  3. Route selection in "add Route"
3 Posts 3 Posters 538 Views
  • Josan 0undefined Offline
    Josan 0
    When you are editing a route and would like to add another from you library, in the "add route" menu they are ordered by modification date.
    Is there any way to find the route you are looking to add? If you have many is very difficult to find the one you want.
    • Josan 0undefined Josan 0
      Jack van Tilburg
      @josan-0
      Unfortunately, the order cannot be adjusted in this case.
      But maybe it's an idea to put the routes, you want to use, together in a folder and then click that folder (and then your route to add) when adding your routes.
        @josan-0
        Drabslabundefined Offline
        @jack-van-tilburg I agree. It is usually a bad idea to work directly with your "historical" routes as the risk is high that you would unintentionaly change them.
        Your approach is much safer.
        Jack van Tilburg
        Drabslabundefined
        Josan 0undefined
        Josan 0
        • 3 Devices and only 1 using NN.
          Big Al 1undefined
          Big Al 1
        • Segmentation
          Lenny Oundefined
          Lenny O
        • Onbekende fout, 3 problemen
          Klompenmaker1undefined
          Klompenmaker1
          392
          Thomas Neumeyerundefined
          Thomas Neumeyer
          1.7k
        • erratic routing instructions
        • Route opslaan op Pc vanuit telefoon MRA app
