  4. Beta 3.2.5 Can't load Routes
20 Posts 5 Posters 341 Views 3 Watching
  • Greg Meekings 0undefined Offline
    Greg Meekings 0
    Beta 3.2.5
    Can't load recently produced routes. Routes generated on my Mac with web (Chrome) interface. This is the message I get.
    So sadly I can't test the navigation on my bike rides...
    • Greg Meekings 0undefined Greg Meekings 0
      Beta 3.2.5
      @Greg-Meekings-0 This error message happens even before entering the Navigation.
      My guess would be a connectivity issue or something strange going on with those routes.
      Also, cycle / hiking routes are not yet really supported by the Navigation app so I wouldn’t really get into that yet πŸ˜‰ It should however work within the Mobile app part (where you currently are). So again, probably your internet / something with those routes. Please try again later / with other routes πŸ™‚
      Sorry for the inconvenience.
      Jose Pinheiro 0undefined 1 Reply Last reply
        Jose Pinheiro 0undefined Offline
        Jose Pinheiro 0
        wrote on last edited by Jose Pinheiro 0
        @Corjan-Meijerink maybe this information can help. I also experience the same error, but only in a "route" that only have waypoints, and not a designed route
        "So many roads, so little time"
        • Jose Pinheiro 0undefined Offline
          Jose Pinheiro 0
          here is the link to the "route" I'm talking about:
          https://www.myrouteapp.com/en/social/route/6791143?mode=share
          • Jose Pinheiro 0undefined Jose Pinheiro 0
            @Jose-Pinheiro-0 That one indeeds shows an error on my side too. A route without waypoints indeed isn’t really a route so the app does not like it.
            I think the error message comes from the fact that statistics cannot be calculated (due to no waypoints)
              Jose Pinheiro 0
              @Corjan-Meijerink right. I understand that make sense
                Greg Meekings 0
                Thanks but I don't have internet or comms problems and my routes do have way points...
                If I copy and edit i.e. add a waypoint it still fails. If I recreate the route from scratch it works?!?
                  @Greg-Meekings-0 Please share the route that cannot be loaded by the app πŸ™‚
                  Greg Meekings 0undefined Rob Verhoeffundefined 2 Replies Last reply
                    Greg Meekings 0
                    @Corjan-Meijerink This is one ofn the routes that fails to load in the 3.2.5 Beta https://www.myrouteapp.com/en/social/route/6337640?mode=share
                    Greg
                      Rob Verhoeffundefined Offline
                      @Corjan-Meijerink could this be an "old" bug from the Navigation app? Transport mode is set to cycling. It crashes right away for me too. I remember seeing this same behavior in the Navigation app!
                      It is not possible to change the transport mode in Routelab. If you can do that behind the scenes, it would be worth a try.
                      Edit: Bizarre! After loading one of my own routes, I opened the route from topic starter again. Now the route opens and I can also navigate.
                      Greg Meekings 0undefined 1 Reply Last reply
                        Greg Meekings 0
                        @Rob-Verhoeff Not a problem with simply cycle mode, one of my cycles routes does open. I have also recreated several cycle routes and they do load ok. Its obscure, perhaps some sort of version incompatibility since resolved...
                          Will be investigated! Thanks for the extra input πŸ™‚
                            I can confirm that the issue has been identified and fixed.
                            The changes will automatically be applied coming Monday / Tuesday. No user action required πŸ™‚
                              Greg Meekings 0
                              @Corjan-Meijerink Great I will check it out next week - after Christmas. Have a good one!
                                @Greg-Meekings-0 Thanks! You too πŸ™‚
                                  I can confirm the issue is solved as of today πŸŽ‰
                                  Maybe another issue now arises but that is something you will probably let me know πŸ˜‰
                                  Steve Lynchundefined 2 Replies Last reply
                                    Steve Lynchundefined Offline
                                    Steve Lynch
                                    #17
                                    For me, prior to todays update I was able to run android routes most of the time and only encountered the occasional crash of a route instantly on selecting it.
                                    The routes that did occasionally crash first time would then open on a second attempt for me.
                                    I have just tried again on android opening 30 different routes and have not had a crash yet.
                                    I did a test route a couple of days ago on Android using the built in screen recorder on Android.
                                    YouTube unlisted link.
                                    https://youtu.be/S-DyyaN2T1A
                                    Do you think this is a valid way of testing?
                                    The only thing I noticed from the video was that the voice commands would sometimes have a slight glitch, that I think is caused by the fact that the built in Android screen recorder is running in the background?
                                    I will be testing Android and iOS at the same time tomorrow using this method, with a 9” iPad in my Tank Bag and the Android phone on the handlebars.
                                    And of course the Zumo XT in case it all goes pear shaped.
                                      Steve Lynch
                                      Link to unlisted video.
                                      https://youtu.be/HThlLu5EsPs
                                      For me I am still occasionally seeing a route crashing on Android when selecting a route in Beta 3.2.5 - 146.
                                      It seems to be completely random for me and on re-selecting the same route it will then appear.
                                      In the video you will see that the 3rd route I open crashes to the home screen.
                                      Phone: Galaxy S10 5G
                                      Android Version 12
                                      One UI Version 4.1
                                        @Steve-Lynch Thanks, we are aware of this and will resolve it in an early update this year.
                                          Greg
                                          @Greg-Meekings-0 There was another issue that resulted in this route not being loaded. I can confirm this has been fixed now πŸŽ‰
                                          • Corjan Meijerinkundefined Corjan Meijerink referenced this topic on
                                          Greg Meekings 0
                                          Steve Lynch
                                          Jose Pinheiro 0
                                            Massimo Cardoneundefined
                                            Massimo Cardone
                                            6.3k
                                          • Veekeersinfo en omleiden
                                            marko 11 0undefined
                                            marko 11 0
                                          • Choice for starting point of a route
                                            Nick Carthewundefined
                                          • In screen 'Routes & tracklogs' show distance (or time) next to routename
                                            M. Schrijverundefined
                                            38.7k
                                            56
                                            13.0k
                                          • Maximum amount of POI's that can be added ?
                                          • CPMC B6/B7
                                            Leike Lodiersundefined
