  3. Apple Car Play and MRA Navigation
14 Posts 6 Posters 4.2k Views 1 Watching
  • Michael Fergusonundefined Offline
    Michael Ferguson
    Couple questions….. Am I to understand that MRA navigation is available for usage within Apple Car play? And if so how do you access it?
    Thanks,
    Mike
    • Michael Fergusonundefined Michael Ferguson
      Thanks,
      Mike
      Nick Carthewundefined Offline
      @Michael-Ferguson Yes, you’ll need a subscription for MRA Navigation and away you go.
      Michael Fergusonundefined 3 Replies Last reply
        Michael Ferguson
        @Nick-Carthew
        I have a subscription and I don’t see where the Nav app is available within Apple Car play!
        Away you go….. how? Have you used the app in Apple Car play yet?
          Michael Ferguson
          @Nick-Carthew
          Looks like a new version of the Nav app came out recently and you have to update! Never saw this in print anywhere. I updated but still don’t see the app as available via car play on my phone…. I will go out to my car and try it soon! And or restart my phone.
            Michael Ferguson
            @Nick-Carthew
            I restarted/rebooted my phone and there it was…. Went out to my vehicle….. played with it… absolutely fantastic!! Can’t wait to use it more! My go to Nav App for my SVU now also!
            • David McCoyundefined Offline
              David McCoy
              I started a 7 day trip in the US today and will be using MyRouteapp Navigation with CarPlay. I encountered an issue today when I stopped for lunch. I disconnected my phone and had lunch. When I returned to my car and plugged my phone in and started CarPlay, I had to restart my route. This caused me to have to delete my beginning waypoint so that the route would start up where I was on the route. I never could get the route to start up after deleting the waypoint. I need some instructions on how to use the Nav app on CarPlay if you have to restart the route after driving for several hours.
              • David McCoyundefined David McCoy
                @David-McCoy Turn off - Navigate via Start.
                This can be found when you select your route. Click Edit Route Settings. 97695158-D34E-4688-AAF8-4BDB21651815.png
                • giovanni monicoundefined Offline
                  giovanni monico
                  Good evening
                  I am also a subscriber of my route app but I cannot pair it with the apple car play of my Mercedes and my Honda Goldwing motorcycle,
                  I await your instructions
                  Thanks
                  Reinhard-32undefined Herko ter Horstundefined 2 Replies Last reply
                  • giovanni monicoundefined giovanni monico
                    Good evening
                    Thanks
                    Reinhard-32undefined Do not disturb
                    @giovanni-monico You need an USB cable to connect your phone to the car. The bluetooth connection doesn’t work for apple car play.
                    Kindly regards
                    Reinhard
                    Montana 700i and Mac
                      Good evening
                      Thanks
                      @giovanni-monico Just making sure: do you have a subscription to MyRoute-app Navigation and do you have that app installed on your phone? It's a separate app from the standard app and it needs a separate subscription. Only Navigation supports Car Play.
                      giovanni monicoundefined 1 Reply Last reply
                        giovanni monico
                        @herko-ter-horst ho l'app installata sul telefono ma non funziona, non compare nessuna icona sull'auto
                          @giovanni-monico Your phone is connected via USB cable to your car / motorcycle?
                          Kindly regards
                          Reinhard
                            giovanni monico
                            @reinhard-32
                            👎 Yes !!!
                              @reinhard-32
                              👎 Yes !!!
                              @giovanni-monico Du you have installed the newest version v1.1 of the MRA Navigation app on you I-Phone?
                              Otherwise Apple CarPlay doesn’t work. If there is no update available, reinstall the navigation app.
                              Kindly regards
                              Reinhard
                              David McCoy
                              Michael Ferguson
                              giovanni monico
                              • Waze warnings...
                                ATLastundefined
                                ATLast
                                ATLastundefined
                                ATLast
                                -3
                                21
                                471
                              • Moving the map
                                Dave J 0undefined
                                246
                                Koen Vandecauter 0undefined
                                Koen Vandecauter 0
                              • Route stuurt mij terug naar start punt bij Android Carplay
                              • Testrit met AA ivm tracklog
