  3. Export 1.2 gpx
Export 1.2 gpx
43 Posts 11 Posters 25.3k Views 4 Watching
    @Dave-J-0
    Hi Dave,
    If you use / import route from the gpx 1.0 and gpx 1.1 into your Zumo, all formation points are seen as waypoints, therefore you will get the message that the route is being split.
    The advice was always to use the Track. With the release of the XT, the Beta version of the gpx 1.1 was used to test whether
    the via points could be worked. So the waypoints only worked on the XT, but not on the older Zumos because all formation points were seen as waypoints, and you don't want that either. How Garmin handles this is Garmin's secret and they won't reveal it.
    I will submit the request for Beta version for the XT to MRA.
    Stefan Trucksäß
    Stefan Trucksäß
    Stefan Trucksäß
    @Hans-van-de-Ven-MRA-Master
    I created a new route for testing and testet it last Sunday.
    The good news: the route works. But shaping points are not displayed but they are existing. The defined route with all detours shows it.
    Unfortunately there are a few points to criticise:
    The import in the navigator, - i.e. the time the navigator needs to import the route - is veeeeery slow. A route with 8 viapoints and 29 shaping points needed more than 6 minutes. With Beta 1.2, such a route needed about 30 seconds. ????
    Shaping points are not displayed after the import. Neither in the map nor in the list. If I have to make a change in the navigator on the way (e.g. when a street is blocked), how can I change a shaping point into a via point? I can't. I can change a via point into a shaping point in the navigator. The shaping point then will be displayed. The recalculation now takes a few seconds.
    The export (Save as) with GPX 1.2 works. In other programmes like Tyre or ITN converter only via points are imported, in kuviger.de via and shaping points. After copying a GPX-file edited by kuviger.de into the Navigator, only Viapoints are displayed again.
    Despite all the joy that GPX 1.2 finally works on the Navigator, the lack of shaping points is a clear step backwards. I can only agree: please bring back the shaping points.
    Grüße aus dem Schwabenland
    Stefan
    • Stefan Trucksäß Stefan Trucksäß
      @Stefan-Trucksäß
      Hallo Stefan,
      Lesen Sie sorgfältig, das gpx 1.1 hat sowohl Formation als auch Wegpunkte. Funktioniert nur bei Zumos mit NTU-Karte, also auch beim Navigator 6. An der Langsamkeit des Imports können wir nichts ändern, es hängt vom Gerät ab, wie schnell es die Daten verarbeiten kann.
      Stefan Trucksäß 1 Reply Last reply
        @Stefan-Trucksäß
        Hallo Stefan,
        Stefan Trucksäß
        Stefan Trucksäß
        Stefan Trucksäß
        wrote on last edited by Stefan Trucksäß
        #29
        Hello Hans,
        GPX 1.1 can transmit shaping points and via points, Obviously. However, when importing GPX 1.1, only shaping points are transferred. I have to change the shaping points into via points manually. Why should I do this when GPX 1.2 transfers BOTH types. The shaping points are there, you just should make them visible and editable again.
        Since yesterday I have a Zumo XT. The import is indeed much faster than with Navigator 6.
        Stefan
        HABVEN aka MrMRA Steve Lynch 2 Replies Last reply
          Hello Hans,
          #30
          @Stefan-Trucksäß
          When you are in the planner, change a shapingpiont into a viapunt. Then export to the device
          • Steve Lynch Steve Lynch
            I have to agree with all the other users who are saying that we want to actually see the shaping points (Blue Dots) on the XT map.
            As we could on the XT with the previous Beta version.
            My personal preference is to never use Via Points.
            When I create a new route I don’t know at what point I might need a coffee or at what point in time I am going to get hungry.
            I like to make those decisions whilst actually riding the route.
            What do i do if I want to skip part of the of the route for some reason?
            If we can’t see the shaping points how can we skip them?
            Nick Dawson
            Nick Dawson
            Nick Dawson
            @Steve-Lynch I use viewpoints for coffee stops and lunch stops as this is another way of making sure that everyone in a group gets to the same place and a chance for stragglers to catch up. Having a coffee stop mid morning then lunch etc. means that if someone falls behind, they are never that far behind.
            Like you, skipping a shaping point causes a problem. Perhaps there are roadworks or a diversion. If you skip and go to the next point, the GPS will skip the next viapoint (ignoring the viapoint).
            To get round this I publish two files for each route with the 2nd one having all the shaping points converted to a viapoint and, to keep them tidy, I rename them with the prefix Z which means that you can find them if needed but they are not mixed in with your normal day to day files.
            Another option would be to pass the diversion following the signs then start the route again with the next point being the next viapoint. This would however skip any shaping points that you had planned.
            I am of course working with groups of Riders. Had I been solo, I would do as you do and not plan coffee stops etc.
            • Nick Dawson Nick Dawson
              Steve Lynch
              Steve Lynch
              Steve Lynch
              @Nick-Dawson
              90% of the time I prefer to travel alone. (Billy No Mates or maybe Victor Meldrew 😁).
              I live in London but my Biker Mates are mostly down the South Coast, from Brighton to Eastbourne, generally I meet up with them only during the summer month’s, except one in particular that I went to School with and often ride to him for a stay over consisting of beer, curry and the obligatory hangover.
              Generally this crowd stay around the south coast area and generally one them will lead as they have the better local knowledge of the South Coast.
              • Bepperling
                Bepperling
                Bepperling
                The same effect, when exporting direct to BMW Navigator. It's not uasable.
                Friedhelm
                • Bepperling Bepperling
                  Friedhelm
                  @Bepperling
                  Which Navigator do you have the 5 or the 6?
                  With the navigator 5, it uses the NT map, it doesn't work, just like the older zumo's.
                    Hello Hans,
                    Steve Lynch
                    Steve Lynch
                    Steve Lynch
                    @Stefan-Trucksäß
                    Good choice on updating to the Garmin XT. 👍
                    I have had mine for a while now and in my experience the plethora of recent updates by the MRA Devs have made the XT even better.
                    Happy days.
                      @Stefan-Trucksäß
                      Happy days.
                      Stefan Trucksäß
                      Stefan Trucksäß
                      Stefan Trucksäß
                      @Steve-Lynch said in Export 1.2 gpx:
                      My Navigator 6 had ghosting. My BMW dealer offers as an exchange only the XT, because the ghosting occurs again sooner or later with a new NAvigator. Because the XT is a new device, I have again a warranty of 2 years. 😊
                      Stefan
                        @Henrik-Müller
                        Use via-points in your route, otherwise use gpx1.1
                        Kevin Buckley
                        Kevin Buckley
                        Kevin Buckley
                        @Hans-van-de-Ven-MRA-Master I just wanted to agree with other replies in this thread. In the past I would have the formation points (blue dots) and waypoints (flags). I would often put multiple waypoints (flags) that I may stop at and I wanted announced, knowing I would stop at some and skip some depending on how the day went. In the past I would have the one skip button on my Zumo xt and I would skip waypoints (flags) but because of all the formation points (blue dots) the overall navigation would stay intact.
                        Now when I first load the trip into my Zumo the track looks good and the navigation is accurate even without the blue dot formation points. However the first time I skip something on my route the Zumo recalculates everything without any regard to the formation points that would have been there in the past and I get a direct route to my next flag point rather than the planned route between the flags I had.
                        I bought the garmin xT specifically because of how MyRoute-app and the xT worked well together, with this change to the beta 1.2 export my Zumo really no longer does the things I need it to do. If you could restore the functionality it would be greatly appreciated.
                        • Kevin Buckley Kevin Buckley
                          Steve Lynch
                          Steve Lynch
                          Steve Lynch
                          @Kevin-Buckley
                          This was resolved.
                          Use GPX 1.1 (Route, Track, POI)
                          That will give you the Via Points and Shaping Points on the XT.
                          Kevin Buckley 1 Reply Last reply
                            @Kevin-Buckley
                            This was resolved.
                            Kevin Buckley
                            Kevin Buckley
                            Kevin Buckley
                            @Steve-Lynch
                            Thanks, will change my export choice going forward.
                            • Robert Bürgisser
                              Robert Bürgisser
                              Robert Bürgisser
                              Hello, I read all the posts carefully and I am very grateful for the good tips.
                              I come to the conclusion that I have to choose the export variant «Garmin (GPX 1.1)».
                              I tested it and saw that I see shapingpoints and viapoints on the Zumo XT, as desired. If I choose the export variant Garmin Zumo (GPX 1.2), I see only the viapoints.
                              For testing, I saved the GPX 1.2 variant and opened it in Basecamp. After a recalculation of the route BC tinkers a completely wrong route - and exactly that happens in the device.
                              With the GPX 1.1 variant, shaping points and viapoints are present and the route follows the track exactly.
                              What advantage does the GPX 1.2 variant have? I see only one serious disadvantage, namely the lack of transmission and visibility of the shaping points.
                              • Robert Bürgisser Robert Bürgisser
                                @robert-bürgisser
                                Hello Robert,
                                Gpx 1.2 is a so called inflated route. If you use the 1.2 file turn off recalculation in your Zumo.
                                Don’t use it in Basecamp because then you won’t get the route as planned
                                • Robert Bürgisser
                                  Robert Bürgisser
                                  Robert Bürgisser
                                  Thanks for the quick reply Hans! Aha, that is a good insight. So I can assume that the route was stored correctly in the device after the export with GMX 1.2.
                                  I will test both possibilities (1.1 and 1.2) and report.
                                    @robert-bürgisser
                                    Yes, you can assume that both files, gpx 1.1 and gpx 1.2, work correctly in the new Zumo. Make sure you transfer the files with the connector or save them as from MRA to your Zumo.
                                    Nick Dawson
                                    Nick Dawson
                                    Henrik Müller
                                    Henrik Müller
                                    Guzt
                                    Guzt
                                    Kevin Buckley
                                    Kevin Buckley
                                    Steve Lynch
                                    Steve Lynch
                                    Robert Bürgisser
                                    Robert Bürgisser
                                    Stefan Trucksäß
                                    Stefan Trucksäß
                                    Bepperling
                                    Bepperling
                                    • Kaart niet zichtbaar
                                      219
                                    • Route omzetten naar een track
                                      Jeroen ekkel c
                                      Jeroen ekkel c
                                    • Xpert overlay not clear
                                      Corrado Miniati 0
                                      Corrado Miniati 0
                                    • Trains like Ferries?
                                      Corrado Miniati 0
                                      Corrado Miniati 0
                                    • Current city/village name instead of the street name
                                      Hanza 0
                                      Hanza 0
                                    • Vermijdingsopties is wat verwarrend
                                      Eric Bovelander
                                      Eric Bovelander
                                      Bé Jeuring
                                      Bé Jeuring
                                      22
                                      41
                                      383
