  4. how to export route from MRA to Garmin XT2
2 Posts 2 Posters 1.0k Views 1 Watching
  • Jim O'Dowd
    Jim O'Dowd
    Jim O'Dowd
    Good day, friends!
    I'm a new lifetime subscriber to MRA and Navigation Next, and I'm going to need a little help to get started right. I'm an experienced Basecamp user, so creating the route in MRA was easy. And getting it to my Android smartphone was also easy!
    But now comes the hard part. I want to export the route to my Garmin XT2 as well. I did manage to do it, but the route file was corrupted. I exported the MRA route to a Dropbox folder and opened the file ini Tread. The file on my smartphone showed as only 200 feet, basically my start and stop points. None of the other 5 waypoints transferred over.
    When I synced the Tread file over to the XT2, obviously the same thing happened....only 2 waypoints vs. the 7 in MRA, and a 200 foot route vs. a 31-mile route.
    So my question is, is there a relaible, easy way to export a route file from MRA to Garmin XT without changing or corrupting the file?
    Many thanks,
    Jim O'Dowd
    Franklin, TN, USA
    Streetfox 1 Reply Last reply
    • Jim O'Dowd Jim O'Dowd
      Good day, friends!
      Many thanks,
      Jim O'Dowd
      Franklin, TN, USA
      Streetfox
      Streetfox
      Streetfox
      @Jim-O-Dowd Hallo, laut Youtube Vidoe von Rhoenschrat " Kurviger auf Garmin Zumo XT / XT2: Meine beste Lösung für einen sauberen GPX-Import | №395" verändert Explore und Tread von Garmin die GPX Dateien auf den Server. Es werden alle Punkte geändert / gelöscht.
      Empfehlung laut Video: Die Routendatei sollte per USB kabel oder SD Karte übertragen werden. Das zumo XT/ XT2 ändert die Routendatei nicht.
      Jim O'Dowd
      Jim O'Dowd
      Streetfox
      Streetfox
        Michael 2v
        Michael 2v
      • Map Layers
