  3. Avoidances/preferences
5 Posts 3 Posters 929 Views 1 Watching
  • Ian Batterhamundefined Offline
    Ian Batterham
    Is it possible to use avoidances (Google Maps) or preferences (Garmin) such as motorways, ferries, etc. as in Basecamp image below?
    • Ian Batterhamundefined Ian Batterham
      Reinhard-32undefined Offline
      @ian-batterham As a gold member you have some choices depends on the map.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      Ian Batterhamundefined 1 Reply Last reply
        Ian Batterham
        @reinhard-32
        Hi Reinhard, the only option I have available on both mobile and iMac versions is "Offroad".
        PAD 0undefined 1 Reply Last reply
          @reinhard-32
          PAD 0undefined Offline
          PAD 0
          Hi @ian-batterham. If you haven’t subscribed to Routeplanner then your only routable map option is OpenStreetMap. Off road is the only routing option in this case.
          If you have subscribed then select the Page Menu button, from the drop down select Default (OpenStreetMap) and change to either TomTom or Here (for Garmin) depending on your needs. Then, in Toolkit, you will have a few more routing options.
          • PAD 0undefined PAD 0
            Ian Batterham
            Thanks @pad-0, I hadn't realised that certain functions only apply to specific maps.
            Ian Batterham
            PAD 0undefined
            PAD 0
            • Manual 'Compare Route calculation'
              Nick Carthewundefined
              Peter Zehentreiterundefined
            • A few observations
              Thomas Miklundefined
              Thomas Mikl
              Herman Veldhuizenundefined
            • Hull to Rotterdam ferry not recognised
              Steve Jarrellundefined
              Steve Jarrell
              1.7k
            • Color of Via points issue
            • Hoe een kaart met bepaalde plaatsen als POI aanmaken.
              nomkoundefined
