  4. WebPlanner routes backup?
7 Posts 7 Posters 2.5k Views 6 Watching
  • Lluis Arasanz
    wrote on last edited by Lluis Arasanz
    Hi Team,
    Regading system outage, there is any way in plane to make a "local" backup of all rutes on hard-drive (or other system)?
    I know some mates that are very upset with a (possible) lost of their work.
    Is not that we distrust on webplanner system, I supose you have this also in mind, but it could be an additional backup layer.
    Is not a GPX export only, I’m thinking in a personal full database backup.
    Not sure this is in plan or I’m fool to think that my routes could be lost.
    At least.. someone had to say it 😊
    Best regadrs And keep working!
    • BMW F750GS
    • Rob Verhoeff
      I think a local database of your routes in MRA-format is like selling the crownjewels voor MRA. I really don't know if any other app let you store your routes other than in gpx- or other well known format.
        The problem will be the MRA's own format. With GPX, you only have the pure geo data and no other information (such as text or images).
        I don't know if all this data is transferred when synchronizing with the app on the smartphone.
        If so, you basically have a backup.
        Guzzist Con Hennekens 2 Replies Last reply
          @Jörgen said in WebPlanner routes backup?:
          Sorry, I wouldn't call it as "backup". Sure, if you have switched on synch in the App, all routes are there; and usable also offline. Also additional text in each routepoint is offline available. Only pictures which have been attached to a routepoint are not available offline.
          Just if the route and then, the routepoint has been opened in the App - if the app is online - just then, the picture will be loaded. Further on - if the app is offline again - this picture in the routepoint is available. Means: you need to open the app, the route and each routepoint if the app is online - just then, the pictures are really and ongoing available in the App.
          Fazit: synch will synch everything, but not pictures which are attached to a routepoint.
          And on Android Smartphone, I wasn't able to localise this picture. It is anywhere inside the App.
          Nothing is impossible ;-)
            We have regular backups of all user data.
            If you want a generic backup, GPX export is indeed the way to go.
            Even the outage we had did not result in data loss as creating / modifying routes etc was simply not possible. The only lost data were a few tracklogs saved during that period.
              Data does only sync from cloud to phone, not vice versa I am afraid.
              • laurencetherobothams.co.uk
                I also would feel much safer, being able to backup all my routes in GPX format, just incase something happens. There is a large number of routes in MRA, a lot of work, and it would be devastating to lose it all, if a crisis occurred. There are too many to do 10 at a time, so in your major update work, could you consider it. (maybe a zip style backup, preserving the directories would be a good solution).... Thanks Guys for such a good product!!
                • How to plan correctly
                  Christian Feurstein
                  Christian Feurstein
                  416
                • test Myroute APP
                  1.8k
                  7.7k
                  593
                  Hubert Thori
                  Hubert Thori
                • Tour results and a question
