been on a run today with my iPhone 8 Plus (iOS 16.3.1) and there was no drain on battery whilst tracking, navigating and screen recording. Indeed, the charge increased to 100% as the ride went on. I was using a cable from auxiliary socket to the Lightning Port to charge and i will check wireless charge performance on the bike next time I am out on it. No issues with drain from my perspective.
                                  iPhone 15 Pro
                                  • Dave J 0undefined Dave J 0
                                    @Dave-J-0 Thanks for confirming another side of this issue! I just drove for 45 minutes with full screen brightness, tracking on and using the nee navigation.
                                    Battery usage was 15% which is pretty decent. When using Google Maps this morning during a 35 minute ride, the battery usage was 11% which is very similar.
                                    My device is an iPhone 12 Pro Max.
                                      Flat Twin Therapy
                                      Indeed that sounds acceptable! I don't mind the battery use when not charging. But when charging there should still be a positive charge, else the risk of running out of battery during a ride is too high. That should not be the case, right?
                                        @Rolf-Aalders That indeed really should not be the case!
                                        infoevertkuiken.nlundefined Flat Twin Therapyundefined 2 Replies Last reply
                                          infoevertkuiken.nlundefined Offline
                                          infoevertkuiken.nl
                                          @Corjan-Meijerink here my battery usage today. Used MRA between 7:30 and 9 and 4:30 and 6. My battery doesn’t like cold weather and this morning was ccccolddd (1 degree Celsius and fog). I think this is ok. My phone (iPhone 7) is always on the charger when driving. I do have background location set to “when using app” because I noticed several crashes when not even using MRA and quite some battery usage. 497DC53A-C653-4462-8CA4-303DD2ABD150.png
                                          Nick Carthewundefined
                                          RetiredWingManundefined
                                          CD130undefined
                                          infoevertkuiken.nl
                                          richtea999undefined
                                          Stephen Rowlandundefined
                                          Stephen Rowland
                                          Dave J 0undefined
                                          Mopetenpitundefined
                                          Mopetenpit
                                          M PRPundefined
                                          M PRP
                                          Arno 0undefined
                                          Arno 0
                                          Paul 41undefined
                                          Paul 41
                                          Maarten vundefined
                                          Maarten v
                                          Ad Koppenol
                                          Flat Twin Therapy
                                          Jure Sirena 0
                                          Simannjoundefined
                                          Simannjo
                                          Karl Mumfordundefined
                                          Karl Mumford
                                          Willy DEOMundefined
                                          Willy DEOM
                                            Nomko Nomdenundefined
                                            Nomko Nomden
                                            Peter Zehentreiterundefined
                                            Nomko Nomden
                                          • Here kaart
                                            Nomko Nomden
                                            406
                                          • DMD - T865x + BMW sync box + bedienen MRA met Wonderwiel
                                            PieterH_GSundefined
                                            PieterH_GS
