  2. New Users' corner
  3. Evening all
Evening all
18 Posts 11 Posters 5.7k Views 1 Watching
  • Paul Phillips 2
    Paul Phillips 2
    Paul Phillips 2
    Just signed up to this for a year after procrastinating about it for a while as it seems like a decent app for planning and navigating routes. I am intending to do a trip to the Pyrenees in June on my ride, fing covid allowing. Hope to cross from Irun to Perpignan and have given myself about 12 days to do this, plus travel from London via Dieppe and back. If anyone has done this and have any hints tips and advice would be greatly appreciated, Hopefully attached is the route I have planned so far
    https://www.myrouteapp.com/route/open/5393241
    HABVEN aka MrMRA Nick Carthew PAD 0 Conor Doherty 4 Replies Last reply
    • Paul Phillips 2 Paul Phillips 2
      @paul-phillips-2
      Hi Paul, welcome to the forum, your holiday through the pyrenees promises to be a beautiful one, the route you have set up looks promising.
      Have you already looked in the RouteXpert library? You can probably find tips for your trip there, and also take a look at Michel's travel story, he went to the pyrenees with Serge last year.
      Paul Phillips 2 1 Reply Last reply
        Hi @paul-phillips-2 Welcome to the forum. You haven't mentioned what satnav device you will be using, I ask this because you have planned your route on the (Default) OpenStreetMap. If you are using MRA Navigation or a Garmin device, it would be better to use the Here map or plan your route on the TomTom map if using a TomTom.
        I would also suggest taking a ferry to Spain to start your tour, yes it's more expensive but when you cost in the price of the channel crossing, fuel, wear and tear and probably one night in a hotel, there's not much in it, plus your holiday starts as soon as the ferry docks. The ferry leaves Plymouth about 5pm and arrives in Santander about 2pm the next day.
        Where do you propose stopping each night? What are the route point numbers on your route for your overnight stops? Accomodation tends to be cheaper on the Spanish side.
          PAD 0
          PAD 0
          PAD 0
          Hello @paul-phillips-2. Your route looks like it should be very entertaining. I zoomed in on a few waypoints at random and found several that were not placed accurately on the road. Regardless of device or app used, this can cause problems in navigating a route if not corrected. Some of the waypoints checked cause a turn in the opposite direction to that clearly intended, followed by the need for a U turn after a short distance. I recommend you zoom to the maximum into each waypoint on your route and, where necessary, reposition accordingly.
          If you do decide to use a map layer other than Open Street Map, as suggested by @Nick-Carthew, it would be best to change that first and then sort out the waypoints. Differences in spatial data between map layers can vary the position of roads enough to leave you back at square one if you donโ€™t do it in that order.
          Have a great trip.
            @paul-phillips-2
            Paul Phillips 2
            Paul Phillips 2
            Paul Phillips 2
            @hans-van-de-ven-mra-master Thanks Hans will definitely take a look at those thanks for the tip
              Paul Phillips 2
              Paul Phillips 2
              Paul Phillips 2
              @nick-carthew Thanks Nick, think I'm going to be using the MRA Navigation using my mobile bought it with the Myroute app and going to use it for work to get used to it instead of google maps. Was umming and arghing about taking the ferry to Santander but fancy the ride up the South West coast of France as me and the missus were doing this four years ago in the car but had a family emergency in Poland so had to leg it from La Rochelle to Krakow so we never got to finish it so my holiday will start in Dieppe :-). Not booking anything until the afternoon of the day as want to take the journey as it comes and use booking dot com and similar apps, if I finish it or not doesn't matter as done a couple of trips on the scooter before with other people and the worst bit is trying to get to a destination by a certain time/date and you go past stuff but don't have time to explore. Really appreciate the tip about the Spanish side being cheaper as that could be a factor
              • PAD 0 PAD 0
                Have a great trip.
                Paul Phillips 2
                Paul Phillips 2
                Paul Phillips 2
                @pad-0 cheers for noticing that will sort that out, haven't really finalised the Pyrenees part of the journey as was hoping for some input from anyone who had done the journey or parts of it before. Think the run up to Irun from Dieppe has been finalised. Having never used this before if you have a planned route but go off it for some reason is there a way to redirect or does it sort it self out once back on route? I know having done this with google maps it's a bit of a pain if for example a road is closed and you need to divert
                  @paul-phillips-2 MRA Navigation will automatically skip one shaping point (ballon shape marker) if you miss it and direct you to the next waypoint. If you need to skip more, select edit and choose how many waypoints you need to skip. Via points (hand shaped) will not be automatically skipped.
                    Paul Phillips 2
                    Paul Phillips 2
                    Paul Phillips 2
                      Conor Doherty
                      Conor Doherty
                      Conor Doherty
                      @paul-phillips-2 Hi Paul,
                      Just had a look at your Route. Looks great. Can I suggest you Stop in Collioure, which is 30 mins before Perpignan- Its a jem!
                      Nick Carthew Malik Malik 0 2 Replies Last reply
                      • Conor Doherty Conor Doherty
                        @conor-doherty said in Evening all:
                        +1 for stopping at Collioure ๐Ÿ‘
                          Malik Malik 0
                          Malik Malik 0
                          Malik Malik 0
                          This post is deleted!
                          • Malik Malik 0 Malik Malik 0
                            [[topic:post-is-deleted]]
                            @malik-malik-0
                            • sudolea
                              sudolea
                              sudolea
                              De trollen zijn aktief vandaag, blijkbaar ๐Ÿค”
                              • Nick Carthew
                                Our spammer is now banned ๐Ÿ‘๐Ÿผ
                                • TJ189
                                  TJ189
                                  TJ189
                                  Welcome Paul
                                  Enjoy your time on the forum, some great support available.
                                  phighhi apk 0 1 Reply Last reply
                                  • TJ189 TJ189
                                    Welcome Paul
                                    phighhi apk 0
                                    phighhi apk 0
                                    phighhi apk 0
                                    • Eagle Books 0
                                      Eagle Books 0
                                      Eagle Books 0
                                      Paul Phillips 2
                                      Paul Phillips 2
                                      sudolea
                                      sudolea
                                      TJ189
                                      TJ189
                                      Eagle Books 0
                                      Eagle Books 0
                                      phighhi apk 0
                                      phighhi apk 0
                                      Malik Malik 0
                                      Malik Malik 0
                                      PAD 0
                                      PAD 0
                                      Conor Doherty
                                      Conor Doherty
                                        Karel76
                                        Karel76
                                        11.2k
                                      • Strange translation
                                        44
                                      • Undo/Redo tool is hidden
                                      • A07 Shared Route Collaboration โ€“ Change Log?
                                      • I need help with the track navigation settings
                                      • Shared toggle switch
