Feature suggestion - Option to show routes in folder in an overview
Hi,
MRA is perfect for creating routes, really like it. When I'm planning for a biketrip, I create a folder for this. I like to keep things organised.
Usually I first make the overview and select a number of highlights. After that I create a route per day. The overview though, still has value to me. So I try to keep that 'up-2-date'.But it gets painful to keep the routes per day 'in sync' with the overview. I know one can open a route, and then 'add' other routes with different colors. Nice feature, but is not what I mean, because I always need to start 'editing' a route and then add the other routes.
Also, keeping the overview up-2-date get's more painful with a longer trip. Because of the calculation that needs to be done when changing the route a bit.What I would appreciate is the ability to select a couple of routes (all?) in a map, and then have the ability to show them 'read-only' in an overview. Now I can select routes, and then copy/move/delete them. A new button there to generate the overview, would be great!!!
The card material used for calculating the routes, should be the chosen default of the user.Nice to have:
- alternating colors for each route
- ability to choose coloring
- when hovering over a route in the overview a text showing the source route
- total length
- export to csv: name, start-name, start-address, end-name, end-address, length, duration
Hi,
- total length
@gert-jan-hiddink The developers are currently working hard at getting some updates done, see Michelās blog READ BLOG
I have asked if an overview of all routes in a folder is possible and could we have it in a future update. The answer was: This should be possible although they need to finish the current list of updates.
With your input, this post could be even better š
