  2. Routes & Tracks
  3. Import from Google Maps Link?
19 Posts 10 Posters 6.5k Views 2 Watching
    @David-Skinner
    Hello David, see this post: https://forum.myrouteapp.com/topic/2766/importing-pois-from-google-maps-overlay/9?_=1668320301406
    @Hans-van-de-Ven-MRA-Master that's not what he's talking about. He wants to import routes (not POIs) from Google Maps using a link. I'm pretty sure that's not possible at the moment.
    • David Skinner David Skinner
      Even though I have been using MyRouteApp for some time I have not worked out how to import routes from Google Maps provided as a link rather than in GPX format. Is there a way of doing this? The following link is provided as an example:
      https://goo.gl/maps/F5ohmErDnwjS5t4Y7
      Thanks in advance
      Dave Skinner
      NZ
      Hi @David-Skinner.
      This doesn’t answer your question, but the route that you have shared only contains a few waypoints, it wouldn’t be difficult to reproduce this directly in MyRoute-app.
      David Skinner 1 Reply Last reply
        @Herko-ter-Horst
        aha, ok, I'll just put on my glasses from now on...🙄
          Thanks in advance
          Dave Skinner
          NZ
          Tim  Thompson
          Tim  Thompson
          Tim Thompson
          @David-Skinner said in Import from Google Maps Link?:
          Thanks in advance
          Dave Skinner
          NZ
          Don't believe MRA will do this. I know Scenic has this ability - can import directly from Google Maps and My Maps links.
          Haven't seen any other solution/app that does.
          But, if you are Android only, then Scenic isn't a solution for you at the moment (iOS only). The Android release of Scenic isn't supposed to hit until early next year (according to the developer).
            Hi @David-Skinner.
            David Skinner
            David Skinner
            David Skinner
            @Nick-Carthew It is Nick, but this is just an example and sometimes the routes are much more complex.
            D.
            Drabslab 1 Reply Last reply
              D.
              @David-Skinner
              hai,
              Just out of curiosity: why would you import routes from google maps and not make these directly in the MRA Routeplanner?
              • Drabslab Drabslab
                @David-Skinner
                hai,
                @Drabslab
                Or; why would you make a route yourself in MRA if you got a nice one via a Google link? 😪
                • Drabslab
                  @Jack-van-Tilburg said in Import from Google Maps Link?:
                  @Drabslab
                  Ah, that makes it clear 🙂
                  I thought that what was meant was to prepare a route in google maps and then download this to MRA
                  • Tim  Thompson
                    Tim  Thompson
                    Tim Thompson
                    Or... Maybe you might want to use Google Maps and/or My Maps as a free route planner (or maybe something to augment another planner). It's already been mentioned - somebody could share a Google Maps/My Maps link. If so, would be nice to be able to easly import it.
                    Considering free/alternative route planners... To be honest, I might consider My Maps as a #2 goto - behind Furkot. Scenic's feature to import from Google Maps/My Maps links actually works fairly well.
                    Stanisław 1 Reply Last reply
                    • Tim  Thompson Tim Thompson
                      Stanisław
                      Stanisław
                      Stanisław
                      There is a free tool to quickly convert google maps ling to GPX, whoch could be imported to MRA, maybe it is a solution:
                      (https://www.gpsvisualizer.com/convert_input)
                      Staszek
                      • Stanisław Stanisław
                        @Stanisław
                        That would be nice. But unfortunately it only works if you have an API Key. 😢
                        • TorqueRider TorqueRider
                          @Stanisław
                          Stanisław
                          Stanisław
                          Stanisław
                          @Jack-van-Tilburg I didn't try it recently, pity 😞
                          The same is in case ot Tire application, added to Tomtom.
                          There is a possibility tu use own api key free for limited use but I didn't want to try it.
                          Staszek
                            @Stanisław
                            I think those actions will be too complicated for the average user.
                              @Stanisław
                              Stanisław
                              Stanisław
                              Stanisław
                              @Jack-van-Tilburg For sure... I have moved to MRA with planning and I like it very much, but sometimes someone is sending me simply link to google maps and I have the same problem to open it it MRA.
                              Staszek
                                @Stanisław
                                I have no idea how great the need for this feature is among MRA users.
                                I'm sure there will be an inventory for Roadmap3 in due course and then users can ask for it.
                                  @Drabslab
                                  @Jack-van-Tilburg, @Tim-Thompson and @David-Skinner, I could suggest to ask in a google forum to implement GPX export, but... yeah.... I think we all would do good to teach people who share Google Maps routes that there are better methods for it 😉
                                  Em Pir 1 Reply Last reply
                                    Em Pir
                                    Em Pir
                                    Em Pir
                                    MyRoute-app taught me that there are MANY flavors of gpx files.
                                    Stanisław
                                    Stanisław
                                    Em Pir
                                    Em Pir
                                    Tim  Thompson
                                    Tim Thompson
                                    David Skinner
                                    David Skinner
                                      Matjaz Valjavec
                                      Matjaz Valjavec
                                      randy etheridge
                                      randy etheridge
                                      295
                                    • Question on Beta access
                                    • Add "Upload File"
                                      John Matthews 0
                                      John Matthews 0
                                      Parantapa
                                      Parantapa
                                    • Replies in this section
                                    • On my "Route lab" on my computer, what version
