Garmin XT2 waypoint
Hi, I tried to export all the Gpx 1 2 with the waypoints from myrouteapp to the Garmin Tread app, but it doesn't let me see the waypoints in Tread and on the Garmin XT2, can anyone help me. Thanks
@Paolo-10 hi Paolo
If you export with 1.2 only the vuapoints are vissible and is exactly what is supposed to be -
@Paolo-10, To add to Marinus: if you want all waypoints visible, use the GPX 1.1 instead. Be aware that you will need to set your avoid/allow and shortest/quickest options on your Zumo identical to ones you used while planning. You will be navigating a route (trip) not a track.
hello and thank you for your answers, I tried to export to Gpx1 and 2 the waypoints do not show them, until a few months ago I used the Mappite app on WEB, I was able to put the waypoints even rename them, and export them to Garnin XT2, it always worked fine. I thought that with myroute there was no problem. I also noticed exporting to Gpx1 or 2, and then importing it into Mappite, the waypoints do not show them to me. I think the problem is due to Myroute WEB, I'm sorry they can't solve the problem. They have nice graphics, a nice intuition on the programming of the routes.
