  3. Avoidances/preferences
5 Posts 3 Posters 1.2k Views 1 Watching
  • Ian Batterham
    Ian Batterham
    Ian Batterham
    Is it possible to use avoidances (Google Maps) or preferences (Garmin) such as motorways, ferries, etc. as in Basecamp image below?
    • Ian Batterham Ian Batterham
      @ian-batterham As a gold member you have some choices depends on the map.
      Kindly regards
      Reinhard
      Montana 700i and Mac
      Ian Batterham 1 Reply Last reply
      • Reinhard-32 Reinhard-32
        Ian Batterham
        Ian Batterham
        Ian Batterham
        @reinhard-32
        Hi Reinhard, the only option I have available on both mobile and iMac versions is "Offroad".
        PAD 0 1 Reply Last reply
          @reinhard-32
          PAD 0
          PAD 0
          PAD 0
          Hi @ian-batterham. If you haven’t subscribed to Routeplanner then your only routable map option is OpenStreetMap. Off road is the only routing option in this case.
          If you have subscribed then select the Page Menu button, from the drop down select Default (OpenStreetMap) and change to either TomTom or Here (for Garmin) depending on your needs. Then, in Toolkit, you will have a few more routing options.
          • PAD 0 PAD 0
            Ian Batterham
            Ian Batterham
            Ian Batterham
            Thanks @pad-0, I hadn't realised that certain functions only apply to specific maps.
            Ian Batterham
            Ian Batterham
            PAD 0
            PAD 0
              869
              Andy Beviere
              Andy Beviere
            • Trips in Commercial Clubs?
              Mike West
              Mike West
            • The ‘Start route here’ option doesn’t seem to be working properly.
              Parantapa
              Parantapa
              Marcel Versluis
              Marcel Versluis
            • Exporting GPX
              smfollen 0
              smfollen 0
            • Na rit vanuit event geen tracklog
              Hanza 0
              Hanza 0
