  3. Zumo XT MAC gpx1.2
Zumo XT MAC gpx1.2
14 Posts 4 Posters 3.5k Views 2 Watching
  • Johan Gustavsson Johan Gustavsson
    Hello!
    Is it only me having problem to export with gpx1.2 with mac, there is no option to select 1.2?
    With my PC it works fine.
    @johan-gustavsson
    Will this help you?
    Garmin Zumo XT <-> Mac... (click)
    Johan Gustavsson 1 Reply Last reply
    • TorqueRider TorqueRider
      @johan-gustavsson
      Will this help you?
      Johan Gustavsson
      Johan Gustavsson
      Johan Gustavsson
      @jack-van-tilburg I have Android file tranfer installed and I can copy files to the XT.
      But I wan´t to use cable and send via connector.
      TorqueRider Reinhard-32 2 Replies Last reply
        @johan-gustavsson
        Not funny!
        Look at this instruction:
        (Source)
        Exporting a gpx 1.2 route to your Garmin Zumo
        A gpx 1.2 file consists of waypoints and the track with possibly poi's (points of interest). Exporting to your Garmin follows the same procedure as gpx 1.1, only choose Garmin Zumo (GPX 1.2) in the connector. You can now also import the route and you will see the route in the 'Travel Planner'. The difference is that no formation points are now shown, only the via points in the form of orange flags. If you click on the 'Map', you will only see the flags. The route between the flags is a track and that is very different from navigating via the route, more about that below.
        But this is what I see:
        No GPX 1.2
          @johan-gustavsson I have an iMac and it is not possible to send Data from MRA via connector to the ZumoXT.
          Kindly regards
          Reinhard
          Montana 700i and Mac
          • Reinhard-32 Reinhard-32
            @reinhard-32 @Johan-Gustavsson
            Michel van Hagen's Blog does not describe an exception for Mac.
            Maybe a good reason to create a ticket in the 'Support' section?
              @jack-van-tilburg
              I think it is because you can only have 1 open system connected to the Mac.
              Filetransfer is 1
              Connector is 2
                @jack-van-tilburg
                Filetransfer is 1
                Connector is 2
                @hans-van-de-ven-mra-master
                That could be.
                But I use a pre M1 Mac and don't see the choice for GPX 1.2.
                (I'm pretty sure I used it for my BMW Nav XI)
                I only have an old Garmin Zumo 590 so can't test 😞
                  That could be.
                  @jack-van-tilburg
                  Then create a support ticket that gpx 1.2 is not available in the connector on a Mac
                    @jack-van-tilburg
                    I don't think it's helpful if I do that because I'm not a user of this feature.
                    Good action for @Johan-Gustavsson of @Reinhard-32.
                      @jack-van-tilburg In the meantime I have opened a ticked according this problem.
                      Kindly regards
                      Reinhard
                      TorqueRider Johan Gustavsson 2 Replies Last reply
                        @reinhard-32 👍
                          Johan Gustavsson
                          Johan Gustavsson
                          Johan Gustavsson
                          @reinhard-32 👍
                            @johan-gustavsson
                            Not funny!
                            (Source)
                            No GPX 1.2
                            Johan Gustavsson
                            Johan Gustavsson
                            Johan Gustavsson
                            @jack-van-tilburg 👍
                            Johan Gustavsson
                            Johan Gustavsson
                            • Route wordt afgesneden
                              Wim Hompes
                              Wim Hompes
                            • Map colours and side roads
                            • OSM Routing with MRA
                              Pierre c
                              Pierre c
                            • reuse pictures
