  3. Use of basecamp
Use of basecamp
15 Posts 6 Posters 2.2k Views 1 Watching
  • Steve Lynchundefined Steve Lynch
    @Arjan-de-Vries
    If you look at the very bottom of the right corner of the Here map you will see the following.
    Maybe someone from MRA can clarify?
    @Steve-Lynch While I'm not sure why the copyright message doesn't seem to be up-to-date, I'm certain the maps are (pretty much) up-to-date, at least judging by some of the roads close to where I live that have changed in the last 6 months.
    Steve Lynchundefined 1 Reply Last reply
      Steve Lynchundefined Offline
      Steve Lynch
      @Herko-ter-Horst
      My son lives in the vacinity of Fern Grove.
      Take a look at the differences between the Here and OSM Maps below.
      Here Map
      OSM
      • Herko ter Horstundefined Offline
        What's your point? That maps from different suppliers differ?
        BTW, this is the (c) 2022 map from https://wego.here.com/:
        And this is the same area in the (c) 1992-2022 version of TomTom MyDrive:
        If there's information missing, you can report it to HERE and TomTom directly using those websites. In my experience with TomTom, any changes I've reported have shown up within a few weeks in MRA as well.
          @Drabslab said in Use of basecamp:
          @Arjan-de-Vries no, absolutely not. Mra routeplanner is much better than basecamp. πŸ€—
          I gave not heard any complaints about the mra here map being outdated. I assume that mra works over a cloud connection to here and therefore always has the most recent versiob.
          Which means the map in Basecamp/on the Zumo is more likely to be "outdated", even if it's the most recent one available.
          So it could make sense to check if there are no differences with the map in Basecamp. However, you'll encounter "issues" even if the map matches 100%, for example due to temporary closures/road works/etc. I just tend to deal with those as I encounter them and I treat any differences due to map versions that are potentially still there in the same way as well.
          Drabslabundefined Online
          @Herko-ter-Horst to my knowledge, and i dont know about the policies of garmin or mra, there is no guarantee that the basecamp map and the maps on zumo are identical.
          For comparison sake only, microsoft tends to update some regions earlier than others.
          Drabslabundefined Herko ter Horstundefined Con Hennekensundefined 3 Replies Last reply
          • Drabslabundefined Drabslab
            In all honesty, i dont worry about this too much. Usually, roads are added, not removed and i guess that old roads continue to exist. Maps, whether on paper or digital, become outdated. This is most obvious with speed restrictions. Counting on your gps to avoid tickets is not a good approach. Routing and a nav app are tools, the most important part on the road is to keep your eyes open.
              Could be. On my older device, I can use the exact maps from the device itself in Basecamp (with the device connected via USB), 100% guaranteed to be same.
              • Arjan de Vriesundefined Arjan de Vries
                Hi,
                I have a gold membership. Make all my routes in MRA.
                I have a zumo XT.
                Do you check the route in basecamp?
                I ask this because I think that the here map in MRA is not the same as the (Up to date) map in the Zumo.
                Am I right?
                Thanks,
                Arjan
                @Arjan-de-Vries
                The roads can sometimes be drawn in a slightly different place.
                  To my knowledge, basecamp and zumo are updated from the same source. So if you update both, they should be exactly equal.
                  I think I have read on this forum before, that the Here mapsource (no not program!) for the planner and the Navigation app are not identical, and therefore small changes can exist due to differences in update schedules. It has not bothered me though. With clever use of waypoints the chance of noticeable difference is almost zero, and the ones I don't notice, well... I don't notice... πŸ˜‰
                    @Con-Hennekens said in Use of basecamp:
                    Yes they most likely are. But that do3sn't meab that they are updated at the same moment
                      Yes, but that renders it a user-error instead of a platform mis-design. Does Garmin Express not update both simultaneously (if you let it do that)?
                      Arjan de Vries
                      Drabslabundefined
                      Steve Lynch
                        Peter Zehentreiterundefined
                        6.3k
                      • Maximum amount of POI's that can be added ?
                        Nick Carthewundefined
                      • App friert ein
                        Travellexxieundefined
                      • Anyone with CPMC B6?
                        1.5k
                      • Hoe een kaart met bepaalde plaatsen als POI aanmaken.
                      • Mi spiegate che problemi ha ???
                        Albyusundefined
                        Albyus
                        378
                      • Mac to Garmin Zumo XT* GPX Transfer
                        Steve Jarrellundefined
                        Steve Jarrell
                        853
                        38.3k
