  3. GPX 1.1, 1.2 and MRA exported routes
gpx 1.2gpx 1.1routesmra connectorvia points
14 Posts 6 Posters 4.2k Views 4 Watching
    If I am correct there is one disadvantage of the 1.2
    You have to be ON the route to start it.
    1.1 navigates you to the starting point.
    Correct?
    Hans van de Ven MR.MRA
    @Arjan-de-Vries
    Hello Arjan,
    Only start the route after you have a complete fix (= at least 3 green lines), so only when the Zumo has found enough satellites and is ready for navigation. If you start the route earlier, you will be sent directly to the 2nd route point via a different route. You will then miss the first part of the route. For example, if you are in a garage, first drive outside and wait until you have a fix and then start the route.
    Arjan de Vries 1 Reply Last reply
      @Arjan-de-Vries
      Hello Arjan,
      Arjan de Vries
      Arjan de Vries
      Arjan de Vries
      @Hans-van-de-Ven-MRA-Master And if I put the first point somewhere a street further from my house , start the route at my house (outside) and choose "go to the beginning"? Then it will go to the first pint and after that go to the second? (I am not able to test this now)
      Hans van de Ven MR.MRA Drabslab 2 Replies Last reply
        @Arjan-de-Vries
        Then you go to the starting pointπŸ‘
          @Arjan-de-Vries i have two favorites, both 100 m from my house, one is called "home start" ,the other one home end.
          For each jotel along the route, my endpoint is the exact address of the hotel or the most convenient parking spot. The next days route has a beginning up to 1km from the hotel
          • Drabslab Drabslab
            Steve Jarrell
            Steve Jarrell
            Steve Jarrell
            @Drabslab I do exactly the same way. As many others have done, I had to learn the hard way why it's a bad idea to put your starting point exactly where you are!
            Steve
            Steve Jarrell
            Western North Carolina US
            2025 BMW R1300GS
            2025 Can-Am Spyder
            DMD T865-X 8" Tablet
            Garmin XT3
            • Jay Potter 0
              Jay Potter 0
              Jay Potter 0
              This topic is interesting to me as a Novice creating GPX files using a number of free apps & now MyRouteApp. How can I tell if the resulting GPX file is in format 1.1 or 1.2?
              • Jay Potter 0 Jay Potter 0
                @Jay-Potter-0
                Hello Jay, gpx 1.1 is a file with shaping- and viapoints
                Gpx 1.2 is a file with only viapoints
                  @Jay-Potter-0
                  Steve Jarrell
                  Steve Jarrell
                  Steve Jarrell
                  @Hans-van-de-Ven-MRA-Master said in GPX 1.1, 1.2 and MRA exported routes:
                  @Jay-Potter-0
                  Do you possibly have this backwards? I believe that 1.1 only has the beginning and ending viapoints and the rest are shaping points, whereas 1.2 can have multiple viapoints and shaping points.
                  Steve
                  Steve Jarrell
                  2025 BMW R1300GS
                  2025 Can-Am Spyder
                  Garmin XT3
                  Steve Lynch Hans van de Ven MR.MRA 2 Replies Last reply
                  • Steve Jarrell Steve Jarrell
                    @Jay-Potter-0
                    Steve
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @Steve-Jarrell
                    I won’t mention the 590 as I have no experience with that device.
                    On the XT, both GPX 1.1 and GPX1.2 can contain Via Points and Shaping Points.
                    The difference is that GPX 1.1 will show the Via Points and the Shaping Points visibly on the XT Map and the Via Points will announce themselves visibly on the XT Screen as you approach them.
                    Shaping Points never announce themselves.
                    GPX 1.2 will only visibly show Via Points on the XT Map and they will announce themselves visibly on the XT Screen as you approach them.
                    With GPX 1.2 Shaping points are hidden on the XT Map but they are still used to Shape the Route.
                      @Jay-Potter-0
                      Steve
                      @Steve-Jarrell
                      Steve
                      gpx 1.1 Route with shaping points (balls) and viapoints (Flags)
                      You can leave the recalculation on on the Zumo XT, if you deviate from the route you will be brought back to the route (to the nearest ball or flag)
                      gpx 1.2 Route-Track via viapoints (Flags)
                      You must turn off the recalculation on the Zumo XT, if you deviate from the route you will have to drive back to the route on sight. If you leave recalculation on you will be directed to the next flag according to the settings on the Zumo.
                      Steve Jarrell
                      Steve Jarrell
                      Arjan de Vries
                      Arjan de Vries
                      Steve Lynch
                      Steve Lynch
                      Jay Potter 0
                      Jay Potter 0
                        Mike wiruth
                        Mike wiruth
                        644
                      • Recent trip made hard !
                        193
                        Kirsten De Weerd
                        Kirsten De Weerd
                      • best format to download
                        Guzt
                        Guzt
                        312
                      • Frozen marker.
                      • How do you download maps
                        Mike wiruth
                        Mike wiruth
                      • Kan keuze voor voertuigbeperking worden ' onthouden' ?
